Example dataset - PIX4Dreact
Get started with real data
Explore PIX4Dreact’s functionalities by registering for a trial version and downloading an example project for free.
Using real data will demonstrate what PIX4Dreact can do, and will help you understand what is needed when collecting your own images.
Important: These datasets may only be used for personal or professional training. For commercial or promotional use, “Courtesy of Pix4D / pix4d.com” must be displayed and all the text linked to pix4d.com. For more information on usage, contact our marketing team.
PIX4Dreact example projects
Bahamas hurricane damage
| This project aims to generate a fast mapping after a disaster using PIX4Dreact |
| General project information | |
| Project | |
| Location | Bahamas |
| Average Ground Sampling Distance (GSD) | 2 cm |
| Area covered | 20 ha |
| Image acquisition | |
| Image acquisition plan | Grid flight plan |
| Camera | Zenmuse X5S |
| Images | |
| Dataset size | 1.62 GB |
| Number of images | 181 |
| Image geolocation coordinate system | WGS84 |
| Download the example project |
 The example project can be downloaded here. After downloading the zip archive, this needs to be unzipped. The folder contains images in JPG format  |
Belleview Avenue
| The goal of this project is to generate a map of a residential area using the Parrot Anafi drone. |
| Project | |
| Location | Colorado (USA) |
| Average Ground Sampling Distance (GSD) | 2.64 cm / 1.04 in |
| Area covered | 0.12 km2 / 11.86 ha / 0.05 sq mi |
| Output coordinate system | WGS84 / Universal Transverse Mercator zone 13N |
| UAV | Parrot Anafi |
| Image acquisition plan | 1 flight, grid flight plan |
| Camera | Anafi 4K 1.5.6 |
| Images | |
| Dataset size | 208 MB |
| Number of images | 38 |
| Image width | 5344 pixels |
| Image height | 4016 pixels |
 The example project can be downloaded here. After downloading the zip archive, this needs to be unzipped. The folder contains images in JPG format.  |
Dominica hurricane damage
| This project aims to generate a fast -mapping after a disaster using Pix4Dreact |
| Project | |
| Location | Loubiere (Dominica) |
| Average Ground Sampling Distance (GSD) | 13,23 cm / 5,21 in |
| Area covered | 45,22 ha |
| Output coordinate system | WGS84 / Universal Transverse Mercator zone 20N |
| Image acquisition plan | grid flight plan |
| Camera | Zenmuse X4S |
| Images | |
| Dataset size | 1.2 GB |
| Number of images | 155 |
| Image width | 9234 pixels |
| Image height | 5414 pixels |
