How to map cell towers
Drone Cell Tower inspection is mainly focused on acquiring as many images as possible to guarantee a full analysis of the different components and geometries during the upcoming stages.
Requirements
Quality of images
In order to design a good data acquisition, it is important to ensure images show the highest possible detail in the structure and antennas:
  • Antenna images from all possible angles. To get the shape of the antenna as well as the rear photo of the antenna.
  • Port configuration of the bottom. The image beneath the antenna is essential for the identification.
  • Tower structure including the foundation and ground cabinets.
Quality of the scene reconstruction
Important: Acquired images must be suitable to generate a good quality point cloud. Optimally reconstructed antennas will guarantee good results at the post-processing stage (antenna recognition and measurements).
The final point cloud should meet the following criteria:
  • Low noise level.
  • Surface definition and defined edges.
  • High point density.
  • High relative accuracy, including the correct scale, orientation, and verticality of the tower.
Figure 1.: Left: Noisy point cloud. Center: Low-density point cloud. Right: (Required) High-quality point cloud
Designing the data acquisition plan
Flight planning depends on the tower structure, the number of points of interest, specific site requirements and tower dimensions.
As a generic example, we can consider a 35m (115 feet) cell tower with 2 antenna nests. Ideally, the missions to perform would be:
  1. One Orbit per antenna nest (green).
  2. One Underneath Orbit per antenna nest (blue).
  3. Cylinder (orange).
Setting references
Cell Tower mission flights are based on certain references that are set based on the drone positions while it is flying.
Important: Pix4Dscan does not use the base map for mission planning. In order to correctly position the mission, characteristic points, for example, the center of the cell tower, need to be identified while flying the drone with the remote controller. The mission is then created using the measured position of these characteristic points.
After tapping the Cell Tower mission in the mission selection menu, follow the guide and determine the Point of interest center and the Point of interest altitude.
This is done in order to be as accurate as possible to get the center reference of the Cell Tower to be mapped, warranting that all the flights within the same Cell Tower mission will share the same center position.
If Return to Home (RTH) altitude is lower than the current drone height when setting the center reference, a pop-up dialog will ask the user to confirm in order to update that value to the current height. This way the RTH will be a safe known altitude, higher than the tower to avoid potential collisions in case of an RTH.
The steps to perform this action are:
  • Place the drone on top of the tower (at least 10m higher for security reasons).
  • Ensure that the gimbal pitch is -90º (looking down). It can be set automatically by tapping Set to -90º.
  • Point the camera so that it aims at the center of the tower with the cross-hair.
  • Tap on Set to confirm the current center reference.
The next step is to determine the maximum altitude of the tower. This value is used for planning cylinder missions.
Note: Keep in mind that all altitude values are relative to Home Point Altitude, so for security reasons ensure to set the home point at the same height as the cell tower base.
To determine the height reference:
  • Align the drone with the highest point of the tower.
  • Ensure that the gimbal pitch is 0º (looking forward). It can be set automatically by tapping Set to 0º.
  • Point the so that it aims at the top of the tower with the cross-hair center.
  • Tap Set to confirm the current highest point reference.
Sub-mission selection
Once all the references are set, the sub-mission selection panel will be shown. This panel allows the user to select between the different available Cell tower sub-missions.
Select the sub-mission to fly by tapping on the sub-mission icon and then tap on Set.
The number of finished sub-missions and the total number of images for each sub-mission type are shown in case we are currently executing a Cell tower mission. After finishing any of the sub-missions, the Cell tower mission dialog is displayed. It is then possible to execute another sub-mission selecting it and tapping Set or to exit the mission by tapping Exit.
Camera parameters
In order to avoid acquiring overexposed or underexposed images, we recommend using the following exposure values (EV) in the camera parameters for the different missions.
Note: The above exposure values (EV) are reference values, but can be modified within their ranges to adapt the luminosity of the images.
Orbit sub-mission
The main goal of orbit sub-missions is to acquire images with high overlap around the point of interest. In the case of cell towers, this is typically the area of an isolated antenna or of antenna nests, where a group of antennas is located at the same height.
In order to get an optimally reconstructed point cloud, it is recommended to increase the overlap in the most interesting areas. These areas are normally where the antennas are located, but orbits can be executed at any height where the user wants to have a higher definition/density in the point cloud.
Rather than choosing parameters in the panel, values such as gimbal pitch, radius, and altitude are based on the video feed on the screen, so from the current drone position, which is manually adjusted with the drone's controller. This is to ensure that we are viewing what we are going to map, so having a correct point of view for the orbit images.
The following parameters can be adjusted.
Parameter Description Recommended value
Images per orbit The number of images that will be taken along the orbit 80 images
Gimbal pitch Camera pitch at which the images are taken -40º (min -60º, max -30º)
Radius 2D distance from the previously set reference center 8 m
Altitude Orbit altitude relative to the take-off point Based on drone position, and depending on the POI altitude
Cylinder sub-mission
The purpose of cylinder sub-missions is to guarantee the full mapping of the tower. The overlap between images can be lower as usually there is no need to get a high density/definition point cloud from the tower structure like the one needed for antennas.
Verticals The number of vertical lines of the cylinder 8
Images per vertical The number of images per vertical line 12 images
Min height The minimum height of the lowest point in the vertical lines * 10 m
Radius The radius of the cylinder * *
* The value of the parameter is based on the current drone value.
The following values are automatically calculated:
  • Gimbal pitch: Values will be interpolated along each vertical between -45º at the highest point and the resulting value from looking to the tower base from the minimum height.
  • The Max flight height: Maximum height for the drone to fly. The drone will start the first line from the top, at a height of Max height = Tower height + Radius.
Underneath orbit sub-mission
It is designed to get high-quality images from the lower side of the antennas, connection board, cables, etc. Basically, the strategy is the same as for the orbit sub-mission but with a lower number of images.
Images per orbit The number of images that will be taken along the orbit 16 images
Gimbal pitch Camera pitch at which the images are taken 25º (min 0, max 30º)
8 out of 8 found this helpful
1 comment
  • Fernando Luís
    The image Underneath orbit sub-mission, similar to the one orbit sub-misson, should have the values used in the example printed in the image (Altitude, Radius, Gimble). Allitude is missing.
