Notification message "Failed to authenticate. Could not authenticate. There was a network issue."
 Previous  |  Next
Error
Description
Cause
Solution
Error
Description
  • Error when logging in Pix4Dfields Desktop or ParrotFields.
  • Error when starting a trial period.
Cause
There is a proxy/antivirus/firewall on the PC that does not allow the application to validate the HTTPS certificate chain. As a result, communication with the Pix4D login server is impossible.
Solution
To solve the login problem, the user (or system admin) needs to add an exception to the proxy/antivirus/firewall for one of the following options:
Information: The exception should be either for all ports OR port 443 (HTTPS).
0 out of 0 found this helpful
