PIX4Dcatch - FAQ
What is PIX4Dcatch?
PIX4Dcatch is a mobile application for ground 3D scans from android and iOS devices. PIX4Dcatch allows anyone to easily acquire the right terrestrial data for digitizing the reality around them and turning it into accurate 3D models.
Where can I download the PIX4Dcatch app?
To download the latest version of PIX4Dcatch, visit the App Store and Play Store.
What is the difference between PIX4Dcapture and PIX4Dcatch?
PIX4Dcapture is the flight planning and image acquisition app for aerial imaging, whereas PIX4Dcatch is a mobile application for ground 3D scans using iOS or Android devices.
Which operating system is supported by PIX4Dcatch?
PIX4Dcatch is currently supported on a device that runs on iOS version 13.4 or higher or on Android version 9 or higher.
Can PIX4Dcatch be used without an Internet connection?
An internet connection is needed every time the application is started for logging into the app. Once the login is complete, the internet connection is not necessary for capturing data.
However, the internet is needed to upload the data to PIX4Dcloud for generating the 3D model.
If using a viDoc RTK rover, you need an internet connection during data capture to stay connected to the NTRIP service.
What are the recommended devices?
  PIX4Dcatch only PIX4Dcatch with LiDAR PIX4Dcatch with viDoc RTK rover
Android Any Android device with ARCore capability. Not supported Not supported
iOS Any Apple iPhone or iPad device (iOS 13.4.1 minimum):
iPhone XR,
iPhone XS,
iPhone XS Max,
iPhone X,
iPhone 8 Plus,
iPhone 8,
iPhone 7,
iPhone 7 Plus,
iPhone 6s,
iPhone 6s Plus,
iPhone SE
iPad Air (2nd, 3rd generation),
iPad (5th, 6th, 7th generation),
iPad Mini (4th, 5th generation),
iPad Pro (1st: 12.9" & 9.7", 2nd: 12.9" & 10.5", 3rd: 11" & 12.9")
iPad Pro 2020,
iPhone 12 Pro,
iPhone 12 Pro Max
iPad Pro 2020 (11 inch),
iPhone 12 Pro,
iPhone 12 Pro Max,
iPhone 11*,
iPhone XR*
*The viDoc RTK rover is also supported on the iPhone 11 and iPhone XR. However, the phone cases need to be purchased separately from the SP-connect website.
Does PIX4Dcatch app utilize the LiDAR data (depth data) obtained from the device for processing?
PIX4Dcatch (iOS version) uses the LiDAR to capture the depth information of the surrounding during the image acquisition. The LiDAR points will compensate for the lack of 3D points over reflective and low texture surfaces.
PIX4Dcatch (Android version) doesn't use depth data while processing.
The option to upload the depth information is only available on the device (Apple iPad Pro 2020, iPhone 12 Pro, iPhone 12 Pro Max, and other iOS devices) with the LiDAR. While processing the exported project using PIX4Dmapper, the depth information will not be used. So, to use the depth data while processing, the project should be directly uploaded from the PIX4Dcatch app to the PIX4Dcloud. For more information visit, How to process the PIX4Dcatch project with the depth information.
How does PIX4Dcatch utilize the LiDAR data during image capturing and while processing?
During the image acquisition, the LiDAR sensor has the following benefits:
  • real-time feedback generated by the LiDAR sensor during capture guides you on the coverage of your area of interest
  • it also fine-tunes the positioning and pose information that automatically triggers the images
  • it helps in locating the project in the real world when compared to the device’s internal GPS that only gives a rough estimate.
If you use a LiDAR enabled iOS device, and choose to upload your project with the “Process with depth” enabled, the LiDAR data is used directly in two ways:
  • To estimate a more accurate scale of the reconstruction and
  • To fill low texture areas that photogrammetry alone is not able to reconstruct.
It is important to note that visible features are still needed in all the images, even if the LiDAR data is used.
