How to scan cell towers - PIX4Dscan
Drone Cell Tower inspection is mainly focused on acquiring the necessary images according to a precise flight planning strategy to ensure a full analysis of the different components and geometries during the upcoming stages.
Requirements
Quality of images
To design a good data acquisition, it is important to ensure images show the greatest possible detail in the structure and antennas:
  • Antenna images from all possible angles. To get the shape of the antenna as well as the rear photo of the antenna.
  • Port configuration of the bottom. The image beneath the antenna is essential for identification.
  • Tower structure, including the foundation and ground cabinets.
Quality of the scene reconstruction
Important: Acquired images must be suitable to generate a good quality Digital Twin. Optimally reconstructed antennas will ensure good results at the post-processing stage (antenna recognition and measurements).
The final digital twin should meet the following criteria:
  • Low noise level.
  • Surface definition and defined edges.
  • High point density.
  • High relative accuracy, including the correct scale, orientation, and verticality of the tower.
Left: Noisy digital twin.     Center: Low-density digital twin.         Right: (Required) High-quality digital twin
Designing the data acquisition plan
Flight planning depends on the tower structure, the number of points of interest, specific site requirements, and tower dimensions.
As a generic example, we can consider a 35m (115 feet) cell tower with two antenna nests. Ideally, the missions to perform would be:
  1. One Orbit per antenna nest (green).
  2. One Underneath Orbit per antenna nest (blue).
  3. Cylinder (orange). If the cylinder mission can't be performed due to obstacles, e.g., guyed towers, perform multiple single verticals.
Setting references
The Cell Tower mission locations are based on some references recorded by the operator after taking-off and while piloting manually the drone in the air.
Important: PIX4Dscan does not use the base map for cell tower mission planning. In order to correctly position the mission, characteristic points, for example, the center of the cell tower, need to be identified while flying the drone with the remote controller. The mission is then created using the measured position of these characteristic points.
After tapping the Cell Tower asset mission in the project creation window, follow the onboarding guide and determine the cell tower lowest point (optional), cell tower center, and the cell tower highest point.
Cell tower lowest point
Some locations do not allow users to take off at the same height as the cell tower base. This includes cases like rooftops or towers located on top of hills. To optimize the missions for these use cases, users can set the cell tower lowest point.
Important: This step is optional and should be skipped if the take-off height is at the same level as the cell tower base.
To determine the cell tower lowest point reference:
  • Align the drone with the lowest point of the tower
  • Ensure the camera angle is
  • Point the camera at the base of the tower
  • Tap on Next to confirm the current tower lowest point reference
Cell tower center
This is done to be as accurate as possible to get the center reference of the Cell Tower to be scanned, warranting that all the flights within the same Cell Tower mission will share the same center position.
If Return to Home (RTH) height is lower than the current drone height when setting the center reference, a pop-up dialog will ask the user to confirm to update that value to the current height. This way, the RTH will be a safe, known height higher than the tower to avoid potential collisions in case of an RTH.
To determine the cell tower center reference:
  • Place the drone on top of the tower (at least 10m higher for security reasons)
  • Ensure the camera angle is -90°
  • Point the camera at the center of the tower
  • Tap on Next to confirm the current tower center reference
Cell tower highest point
The next step is to determine the cell tower highest point. This value is used for planning cylinder and single vertical missions.
Note: Keep in mind that all height values are relative to the drone take-off position. For security reasons, ensure to take-off at the same level as the tower base or to set the tower lowest point reference accurately.
To determine the cell tower highest point reference:
  • Align the drone with the highest point of the tower.
  • Ensure the drone height is higher than 10 meters.
  • Ensure the camera angle is 0°.
  • Point the camera at the top of the tower.
  • Tap Next to confirm the current tower highest point reference.
Sub-mission selection
Once all the references are set, the sub-mission selection panel will be shown. This panel allows the user to select between the different available Cell tower sub-missions.
The PIX4Dscan missions are specially designed to deal with signal lost scenarios, as it can be a common case. If the signal is lost during a mission the drone will continue flying the mission and triggering the images. If once the mission is finished the signal is not back, then the drone will execute the selected signal lost action (RTH, Hover, Land). This ensures the integrity of the data.
Select the sub-mission to fly by tapping on the sub-mission icon and then tap on Next.
The number of finished sub-missions and the total number of images or videos for each sub-mission type are shown in case we are currently executing a Cell tower mission. After finishing any of the sub-missions (except single vertical), the Cell tower mission dialog is displayed. It is then possible to execute another sub-mission selecting it and tapping Set or to exit the mission by tapping on the cross at the top right side of the panel.
Camera parameters
In order to avoid acquiring overexposed or underexposed images, we recommend using the light condition templates (extremely sunny, mostly sunny, mostly cloudy, extremely cloudy) loading the recommended following white balance (WB) and exposure compensation values (EV) for the different mission types.
Note: The above exposure compensation values (EV) are reference values, but can be modified within their ranges to adapt the luminosity of the images.
Orbit sub-mission
The main goal of the orbit sub-missions is to acquire images with high overlap around the point of interest. In the case of cell towers, this is typically the area of an isolated antenna or of antenna nests, where a group of antennas is located at the same level. Learn which types of antennas are recognized by PIX4Dinspect in AI recognition of antennas.
