Pix4Dscan supported drones, cameras and controllers
Pix4Dscan is compatible with the following drones, cameras, and controllers.
Manufacturer Drone Camera Controller iOS
DJI drones Phantom 4 Pro Built-in Default GL300F Compatible (1.0.0)
Phantom 4 Pro V2.0 Built-in Default GL300L Compatible (1.0.0)
Mavic 2 Pro Built-in Default RC1A Compatible (1.0.0)
Phantom 4 Built-in Default GL300C Not tested
Parrot drones Anafi Built-in Default SkyController 3 Compatible (1.0.0)
Anafi Thermal Built-in (RGB only) Default SkyController 3 Compatible (1.1.0)
Anafi USA Built-in (RGB only) Default SkyController 3  Not tested
Tip: The following drones are not officially tested by Pix4Dscan. However, you will be able to fly your mission if you select the appropriate settings in Pix4Dscan:
  • Anafi USA & Anafi Thermal: Select Anafi drone in Pix4Dscan's  Drone selector dropdown list.
Pix4Dscan is compatible with iPad devices only. Pix4Dscan requires iPad OS 11.0 or later. We recommend using the latest OS version as it is usually the one used for internal testing. Pix4Dscan has been tested with the following devices:
  • iPad Mini 5th gen, iPad Pro 2nd gen, iPad 7th gen, iPad Air 2.
Disclaimer: Pix4D publishes this information as a courtesy to its customers. Because this information may not be accurate, Pix4D makes no warranty of any kind, expressed or implied, with respect to its validity.
6 out of 8 found this helpful
18 comments
  • Roger Paudex
    Hi,
    • What are the requirements of a drone for Pix4DScan to be compatible with it?
    • In case the drone also has a thermal camera, is it possible for Pix4DScan to display the thermal view as well?
    • Is it possible not to use the predefined tower trajectory but to freely fly around?
    Thanks
  • Alice (Pix4D)
    Hi Roger,
    At the moment Pix4Dscan does not support thermal cameras but we are interested in discussing further with you to better understand your use case. Could you please send us a support request at this link https://support.pix4d.com/hc/en-us/requests/new? so that we can also clarify your additional doubts? Thank you
  • Weifeng YU
    The program and workflow look great! When can we expect mavic 2 pro support? The PH4 pros are no longer in production.
    Thanks!
  • Alice (Pix4D)
    Hi, happy to read your positive comments!
    We will add support for more drones soon and the Mavic 2 Pro is on our list but we cannot give you an estimate for when the new camera will be implemented in the app.
  • Raphael Atimbire
    Hi Alice,
    Is Pix4D Scan compatible with Phantom 4 pro RTK yet?
  • Alice (Pix4D)
    Hi Raphael, Pix4Dscan does not support the P4P RTK at the moment.
  • Raphael Atimbire
    Thank you.
  • Michael Martin
    I recently purchased the DJI Mavic Air 2 Pro with the 4K Hasselblad camera and the new Smart Controller.  Will your software work with this drone and the Smart Controller?  I believe that the Smart Controller has a built-in Android device built-in.  It is the more advanced controller and does not need a cellular phone nor a tablet.  Will it all work?  I want to do tower inspections.
  • Fernando Luís
    Hi,
    does the PIX4Dscan is compatible with Phantom 4 PRO with a remote control that has a built in screen?
    Thanks in advance,
    Fernando
  • Alice (Pix4D)
    Hi Michael Martin and Fernando Luís
    The DJI Mavic Air 2 Pro and the new Smart controller are not supported at the moment.
    The default remote controller is supported for the P4P as specified under the table of the article (the model is the GL300F).
  • José González
     Hola
      El Mavic AIR 2 es compatible con el software Pix4Dscan ?? según veo mas arriba en Julio 9 consultaron lo mismo y la respuesta fue que en ese momento no era compatible. Yo quiero saber si ya es compatible ahora?. O aún continúa incompatible ??
     Gracias por su respuesta,  de antemano!
  • Alice (Pix4D)
    Hola Josè,
    La lista aquí siempre está actualizada. Por lo tanto, el Mavic Air 2 no es compatible con Pix4Dscan en este momento.
  • Robert Groen
    Is Pix4D scan compatibale  with the DJI Mavic Pro (as the it's compatible with pix4D capture)?
  • Alice (Pix4D)
    Hi Robert, the DJI Mavic Pro is not supported at the moment.
  • محمود قاسم
    Hello, when will the Mavic Air 2 be downloaded to your program?
  • Kapil (Pix4D)
    Hello,
    The DJI Mavic Air 2 is not supported by pix4Dscan at the moment and it is currently not in our pipeline to support it. If things change, we will publish it on this page.
  • Rubén Asensio
    Hola,
    Hace poco asistí a un webinar sobre Pix4Scan y me pareció un producto muy interesante. ¿Estará la aplicación disponible para Android en un futuro?
    Gracias!
  • Kapil (Pix4D)
    Hello,
    Pix4Dscan is currently supported on iOS (iPad only). At the moment, we don't have any plan to support the product on android devices, if thing changes we will post it on our Support Page here.