For example, please check out these two projects: project processed without LiDAR and project processed with LiDAR. Notice the holes in the point cloud of the project processed without the LiDAR and see how these holes are filled out in the project processed with the LiDAR. Particularly, in areas that photogrammetry is unable to create “tie points”, it takes the help of the LiDAR data to fill those areas.
What is the accuracy of the reconstruction?
The absolute geolocation accuracy depends on how you georeference the images and if GCPs are used in the project or not.
  • With the integrated (phone) GNSS sensor, the absolute accuracy is expected to be a few meters.
  • With the viDoc RTK Rover, the absolute accuracy can be in the range of a few centimeters. For more information see How to use PIX4Dcatch with viDoc RTK rover article.
  • When GCPs are used, the absolute accuracy is expected to be in the range of the GCP errors.
Research has revealed that it is possible to achieve 3D models with an absolute geolocation accuracy of less than 5 cm. For more information see the white paper.
The relative accuracy of the reconstruction is expected to be in the range of 1 - 3 times Ground Sampling Distance (GSD). More in the What is the relative and absolute accuracy of mapping article.
How can I get RTK geotags on mobile images?
You need to download the PIX4Dcatch iOS app on your iPhone or iPad and purchase the viDoc RTK rover.
Since the RTK corrections are transferred via an NTRIP service, you will also need a subscription to an NTRIP service corresponding to your location.
When connecting the PIX4Dcatch app to the viDoc RTK rover via Bluetooth, the images are automatically geotagged with the accurate positions from the rover.
More information in the How to use PIX4Dcatch with viDoc RTK rover article.
How can I purchase the viDoc RTK Rover?
Contact us directly for the purchase of the viDoc RTK rover.
Can I include GCPs into my PIX4Dcatch project?
GCPs can be integrated into your PIX4Dcatch project by exporting the images and processing them in PIX4Dmapper or PIX4Dcloud with your GCPs. More information at How to include GCPs into a PIX4Dcatch project.
How can I merge drone images with my PIX4Dcatch dataset?
A possible workflow is to combine PIX4Dcatch image data without the LiDAR information and drone data into PIX4Dmapper. Manual Tie Points can be used to merge the two projects together. More information about how to process such datasets in the How to merge projects article.
How to enable the Compass Calibration service?
To get a more accurate orientation in PIX4Dcatch on iOS, the Compass Calibration must be enabled:
  • Click on the Settings icon.
  • Select Privacy.
  • Select Location Services.
  • Select System Services.
  • Turn Compass Calibration ON.
Can I access the raw or native images directly in my app?
Images captured can be accessed by every (logged-in) user. This means that every user with a PIX4D account can export the captured images.  Another way to access the images would be by using a PIX4Dcloud license. The images should be first uploaded to PIX4Dcloud and then downloaded.
Can I directly upload images to PIX4Dcloud for processing using the app?
Yes. You can only upload the images to the cloud for processing if you have the PIX4Dcloud or PIX4Dcloud Advanced license.
Can I export images from the app?
Every user with a PIX4D account can export images from the app. For more information, see How to export PIX4Dcatch projects (iOS, Android).
Does the PIX4Dcatch process the 3D model directly on the mobile device?
No. To process an accurate 3D model, you would need a valid PIX4Dcloud or PIX4Dmapper license.
In which languages is PIX4Dcatch available?
PIX4Dcatch is available in the English language.
What is the cost of PIX4Dcatch?
PIX4Dcatch is a free application for capturing data. However, you will need a valid PIX4Dcloud or PIX4Dmapper license to upload the dataset to PIX4Dcloud or process the project in PIX4Dmapper.
How can I get technical support for PIX4Dcatch?
Pix4D customers and trial holders: For technical questions, contact our support team.
Not a customer yet? Contact sales or post on the Pix4D Community.
Where can I submit the product feedback and feature requests?
Please help us understand what you need most by sharing your use case and upvote other users' feedback on the Pix4D Community.
5 out of 5 found this helpful
