Manual - PIX4Dscan
Manual
Settings
This guide is intended to explain all the functionalities and settings available in PIX4Dscan. It is recommended to read it carefully to be familiar with the application and to have the best experience using it.
The manual is divided into the following categories:
Login
A login window appears at a fresh install of PIX4Dscan or after a previous log out.:
  1. Enter the email and password of the PIX4D user account.
  2. Click Login.
Note: The internet connection is needed to log into the app. Once the login is complete, the internet connection is not needed anymore.
Dashboard
The Dashboard is displayed after having logged in.
From the Dashboard, several actions are possible:
  • Drone selector and status: from the drop-down menu, select one of the supported drones and ensure its status is Connected.
  • Settings: tap menu.png to access the Settings. For more information: PIX4Dscan - Settings.
  • Start flight: the button is only available if the drone is connected. Tap Start flight to proceed with the flight.
Once Start flight has been tapped, the Flight view and the Map view appear.
Before starting the flight, drone connection is needed and we recommend going through the Safety and Security Settings.
Flight view
The Flight view is enlarged by default. It provides real-time video feedback from the drone, needed to follow the flight and to get visual information on the quality of the images.
The video-feed reflects the same image brightness and white balance as it will be used while taking the images.
Camera white balance and exposure value can be customized in the flight view when the properties of the mission are not edited or when the drone is not performing a mission.
Note: The Flight view is only available if the drone is detected as Connected.
Map view
The Map view shows the view with a basemap. To customize the Map view settings go to the Interface settings. For more information: Settings.
The Flight view is enlarged by default. It is possible to minimize or close the video feed by tapping on the Map box or - button at the bottom left.
Note: The basemap is displayed if the internet connection is established. The map can be cached in memory beforehand in case the Internet connection is not available on the field. For more information: Is an Internet connection needed to use PIX4Dscan?.
Possible actions that can be performed in this view are:
  • Interact with the map (move, rotate, zoom, switch styles)
  • Create a new project
  • Enter the project list
In the Map view:
  • homepoint.png defines the home point location.
  • drone_0.75.png defines the drone location.
  • GPS_marker0.5.png defines the device location. The radius of the biggest circle defines the accuracy of the GPS position.
  • poi.png defines the point of interest location (only displayed when a POI mission is being set up).
  • north-16__1_.jpgpoints to the North. When the map is rotated, tap the icon to align the current orientation of the map with the North.
  • Scale.jpg a visual scale defines the scale of the map.
  • map_switch_to_satellite.jpg lets the user switch from Streets to Satellite base map.
  • map_switch_to_streets.jpg lets the user switch from Satellite to Streets base map.
  • Pix4Dcatch_reset_the_shape.png lets the user reset a grid mission to its default shape and location (only displayed when a grid mission is being set up).
  • Pix4Dcatch_center_the_map.png lets the user center the map view on the mission location (only displayed when a mission is being set up).
  • telemetry.png to review the drone telemetry (See the dedicated section).
Tap on returntohome.png  to trigger a return to home action (See the dedicated section).
Tap on add_mission.png to open the project creation window (See the dedicated section).
Tap on folder.png  to open the project list view (See the dedicated section).
Tap focus_on_drone.png to center the Map view on the drone position.
Status bar
The top bar displays different items in order to monitor the status of different properties that are important before and while flying the mission.
Flight mode: defines in which mode the drone is flying. The possible values are:
  • MANUAL FLIGHT while flying the drone with the remote controller to take-off, land, and fly to the object of interest and set up the mission.
  • IN MISSION during the mission
  • GOING TO LAND when landing or when returning to home
  • LANDED when landed on the ground. If the drone is landed, the PIX4Dscan logo in the top left corner allows to exit flight or map view and go back to the dashboard.
Connection and datalink quality: monitors the connection to the drone and the quality of the datalink. Values can be:
  • Connected. Within the Connected status, different datalink quality types can be detected so that signal loss can be prevented when the connection is getting weaker.
  • Not connected. If the connection is lost during the mission, the drone will behave as specified in the Safety and Security settings. The mission gets paused and can be resumed later.
drone_battery.png Drone battery: monitors the drone battery level.
  • Green if there is sufficient battery.
  • A warning appears when the battery level is comprised in between 30% and the minimum drone battery level set in the safety and security settings.
