Georeferencing of inspection projects, outputs and annotations - PIX4Dinspect
Image coordinate system
  • Horizontal: Normally WGS84.
  • Vertical: Normally EGM96.
Important: The input files need to have geolocation to be used in the processing.
Project coordinate system
The project coordinate system is the UTM projection of the WGS84 coordinate system. The UTM zone is defined by the coordinate values of the input files.
Output coordinate system
  • Horizontal: The same as the project coordinate system.
  • Vertical: The same as the image vertical coordinate system.
Displayed coordinates in the 2D/3D view
  • Horizontal: Displayed as latitude and longitude in WGS84 (decimal degrees) and also as X, Y coordinates in the project coordinate system.
  • Vertical: The same vertical coordinate system as the image vertical coordinate system. The unit can be meters (m) or international feet (ft) according to the account preferences. For more information: Pix4Dinspect - FAQ.
1 out of 1 found this helpful
