Keyboard shortcuts - PIX4Dmatic
PIX4Dmatic supports various keyboard shortcuts to enhance efficiency and streamline workflows. Below are some commonly used shortcuts:
The following shortcuts are available:
General shortcuts
Edit
View
Window
Tools
Marking
Starting with PIX4Dmatic 2.1.0, it is possible to change the shortcut assigned to each action related to general shortcuts, selection and vectorizing tools, measurement tools, other actions, sections, settings, views, the 3D viewer, and the image viewer, allowing the keyboard layout to be customized to match the preferred workflow.
To modify the shortcuts, navigate through Edit > Preferences > Shortcuts
shortctus_2.1.0
General shortcuts
Action Windows MacOS Note
New project Ctrl + N ⌘ + N
Open project Ctrl + O ⌘ + O
Save project Ctrl + S ⌘ + S
Close project Ctrl + W or Ctrl + F4 ⌘ + W Close the current project. In the case of unsaved changes, an additional pop-up is displayed
Exit software Alt + F4 ⌘ + Q In the case of unsaved changes, an additional pop-up is displayed
Menu bar Alt + F (File)
Alt + E (Edit)
Alt + P (Process)
Alt + V (View)
Alt + W (Window)
Alt + H (Help)
Alt + T (Tools)
⌘ + W In the case of unsaved changes, an additional pop-up is displayed
Open the PIX4D Support website F1 ⌘ + ?
Edit
Undo the previous action Ctrl + Z ⌘ + Z Revert the last action(s)
Redo the previous action Ctrl + Y or Ctrl + Shift + Z ⌘ + ⇧ + Z Revert the last Undo(s). The function is only available after the Undo command
Deselect object Esc Esc To deselect the scene object
Delete the selected object Del, or backspace Del, or backspace An object needs to be selected
Move through selected vertices
Tab (next vertex)
Alt + Tab (previous vertex)
Tab (next vertex)
⇧ + Tab (previous vertex)
To move between vertices of a geometry
View
Hide all panels Ctrl + Shift + H ⌘ + ⇧ + H To close all panels and display only the 3D view
Switch to 2D 2 2 Switch to the 2D view (DSM and orthomosaic)
Switch to 3D 3 3 Switch to the 3D view
Orthographic view 5 5 Switch to orthographic view
Perspective view 6 6 Switch to perpective view
View all Ctrl + 1 ⌘ + 1 The scene is zoomed out to the whole extent
Focus on selection
Ctrl + 2 ⌘ + 2 Zoom in on the selected object
Top view
7 7 View from the top. The scene is zoomed out to the whole extent
Window
Minimize Ctrl + M ⌘ + M To minimize PIX4Dmatic
Show next tab
Ctrl + Tab
⌃ + Tab
To move to the next project in the project bar
Show previous tab
Ctrl + Shift + Tab ⌃ + ⇧ + Tab
To move to the previous project in the project bar
Tools
Simple selection S S To select the Select tool
Rectangle Selection R R To enable the rectangle selection tool
Polygon selection J J Enable the Polygon selection tool
Color selection Shift + C ⇧ + C To enable the Color selection tool
Object selection Y Y To enable the Object selection tool
Road selection Shift + A ⇧ + A
Marker M M To enable the Marker tool
Polyline L L To enable the Polyline tool
Polygon P P To enable the Polygon tool
Polygon hole
H H To enable the Polygon hole tool
Circle C C To enable the Circle tool
Arc A A To enable the Arc tool
Catenary U U To enable the Catenary tool
Assisted road marking Shift + R ⇧ + R To enable the Assisted road marking
Roof detection Shift + F ⇧ + F To enable the Roof detection tool
Wall detection Shift + W ⇧ + W To enable the Wall detection tool
Distance D D To enable the Distance tool
Volume V V To enable the Volume tool
Scale Constraint T T To begin drawing a Scale constraint
Orientation Constraint
G G To begin drawing an Orientation constraint tool
Stockpile detection
Shift + S ⇧ + W To enable the Stockpile detection tool
Region of Interest O O To create a delimiting region that restricts the extent of outputs
Orthomosaic editor Shift + O ⇧ + O To enable the Orthomosaic editor tool
Region of interest - delete selected region Del Del After enabling Region of interest (O), press the Del key to delete the selected region
Region of interest - cancel the creation Esc Esc After enabling Region of interest (O), press the Esc key to cancel the creation of the ROI
Region of interest - confirm the share Enter Return After enabling Region of interest (O), press the Enter/Return key to complete and confirm the shape of the ROI
Wireframe Scroll wheel button Scroll wheel button Enables a style view where the faces of polygons are invisible
Vectical section Shift + V ⇧ + V Create a vertical section
Horizontal section Shift + H ⇧ + H Create a horizontal section
Section from polyline Shift + L ⇧ + L Create a section selecting a polyline
Section from planar polygon Shift + P ⇧ + P Create a section selecting a polygon
Clipping box Crtl + B ⌘ + B  To enable or disable the clipping box
Marking
Maximize image viewer Ctrl + F ⌘ + F To maximize or minimize the image viewer.
Fullscreen Space bar Space bar To enter and exit the full-screen marking mode. An image needs to be selected or hovered over for the shortcut to work.
Next/ previous image ←, → ←, → To move to the next or previous images in the image list.
Re-sort the image list Ctrl + R ⌘  + R To re-sort the image list. The already marked images appear on the top of the list
Minimum zoom Ctrl + 1 ⌘  + 1 To jump to the minimum zoom level. All images are completely zoomed out
Maximum zoom Ctrl + 2 ⌘  + 2 To jump to the maximum zoom level. All images are zoomed in. When a mark is available, the image is zoomed into the center of the mark
Zoom in/out images Alt + scroll wheel Option + scroll wheel To zoom in and out of all images at once