  • It becomes critical (red) when it reaches the minimum drone battery level set in the safety and security settings.
controller_battery.png Controller battery: monitors the controller battery level.
  • A warning appears when the battery is lower than 30% and the icon turns into the orange color.
  • It becomes critical (red) when it reaches 20%.
memory_card-outline.png Memory card free space: monitors the memory card free space.
  • Green if a sufficient amount of free space exists.
  • Orange if the amount of free space is lower than 3 GB.
  • Red if the amount of free space is critically low (lower than 1 GB).
satellite.png Satellite number and GPS signal: monitors the number of satellites available for positioning and the GPS signal strength.
  •  A minimum of 6 satellites is required.
Important: If one of the above critical conditions occurs before starting or resuming the mission, a pre-flight check will prevent the mission to be started or resumed and the user will be informed by a notification.
Settings
Tap menu.png to access the Settings.
Settings can be changed any time when the drone is not performing a mission. A detailed description of the available settings is described in Pix4Dscan - Settings.
Telemetry
The telemetry bar monitors some important characteristics of the flight.
drone_speed.png Drone speed. It shows the velocity at which the drone is flying.
distance_from_homepoint.png Horizontal distance from the home point. It shows the distance from the home point on the ground.
altitude.png Height relative to the take-off point.
Drone_to_point_of_interest_distance.png Drone to point of interest distance. Only available when the POI center has been defined.
Camera_azimuth_indicator.png Camera azimuth indicator. Only available for cell tower missions.
camera_angle.png Gimbal pitch. It shows the orientation of the camera.
  • If gimbal pitch = 0°, it means that the camera is looking forward.
  • If gimbal pitch = -90°, it means that the camera is looking nadir.
Return To Home
Tap go_home.png to make your drone return to the home point.
The PIX4Dscan return to home button can only be pressed when the drone is in the air and not performing a mission (mission has to be paused beforehand). After the Return to home button is pressed
Return To Home settings can be edited as explained in PIX4Dscan - Settings
Project creation
Tap on  add_mission.png to open the project creation window.
From this window, a new project can be created by selecting different missions. A project can contain a unique asset mission (e.g. cell tower) or multiple generic missions (e.g. orbit, cylinder, grid).
Information: Cell tower missions are only available under the Inspect - Telecom version. Contact sales for more information.
A new project with generic missions: orbit, cylinder and grid.New_project_with_orbit_cylinder_mission.png
Tap Cancel to leave the project selection window or Done to enter the project panel.
Project panel
The project panel displays the selected mission types and some high-level information (number of missions, mission completion status, media generated). A new mission can be created by selecting a mission type and tapping on Next. The cell tower project panel also includes the options to reset the cell tower references (cell tower lowest and highest points, cell tower center).
Project panel of generic missions (orbit, cylinder and grid)Project_view_full.PNG
The different steps for planning the individual mission are described below.
Vector.png Grid mission
The grid mission is meant to plan and fly polygonal mission shapes with a single grid flight pattern for 2D maps or a double grid flight pattern for 3D models. It is suitable for most environments that require flexible boundaries or complex mapping shapes and ensures that images are taken with the gimbal pitch and the overlap required for optimal processing.
How to position and design the mission
Once entering the grid mission, the default mission shape is displayed over the basemap at the current location.
Important: To facilitate the design of the mission, the properties panel (on the right side of the screen) is collapsable by tapping on the arrow beside the mission title.
The following actions can be performed.
  1. Move the survey area: the survey area can be displaced by tapping on the center cross and dragging the shape to a new location.
  2. Move a vertex: tap on a vertex and drag it to a new position to extend or reduce the survey area.
  3. Remove a vertex: two adjacent vertices can be merged by dragging one on top of the other one.
  4. Add a vertex: a vertex can be added by tapping on the “+” icon displayed over a segment.
  5. Rotate the flight lines: tap and rotate within the survey area to modify the direction of the flight lines.
Note: The reset mission button (top of the map view) allows the mission shape and location to be reset to the default one upon confirmation.
Note: The "how to design a grid mission onboarding guide" is automatically displayed the first time this grid mission is entered and is always accessible in the general settings of PIX4Dscan (Help - Onboarding guides - Grid mission).
Define the properties of the mission
Once entering the grid mission, the panel containing the properties is automatically displayed at the right side of the screen.
