Previous | Next |
Error
"Failed to authenticate. Could not authenticate. There was a network issue."
Description
- Error when logging in PIX4Dfields Desktop or ParrotFields.
- Error when starting a trial period.
Cause
There is a proxy/antivirus/firewall on the PC that does not allow the application to validate the HTTPS certificate chain. As a result, communication with the PIX4D login server is impossible.
Solution
To solve the login problem, the user (or system admin) needs to add an exception to the proxy/antivirus/firewall for one of the following options:
- PIX4Dfields (Windows or macOS)
- All URLs with the form of "*.pix4d.com"
- URLs: cloud.pix4d.com, api.account.pix4d.com, auth.fields.pix4d.com
- The IPs:
- cloud.pix4d.com IP: 52.21.36.59
- api.account.pix4d.com IP: 52.73.176.255
- auth.fields.pix4d.com IP: 3.210.46.211