In order to get an optimally reconstructed digital twin, it is recommended to increase the number of images in the most interesting areas. These areas are normally where the antennas are located, but orbits can be executed at any level where the user wants to have a higher definition/density in the digital twin.
Rather than selecting them from the mission settings, values such as camera angle, radius, and height are based on the video feed on the screen, so from the current drone position, which is manually adjusted with the drone's controller. This is to ensure that we are viewing what we are going to scan, so having a correct point of view for the orbit images.
The following parameters can be adjusted.
Parameter Description Recommended value
Capture mode**
Time interval capture: time optimized continuous flow
Stop at capture point: stability and image centering optimized flow
Flight direction
Flight direction allows users to define the direction of a circular mission
Clockwise or Counterclockwise
Truncate by
Mission truncation allows users to define a truncation angle for the mission, providing flexibility on mission design
Default: 0°, Range: 0° - 315°, Steps: 15°
Images per orbit The number of images that will be taken along the orbit 80 images
Camera angle Camera angle -40º to -35º(min -60º, max -30º)
Radius 2D distance from the previously set reference center 8 m. Based on drone position*
height Orbit height relative to the take-off point Based on drone position, and depending on the POI height
* Recommended value is based on a 2 m radius structure. If the structure is wider then the radius should be increased accordingly.
*Different capture modes are supported for DJI drone
Cylinder sub-mission
The purpose of cylinder sub-missions is to ensure the full scanning of the tower. The overlap between images can be lower as usually there is no need to get a high density/definition point cloud from the tower structure like the one needed for antennas.
Flight direction Flight direction allows users to define the direction of a circular mission Clockwise or Counterclockwise
Truncate by Mission truncation allows users to define a truncation angle for the mission, providing flexibility on mission design Default: 0°, Range: 0° - 315°, Steps: 45°
Mission min height The minimum height of the lowest point in the vertical lines * 15 m (min. 5m above min POI height)
Mission radius The radius of the cylinder * 8m
Verticals The number of vertical lines of the cylinder 8
Front overlap The image front overlap in the vertical line 75%
The following values are automatically calculated:
  • Camera angle: Values will be interpolated along each vertical between -45º at the mission maximum height and the resulting value from looking to the tower base from the mission minimum height.
  • Mission maximum height: Maximum height for the drone to fly. The drone will start the first line from the top, at a height of Mission max height = Cell tower highest point + mission radius.
Single vertical sub-mission
Single vertical sub-missions are meant to replace or complement a cylinder mission in case it can’t be completely performed due to obstacles (e.g. guyed towers).
The dashed circle in the map view represents the selected radius. When the drone moves around the point of interest, the starting position of the single vertical is dynamically projected over it. Once a single vertical has been completed, the user remains in the sub-mission view and a green check appears on its location as a visual reference for upcoming single verticals.
Mission min height The minimum height of the lowest point in the vertical lines  15 m (min. 5m above min POI height)
Mission radius 2D distance from the previously set reference center 8m*
Flight direction Trajectory of the drone along the single vertical Up to down
* If multiple single vertical sub-missions are performed, it is recommended to use the same radius.
Note: We recommend a minimum of 8 verticals per project to ensure a good reconstruction.
  • The Max flight height: Maximum height for the drone to fly. The drone will start the first line from the top, at a height of Mission max height = Cell tower highest point + mission radius.
Underneath orbit sub-mission
It is designed to get high-quality images from the lower side of the antennas, connection board, cables, etc. Basically, the strategy is the same as for the orbit sub-mission but with a lower number of images.
Truncate by Mission truncation allows users to define a truncation angle for the mission, providing flexibility on mission design Default: 0°, Range: 0° - 315°, Steps: 15°
Images The number of images that will be taken along the orbit 16 images
Camera angle Camera angle at which the images are taken 25º (min 0, max 30º)
Orbit line of sight sub-mission
The Orbit line of sight sub-mission is designed to get a 360º view of the cell tower surroundings. It helps to identify obstacles around the asset, and also check the visual line with other locations. It executes an orbit from the current drone height looking outwards the asset.
In order to start an orbit line of sight mission, the camera angle must be set at 0º.
Images The number of images that will be taken along the orbit Default: 8, Range: 8 - 32, Steps: 1
Radius 2D distance from the previously set reference center 8m. Based on Drone position*
Height Orbit height relative to the take-off point Based on drone position, and depending on the POI height
* Recommended value is based on a 2m radius structure. If the structure is wider, then the radius should be increased accordingly.
18 out of 19 found this helpful
3 comments
  • Fernando Luís
    The image Underneath orbit sub-mission, similar to the one orbit sub-misson, should have the values used in the example printed in the image (Altitude, Radius, Gimble). Allitude is missing.
  • Tomas Bechmann
    I had issues with GPS signal and had to make the radius 18 meters to avoid fall outs. Any issues with a larger radius except for resolution? Any clever tricks to avoid it?
  • Marco Paccagnella
    Dear Thomas,
    Depending on the drone location, some satellites can be physically hidden leading to a poor GPS signal. Could you eventually try to start the mission in a different location around the cell tower?
    We usually recommend a radius of around 8 meters. A larger value would lead to lower details in the images. Please keep the radius as constant as possible in the different cell tower sub-missions to get a good reconstruction.
    I hope this helps.