  • Mission information: estimations for the currently designed mission
    • Time: estimated duration of the mission execution
    • Area [m2, ft2]: area covered by the mission
    • GSD (ground sampling distance) [cm/pixel, inch/pixel]: distance between two consecutive pixel centers measured on the ground. The GSD depends on different parameters such as the camera specifications, the flight height and the camera angle.
  • Mission parameters
    • Flights pattern:
      • Use a single grid pattern to take images perpendicular to the ground (nadir), with the overlap required for optimal processing. Recommended in the following cases: main interest in 2D map outputs, relatively flat surface (e.g. earthworks, fields), large area.
      • Use a double grid pattern to take images from multiple sides (oblique), with the overlap required for optimal processing. Compared to the single grid, this pattern is recommended for flying closer to objects in order to capture more vertical details. Recommended in the following cases: main interest in 3D model outputs, surface with height fluctuations or objects (e.g. buildings, forest), small and medium area (flight time is doubled compared to single grid pattern).
  • Flight height [m, ft]: height of the mission in reference to the take-off location. The range is 10 - 150m.
  • Front overlap [%]: percentage of an image covered by the next one at the ground level with respect to the flight direction. The range is 20 - 90%.
  • Side overlap [%]: percentage of an image covered by an adjacent one (in adjacent flight line) at the ground level. The range is 20 - 90%.
  • Gimbal pitch [°]: pitch of the camera during the mission execution. The range is 0° - -90° (nadir).
  • Drone speed [m/s, mph]: speed of the drone during the mission execution. The maximum speed depends on the selected front overlap and flight height. The slider allows to select percentages (10% steps) of the maximum speed.
    Note: the restore button can be used to reset the settings to their default values.
Note: The restore button can be used to reset the settings to their default values.
To generate the best 2D and 3D outputs, we highly recommend using the default mission settings values according to the selected flight pattern:
Parameters Single grid Double grid
Front overlap 80% 80%
Side overlap 70% 70%
Gimbal pitch -90° -70°
orbit_mission_type.png Orbit mission
Define the point of interest center
An animated description will guide the user through the setting of the point of interest center.
  1. In manual mode, place the drone on top of the structure/tower.
  2. Ensuring that all the conditions below are satisfied, tap Set.
  • In the Flight view, the green target aims at the center of the structure/tower.
  • The gimbal pitch angle is -90° (looks nadir). To do so, use the controls or tap Set to -90°.
  • The height is higher than 10 m.
  • The GPS signal is strong enough. 6 satellites in view are at least needed to start the mission.
The following properties are editable on the right panel.
  • Light condition template selection: extremely sunny, mostly sunny, mostly cloudy, and extremely cloudy. Those are loading predefined recommended white balance and exposure value according to the weather conditions:  General recommendations for exposure value and white balance. When expanding that section, white balance and exposure value are also customizable.
  • White balance: it can be changed according to the weather conditions. White balance options are:
    • auto_white_balance.png Automatic: automatically optimizes the white balance.
    • weather_sunny.png Sunny: optimizes the white balance for sunny weather conditions.
    • weather_cloudy__1_.png Cloudy: optimizes the white balance for cloudy weather conditions.
  • Exposure value: exposure value compensation whose values range from -3 to 3.
  • Mission settings: a default value is applied to the following setting. When making edits to this value, tap Restore to replace the edited value with the default one.
  • Images per orbit: defines the number of images per orbit.
Rather than choosing parameters in the panel, values such as gimbal pitch, radius, and height are based on the drone telemetry, so from the current drone position, which is manually adjusted with the drone's controller.
  • Gimbal pitch: defines the pitch angle of the camera.
  • Radius: defines the radius length of the orbit.
  • Height: defines the height of the orbit.
Parameters Red values interval Orange values interval Green values interval
Gimbal pitch - -90-(-61)° / -29-90° -60-(-30)°
Radius 0-5 m 6-7 m From 8 m above
Height < 10 m 10-14 m From 15 m above
Important: Red values prevent the start of the mission. Orange values do not block the start of the mission but are not recommended values. Green ones fall in the interval of the suggested values.
Note: Changes to the radius value will be reflected in the estimate of the time needed to complete the mission, which can be read next to the mission type name.
