Automatic reports can be generated at any time during the inspection process.
Content
Pix4Dinspect can record, compile and list annotations, as soon as they are added to the images, together with the AI recognized antennas.
Reports contain information about:
- The user generating the report.
- The asset properties.
- The inspection project details.
- An overview of the image annotations.
- A full catalog of the single annotations per image with the image annotation details.
- The antennas' inventory.
Formats
The available formats for the report generation are:
JSON
Reports exported in this format can be used to produce customized reports or other outputs with third-party applications.
JSON example
Information about the user generating the report |
"reported_by": { |
Information about the asset properties |
"asset": { |
Information about the inspection project details |
"inspection": { |
An overview of the image annotations |
"image_annotations": { |
A full catalog of the single annotations per image with the image annotation details |
Information about the antennas (if antennas are present and recognized) |
Reports exported in this format collect the information generated during the inspection phase in an organized file with a default Pix4D style. For custom reports, contact our Sales team.
PDF structure
The .pdf report is structured as follows:
- A front-page containing:
- The Asset name
- Information about the user generating the report
- The date and time of the report generation
- The table of contents
- An Overview section containing:
- A snapshot of the asset on a base map background, taken from the Dashboard
- The Asset type
- The position of the asset (WGS84 coordinates that position the Asset onto the map of the Dashboard)
- The tower height (only if Panel antenna recognition is enabled in the Options before processing).
- The description of the Asset
- The date and time when the Inspection was created
- An Annotations section containing:
- The total number of annotations of the inspection project
- The number of annotations per severity level
- The full list of annotations with their type, severity level and description
For each annotated image: - The image with its name, its number of annotations, its position and yaw angle.
- In greater detail, for each annotation of the image, an enhanced cut-out of the annotation area together with the annotation’s properties (type, severity level and description).
- An Inventory section containing:
- The full list of antennas with their ID and type.
For each antenna: - Its properties: name, type, dimensions and orientations, altitude, supported frequencies, model, status.
- If any, the image chosen as best fit with the zoom level and image framing that were active when defining the image as such.
