[iPadOS, Android] PIX4Dscan - Settings
Manual
Settings
Access: On the top bar, tap menu.png.
SETTING DESCRIPTION
Your Pix4D account
This section contains:
  • User information: the user's first name and last name, email of the Pix4D account.
    Tap Log out to log out and access the login screen upon confirmation.
  • License information: it describes the type and the duration of the currently active license.
  • Privacy Settings: click Update to specify communication and data privacy preferences.
Safety and Security
Only available when the connection with the drone is established.
Important: For the Safety and Security settings coming from the vendor applications, their values are retrieved in PIX4Dscan (signal lost action, RTH height etc.). We recommend checking all the safety and security settings before starting the flight.
Signal lost action: Defines which action is taken in case of connection loss between the remote controller and the drone (Not connected status). The action will only be executed if the drone is not performing a mission.
The options are the following:
  • Return to home point (recommended): the drone returns to the home point.
  • Land: the drone lands on its current location.
  • Hover: the drone hovers on its position.
Minimum drone battery level: Set the minimum drone battery level under which PIX4Dscan will not allow a mission to be started or resumed.
RTH height: defines the height that the drone will reach before starting returning to the home point.
Restore: tap on the Restore button to restore all safety and security settings to default recommended values.
Interface
Map orientation: defines the orientation of the Map view. Options are:
  • Drone bearing locked: the orientation of the Map view rotates together with the drone moving.
  • Manual bearing: the orientation of the Map view remains fixed while the drone is moving.
Unitsdefines which units are shown in the application to express distances and velocities. Options are:
  • Metric (m, m/s)
  • Imperial (ft, mph)
Languageselect the preferred language for the application. Options are:
  • English
  • Spanish
  • Japanese
  • French
Help
This section links to the PIX4Dscan documentation and onboarding guides (cell tower and grid) and allows to contact technical support and send all logs by email directly from the device.
About
It contains the application disclaimer, the PIX4D terms and policies, and the third-party licenses.
1 out of 1 found this helpful
