The outputs of the PIX4Dinspect project consist of Intelligent Digital twin and of post-processing results, such as reports.
3D Model
Extension |
Description |
.las |
3D Model file. (For Cell Tower assets) The downloaded 3D Model is the clipped 3D Model if the clipping radius was specified in the Options while creating the new project. |
Textured 3D Model
Extension |
Description |
.obj |
Textured 3D Model file. This output is available for all the asset types except Cell towers and Transmission towers. |
Elevation map
Extension |
Description |
.tif |
Elevation map file. |
Image map
Extension |
Description |
.tif |
Image map file. |
Note: The output coordinate system of the output results, annotation, and report are in WGS84.
Post-processing results
Reports
Extension |
Description |
.json |
Json file containing information about the process. |
.pdf |
Pdf report. |
More information on reports in Reports.
Outputs can be exported on a local device. More information on how to export outputs in: Export.
