Previous | Next |
This article goes step by step through the process of creating a new project in Pix4Dinspect.
A new project is a cloud-based project that belongs to an asset and allows generating Intelligent Digital twin, visualize them in 2D and 3D, inspect the reconstructed models and annotate images for collaboration.
Inspection creation
1. At the top left of the Dashboard, click and select New Project.
2. The window Create New Project appears.
3. Assign the new project to an asset choosing one of the following options:
- Select an existing asset to which the new project should belong from the drop-down list or from the map. You can also provide the Project name(option) and the date for the project.
- Create a new asset. A detailed explanation here.
4. Click Next.
Inputs selection
Inputs can be added via drag and drop or selected from the disk.
Drag and drop input files
- Drag and drop the input files on the screen.
- (Optional) More input files can be added if needed.
- Click Next.
Select from Disk
- Click Select from Disk.
- Click Next.
Options
Different options are available to define the intelligent digital twin and to activate the artificial intelligence algorithms for antenna detection.
- Digital twin: select this option to generate all the following intelligent digital twin
- 3D Model
- Textured 3D Model (for Cell Tower assets the textured 3D Mesh is not generated)
- Image map
- Elevation map
- Area of interest: defines the radius of the circle outside of which the 3D Model will be cut. The center of the circular area is the center of the cell tower, which is estimated through a density structure analysis.
- Auto: crops the 3D model using the automatic image geolocation
- Don't crop: recommended for a project mapping the vertical wall
- Artificial Intelligence plugins: The user can apply the custom AI algorithms to your data and improve your intelligent digital twin.
- Antenna recognition: select this option to run antenna recognition algorithm to obtain antennas' location, dimensions and orientation. More information in: Inventory tool.
The user can navigate between the different steps by clicking Previous and Next.
To start generating the outputs, click Upload.
