SETTING | DESCRIPTION |
Account details |
This section contains account details information:
Safety and Security Only available when the connection with the drone is established. |
Minimum drone battery level: Set the minimum drone battery level under which PIX4Dscan will not allow a mission to be started or resumed. Signal lost action: Defines which action is taken in case of connection loss between the remote controller and the drone (Not connected status). The action will only be executed if the drone is not performing a mission.
RTH height: defines the height that the drone will reach before starting returning to the home point. Restore: tap on the |
Interface |
Map orientation: defines the orientation of the Map view. Options are:
Units: defines which units are shown in the application to express distances and velocities. Options are:
Language: select the preferred language for the application. Options are:
Help |
This section links to the PIX4Dscan documentation and onboarding guides (cell tower and grid) and allows users to contact technical support and send all logs by email directly from the device. |
About |
It contains the application disclaimer, the PIX4D terms and policies, and the third-party licenses. |
