Pix4Dmatic keyboard shortcuts
Pix4Dmatic supports the use of shortcuts to make you more efficient at doing certain tasks. Shortcuts are especially useful when marking tie points.
The following shortcuts are available:
General shortcuts
Edit
View
Window
Marking
Category Action Windows Mac Note
General shortcuts New project Ctrl + N ⌘ + N
Open project Ctrl + O ⌘ + O
Save project Ctrl + S ⌘ + S
Close Ctrl + W ⌘ + W Close the current project. In the case of unsaved changes, an additional pop-up is displayed
Close all Ctrl + Shift + W ⌘ + ⇧ + W Close all open projects. In the case of unsaved changes, an additional pop-up is displayed
Exit software Alt + F4 ⌘ + Q In the case of unsaved changes, an additional pop-up is displayed
Menu bar
File
Edit
Process
View
Window
Help
Alt + F
Alt + E
  For quick access to the top menu items
Support page F1 F1 Open the Pix4Dmatic support documentation
Edit Undo the previous action Ctrl + Z ⌘ + Z To reverse the last action(s)
Redo the previous action Ctrl + Y ⌘ + ⇧ + Z To reverse the last Undo(s). The function is only available after the Undo command
Deselect object Esc Esc To deselect scene object
View Hide all panels Ctrl + Shift + H ⌘ + ⇧ + H To close all panels and display only the 3D view
Cameras Alt + C Option + C Toggle on/ off cameras.
Switch to 2D 2 2 Switch to the 2D view (DSM and orthomosaic)
Switch to 3D 3 3 Switch to the 3D view
View all Ctrl + 1 or C ⌘ + 1 or C The scene is zoomed out to the whole extent
Focus on selection Ctrl + 2 or F ⌘ + 2 or F Zoom on the selected object
Top view 7 7 View from the top. The scene is zoomed out to the whole extent
Window Minimize Ctrl + M ⌘ + M To minimize Pix4Dmatic
Show previous tab Ctrl + Shift + Tab ⌃ + ⇧ + Tab To move to the previous project in the project bar
Show next tab Ctrl + Tab ⌃ + Tab To move to the next project in the project bar
Marking Maximize image viewer Ctrl + F ⌘ + F To maximize or minimize the image viewer.
Full screen Space bar Space bar To enter and exit the full screen marking mode. An image needs to be selected or hovered over for the shortcut to work.
Next/ previous image ←, → ←, → To move to the next or previous images in the image list.
Re-sort the image list Ctrl + R ⌘ + R To re-sort the image list. The already marked images appear on the top of the list
Minimum zoom Ctrl + 1 ⌘ + 1 To jump to the minimum zoom level.
All images are completely zoomed out
Maximum zoom Ctrl + 2 ⌘ + 2 To jump to the maximum zoom level.
All images are zoomed in. When a mark is available, the image is zoomed into the center of the mark
Zoom in/out images Alt + scroll wheel Option + scroll wheel To zoom in and out of all images at once
3 out of 4 found this helpful
