Certain measures are essential to ensure the uploading stage is fulfilled successfully after the inspection has been created.
Under one of the following conditions, the upload gets paused:
- There is an Internet connection interruption (change of wifi network, internet provider interruption, etc...).
- The computer enters the Sleep mode.
- The SD card where the images are stored is disconnected from the uploading device.
As soon as the reason leading to the pausing of the uploading process is away, the image uploader should automatically take-over and continue with the uploading process. The only action needed from the user is to ensure the three above conditions are no more satisfied.
I want sky block to be one block and make it appear again once you delete it
Hi Amir,
Please create a new Community post here providing more information about your question: What product are you using, which version, a detailed description of the issue (please provide some screenshots highlighting the issue, send us the quality report of the project, etc). Thank you
