Drone Cell Tower inspection is mainly focused on acquiring as many images as possible to guarantee a full analysis of the different components and geometries during the upcoming stages.
Requirements
Designing the data acquisition plan
Setting reference
Sub-mission selection
Requirements
Quality of images
In order to design a good data acquisition, it is important to ensure images show the highest possible detail in the structure and antennas:
- Antenna images from all possible angles. To get the shape of the antenna as well as the rear photo of the antenna.
- Port configuration of the bottom. The image beneath the antenna is essential for the identification.
- Tower structure including the foundation and ground cabinets.
Quality of the scene reconstruction
The final point cloud should meet the following criteria:
- Low noise level.
- Surface definition and defined edges.
- High point density.
- High relative accuracy, including the correct scale, orientation, and verticality of the tower.
Figure 1.: Left: Noisy point cloud. | Center: Low-density point cloud. | Right: (Required) High-quality point cloud |
Flight planning depends on the tower structure, the number of points of interest, specific site requirements and tower dimensions.
As a generic example, we can consider a 35m (115 feet) cell tower with 2 antenna nests. Ideally, the missions to perform would be:
- One Orbit per antenna nest (green).
- One Underneath Orbit per antenna nest (blue).
- Cylinder (orange). If the cylinder mission can't be performed due to obstacles (e.g. guided towers), perform multiple single verticals.
Setting references
Cell Tower mission flights are based on certain references that are set based on drone positions while it is flying.
After tapping the Cell Tower mission in the mission selection menu, follow the guide and determine the Point of interest center and the Point of interest height.
This is done in order to be as accurate as possible to get the center reference of the Cell Tower to be mapped, warranting that all the flights within the same Cell Tower mission will share the same center position.
If Return to Home (RTH) height is lower than the current drone height when setting the center reference, a pop-up dialog will ask the user to confirm in order to update that value to the current height. This way the RTH will be a safe known height, higher than the tower to avoid potential collisions in case of an RTH.
The steps to perform this action are:
- Place the drone on top of the tower (at least 10m higher for security reasons).
- Ensure that the gimbal pitch is -90º (looking down). It can be set automatically by tapping Set to -90º.
- Point the camera so that it aims at the center of the tower with the cross-hair.
- Tap on Next to confirm the current center reference.
The next step is to determine the maximum height of the tower. This value is used for planning cylinder missions.
To determine the height reference:
- Align the drone with the highest point of the tower.
- Ensure that the gimbal pitch is 0º (looking forward). It can be set automatically by tapping Set to 0º.
- Point the camera so that it aims at the top of the tower with the cross-hair center.
- Tap Next to confirm the current highest point reference.
Once all the references are set, the sub-mission selection panel will be shown. This panel allows the user to select between the different available Cell tower sub-missions.
Select the sub-mission to fly by tapping on the sub-mission icon and then tap on Next.
The number of finished sub-missions and the total number of images for each sub-mission type are shown in case we are currently executing a Cell tower mission. After finishing any of the submissions (except single vertical), the Cell tower mission dialog is displayed. It is then possible to execute another sub-mission selecting it and tapping Set or to exit the mission by tapping Exit.
Camera parameters
In order to avoid acquiring overexposed or underexposed images, we recommend using the light condition templates (extremely sunny, mostly sunny, mostly cloudy, extremely cloudy) loading the recommended following white balance (WB) and exposure values (EV) for the different mission types.
Orbit sub-mission
The main goal of orbit sub-missions is to acquire images with high overlap around the point of interest. In the case of cell towers, this is typically the area of an isolated antenna or of antenna nests, where a group of antennas is located at the same height. Learn which types of antennas are recognized by Pix4Dinspect in AI recognition of antennas.
In order to get an optimally reconstructed point cloud, it is recommended to increase the number of images in the most interesting areas. These areas are normally where the antennas are located, but orbits can be executed at any height where the user wants to have a higher definition/density in the point cloud.
Rather than choosing parameters in the panel, values such as gimbal pitch, radius, and height are based on the video feed on the screen, so from the current drone position, which is manually adjusted with the drone's controller. This is to ensure that we are viewing what we are going to map, so having a correct point of view for the orbit images.
The following parameters can be adjusted.
Parameter | Description | Recommended value |
Images per orbit | The number of images that will be taken along the orbit | 80 images |
Gimbal pitch | Camera pitch at which the images are taken | -40º to -35º(min -60º, max -30º) |
Radius | 2D distance from the previously set reference center | 8 m. Based on drone position* |
height | Orbit height relative to the take-off point | Based on drone position, and depending on the POI height |
* Recommended value is based on a 2 m radius structure. If the structure is wider then the radius should be increased accordingly.
Cylinder sub-mission
The purpose of cylinder sub-missions is to guarantee the full mapping of the tower. The overlap between images can be lower as usually there is no need to get a high density/definition point cloud from the tower structure like the one needed for antennas.
Verticals | The number of vertical lines of the cylinder | 8 |
Front overlap | The image front overlap in the vertical line | 75% |
Min height | The minimum height of the lowest point in the vertical lines * | 15 m |
Radius | The radius of the cylinder * | 8m |
The following values are automatically calculated:
- Gimbal pitch: Values will be interpolated along each vertical between -45º at the highest point and the resulting value from looking to the tower base from the minimum height.
- The Max flight height: Maximum height for the drone to fly. The drone will start the first line from the top, at a height of Max height = Tower height + Radius.
Single vertical sub-mission
Single vertical sub-missions are meant to replace or complement a cylinder mission in case it can’t be completely performed due to obstacles (e.g. guided towers).
The dashed circle in the map view represents the selected radius. When the drone moves around the point of interest, the starting position of the single vertical is dynamically projected over it. Once a single vertical has been completed, the user remains in the sub-mission view and a green check appears on its location as a visual reference for upcoming single verticals.
Min height | The minimum height of the lowest point in the vertical lines | 15 m |
Radius | 2D distance from the previously set reference center | 8 m* |
Flight direction | Trajectory of the drone along the single vertical | Up to down |
* If multiple single vertical sub-missions are performed, it is recommended to use the same radius.
Underneath orbit sub-mission
It is designed to get high-quality images from the lower side of the antennas, connection board, cables, etc. Basically, the strategy is the same as for the orbit sub-mission but with a lower number of images.
Images per orbit | The number of images that will be taken along the orbit | 16 images |
Gimbal pitch | Camera pitch at which the images are taken | 25º (min 0, max 30º) |
Radius | 2D distance from the previously set reference center | 8 m |
The image Underneath orbit sub-mission, similar to the one orbit sub-misson, should have the values used in the example printed in the image (Altitude, Radius, Gimble). Allitude is missing.
