- Pix4D Documentation
- PIX4Dinspect
- Getting started
New asset - PIX4Dinspect
This article goes step by step through the process of creating a new asset in Pix4Dinspect.
An asset is a collection of cloud-based projects, called projects, that allow generating Intelligent Digital twin, visualize them in 2D and 3D, inspect the reconstructed models and annotate images for collaboration.
Note: All projects belonging to the same asset are shown in the upper bar timeline when opening any of those projects.
There are two ways to access the New Asset wizard.
- Before creating a project: at the top left of the dashboard, click
and select New Asset.
- While creating a new project, whose asset has not been created in advance.
Define the asset's properties in the New Asset wizard.
- Location: WGS84 (EPSG:4326) coordinates that identify the location of the asset.
The coordinates can be defined by:
- Manually inserting them in the Location field, with the format [latitude, longitude] in degrees.
- Selecting the asset's location on the map. The address of the location can be inserted in the search bar for faster focusing on the map.
Note: The location of the asset do not have any influence on the processing. They can be edited at any time from the dashboard.
- Asset name: univocal name given to the asset.
- Asset type: category of the asset. Available options are:
- Telecom (for inspect-telecom licenses only, contact sales for more information):
- Self-support
- Monopole
- Guyed tower
- Rooftop
- Watertower
- Generic:
- Transmission tower
- Rooftop
- Building
- Bridge
- Cooling tower
- Energy utility
- Other
Note: The Telecom asset is the correct asset to be used for any type of Telecom project, tower, water tower, roof installation, etc.
Warning: The asset type cannot be changed after the asset has been created.
- Asset Description (optional): a short description of the asset.
Click Save to finalize the asset creation.
The asset is now created and visible on the dashboard. Projects can be added to the asset.