Tap Start mission. The drone enters the In mission mode and the mission starts. An estimate of the time remaining until completion is displayed throughout the whole mission.
cylinder_mission_type.png Cylinder mission
The following properties are editable on the right panel:
  • Verticals: number of vertical lines for the mission.
  • Front overlap: define the image front overlap in the vertical line.
  • Minimum height: defines the minimum height the drone should fly the mission. The value should be at least 10 m lower than the maximum height.
    Tap Set to current to set the value to the current height of the drone.
  • Maximum height: defines the maximum height the drone should fly the mission. The value should be at least 10 m higher than the minimum height.
  • Point of interest height: defines the height value of the orbit.
  • Radius: defines the radius length of the orbit. The minimum value is 8 m.
Note: Changes to the above values will be reflected in the estimate of the time needed to complete the mission, which can be read next to the mission type name.
cell_tower.png Cell tower mission
  2. Ensuring that all the conditions below are satisfied, tap Next.
Define the point of interest height
An animated description will guide the user through the setting of the point of interest height.
  1. In manual mode, align the drone with the highest point of the tower.
  • In the Flight view, the green target aims at the top of the structure/tower.
  • The gimbal pitch angle is 0° (looks forward). To do so, use the controls or tap Set to 0°.
Fly sub-missions
Orbit, cylinder, single vertical line, and underneath orbit missions can be flown to efficiently scan cell towers and to successfully reconstruct the results. Detailed recommendations on how to scan cell towers can be found in How to scan cell towers.
In general, we recommend flying:
  • One orbit sub-mission per cluster of antennas.
  • One cylinder sub-mission with many verticals or many single vertical missions according to the type of tower.
  • One underneath orbit sub-mission per cluster of antennas.
The references that are set at the beginning of the Cell tower mission are used by default by all the sub-missions. Select one of the available sub-missions and tap Next.
After one type of sub-mission is completed, another type of sub-mission or another sub-mission of the same type can be performed.
Note: The point of interest center and height references can be reset if needed at the cell tower submission selection stage.
Orbit submission
The following property is editable on the right panel:
Rather than choosing parameters in the panel, values such as gimbal pitch, radius, and height are based on the video feed on the screen, so from the current drone position, which is manually adjusted with the drone's controller.
  • Gimbal pitch: defines the pitch angle of the camera. This angle must have a negative value.
  • Height: defines the height value of the orbit.
Tap Start mission. The drone enters the In mission mode and the sub-mission starts. An estimate of the time remaining until completion is displayed throughout the whole mission.
Cylinder submission
  • Minimum height: defines the minimum height the drone should fly the mission. The value should be at least 10 m lower than the maximum height, calculated as the point of interest height value + the radius.
  • Radius: defines the radius length of the orbit. The minimum and recommended value is 8 m. Tap Set to current to set the value to the current distance of the drone with respect to the tower centerline.
Note: The gimbal pitch varies during the flight and is controlled by the mission in order to take the most suitable acquisition set.
Single vertical submission
  • Radius: defines the distance between the POI center and the single vertical. The minimum and recommended value is 8 m. Tap Set to current to set the value to the current distance of the drone with respect to the tower centerline.
Underneath orbit submission
  • Gimbal pitch: defines the pitch angle of the camera. This angle must have a positive value.
Gimbal pitch - < 0° 0-90°
Pause, resume or cancel the mission
When in mission mode, the mission can be paused, resumed or canceled from the application.
  • Tap pause.png to pause the mission. After the mission is paused, the drone hovers and the manual mode is entered.
  • Tap play.png to resume the mission. The drone will perform the pre-flight checks and fly to the first waypoint that was not reached before clicking pause.
    Important:
    Cylinder mission: When resuming the mission, the drone will first vertically ascend to the safety altitude that is higher than the structure height and, only after that, it will move to the first waypoint that was not captured. The structure height is defined during mission planning.
    Orbits and single vertical: A warning popup is displayed at the mission resume. The drone will first ascend/descend directly to a height equal to the last reached waypoint, then fly towards it. To avoid collision risks, be sure there are no obstacles on the flight route.
  • Tapexit_mission.png to cancel the mission. A popup will ask for confirmation to cancel the mission. A canceled mission cannot be resumed.
Other ways of interrupting a mission are described in How to interrupt a PIX4Dscan mission.
2 out of 2 found this helpful
