Previous | Next |
Basemaps in PIX4Dfields
Change a basemap in PIX4Dfields
Use a custom basemap in PIX4Dfields
Supported arguments for a custom basemap in PIX4Dfields
To create a locally hosted tile web map service of an orthomosaic using python and QGIS
To add a custom Mapbox layer
Basemaps serve as a reference map on which projects are overlaid. PIX4Dfields provides several options for these maps. The Standard basemap option is a full global basemap with either Street or Satellite content provided by Mapbox. A custom basemap option is available to display customized content utilizing a tiled web map service. This service can be hosted locally or online.
Change a basemap in a PIX4Dfields project
- Open a project in PIX4Dfields.
- Click on Select basemap
- Select Custom, Satellite, Street, or None.
To add a custom basemap in PIX4Dfields
To add a custom basemap provider:
- In the Dashboard screen, click SETTINGS
- In the APP SETTINGS section, click Basemap.
- Select Your custom basemap.
- Type or paste the URL for the map service.
- Create a new project in PIX4Dfields.
- Click on Custom.
The table below describes the arguments supported on PIX4Dfields:
Arguments | Description |
{x} |
X position of tile |
{y} or {-y} | Y position of the tile, starting at the top/north. Use {-y} if the origin is at the bottom/south (TMS). |
{z} | Zoom |
{r} | Scale value. Can be used to add "@2x" to the URL to load retina tiles |
{q} | Quadtree |
{bbox4326} {bbox4326_latlon} {bbox4326_lonlat} {bbox3857} |
Bounding box coordinates for WMS Urls. If ‘latlon’ or ‘lonlat’ are not provided then order is determined by version, where < 1.3 uses lonlat |
{s} | Subdomains a,b,c. |
- Create a local server using python:
- Create a dedicated folder on the windows machine (e.g. “Local_Basemap”).
- Open a windows console and navigate to the folder “Local_Basemap”.
- Execute the following command: "C:\Program Files\QGIS 3.16\apps\Python37\python" -m http.server (check that the path to where python is installed is correct).
- The console will show the following message: Serving HTTP on 0.0.0.0 port 8000 (http://0.0.0.0:8000/) … The URL of the local server will be http://localhost:8000/
- Generate XYZ tiles from the orthomosaic that you want to use.
- Open QGIS and load the orthomosaic.
- Click Processing> Toolbox> Raster tools>Generate XYZ tiles (Directory)
- Fill in the following parameters as follows:
- Extent: the orthomosaic.
- Zoom level range: it depends on the ortho size, but 12-19 should be ok for all cases.
- Tile format: JPG.
- Output directory: save into the folder “Local_Basemap”.
- Output html: give a name and save it in the “Local_Basemap” folder (to test if the tiles were created correctly).
- Open PIX4Dfields and add the following URL http://localhost:8000/{z}/{x}/{y}.jpg in the custom basemap section.
It is possible to create custom basemaps in Mapbox that can be imported into PIX4Dfields as a tile web map service.
- In Mapbox Studio, navigate to Share & Develop.
- Under Developer resources, select Third party.
- PIX4Dfields will support either Carto or Fulcrum formats.
- Copy the Integration URL.
- Paste into Your custom basemap in the APP SETTINGS of PIX4Dfields.
How do you change the basemap in Pix4Dreact? An online search only has info on Pix4Dcapture.
