Which cameras are supported in Pix4Dmatic
Pix4Dmatic can process images (.jpg or .jpeg format) taken from the aerial manned or unmanned platforms.
The acquisition angle of images should be nadir or slightly oblique (required: 0° - 45°; recommended: 10° - 35°).
Manufacturer Camera Syntax Compatibility (listed version and above)
DJI Mavic Pro FC220_4.7_4000x3000 Pix4Dmatic 1.0.1
Mavic 2 Pro L1D-20c_10.3_5472x3648 Pix4Dmatic 1.0.1
Phantom 3 Professional FC300X_3.6_4000x3000 Pix4Dmatic 1.0.1
Phantom 4 FC330_3.6_4000x3000 Pix4Dmatic 1.0.1
Phantom 4 Pro FC6310_8.8_4864x3684
FC6310_8.8_5472x3648
Pix4Dmatic 1.0.1
Phantom 4 Pro V2 FC6310S_8.8_4864x3648
FC6310S_8.8_5472x3648
Pix4Dmatic 1.0.1
Phantom 4 RTK FC6310R_8.8_5472x3648 Pix4Dmatic 1.0.1
Zenmuse X4S FC6510_8.8_5472x3648 Pix4Dmatic 1.0.1
Parrot Anafi Anafi_4.0_4608x3456
Anafi_4.0_5344x4016
Pix4Dmatic 1.0.1
senseFly  Aeria X senseFlyAeriaX_18.5_6000x4000 Pix4Dmatic 1.0.1
S.O.D.A. S.O.D.A._10.6_5472x3648 Pix4Dmatic 1.0.1
S.O.D.A. 3D S.O.D.A._10.6_5472x3648 Pix4Dmatic 1.0.1
S.O.D.A. Corridor S.O.D.A._10.6_5472x3648 Pix4Dmatic 1.0.1
Sony
Cyber-shot DSC-RX1RM2 DSC-RX1RM2_35.0_7952x5304 Pix4Dmatic 1.0.1
Cyber-shot DSC-WX220 DSC-WX220_4.4_4896x3672 Pix4Dmatic 1.0.1
UMC-R10C UMC-R10C_E15mmF4.5_15.0_5456x3632
UMC-R10C_E20mmF2.8_20.0_5456x3632
Pix4Dmatic 1.2.1
Apple iPad with Pix4Dcatch Apple_Pix4Dcatch.iPad8.9_1920x1440 Pix4Dmatic 1.6.0
Note: Pix4Dmatic automatically detects geolocation information in the EXIF of the images. Importing image geolocation using .csv or .txt files is currently not supported.
Important: For processing in Pix4Dmatic both image geolocation and orientation need to be written in the EXIF of images.
10 out of 15 found this helpful
22 comments
  • Jeongheon Seo
    My data was captured with DJI Phantom4pro. but message is "Camera not supported"
    What happen?
  • Blaž (Pix4D)
    Hi, the DJI Phantom 4 Pro camera is supported in Pix4Dmatic. It could be that you are using image resolution that is not supported.
    Could you double-check that you are using one of the following resolutions?
    • 4864x3684
    • 5472x3648
    Best,
  • Jeongheon Seo
    My picture is 7,677~9,428Mbyte/each.
  • Jeongheon Seo
    5472 X 3648 X 16M
  • Anrijs Strazdins
    I have the same problem - "Camera not supported"
    Phantom 4 RTK , 4864x3648 resolution
  • Arash Jedi
    Hi i have same problem with import Geotaged image by teokit
    "camera not supported " error
  • Michael Tucker
    I am having the same image with my Mavic Pro 2
  • f m
    Mavic Enterprise Zoom - camera not supportet by Pix4Dmatic - any suggestions when this camera will be supportet?
  • Pierangelo Rothenbühler
    We're working on an improvement that should enable you to import different resolutions for a supported camera model and import more cameras, as long as they have the required geotags (geolocation and IMU). We'll update the article as soon as it is ready. In the meantime, please continue posting the camera models that you'd like to see supported in the comments, that way we can prioritize them. Thank you.
  • Balint Vanek
    Dear Pierangelo,
    We created a dataset with sony a6400 images, xmp roll, pitch, yaw and exif lattitude, longitude, height above sea level: https://we.tl/t-RpUuOIPj65
    Please use it to add the camera model to the database of pix4dmatic!
  • Balint Vanek
    The second part of the dataset can be found here: https://we.tl/t-LBtgvvFmzx
    30 Gb total.
  • Balint Vanek
    Modified Skywalker EVE-2000, Sony a6400, Zeiss Ventum 21 mm (manual), 18 m/s airspeed, 263 m height above ground, 1/1250 s shutter speed, f 4.0, ~4.88 cm/pixel
  • Aaron Martinez
    DJI FC6310 5472x3078
  • OEM-reseller Sci.Aero
    Sony a6000 and all a7r variants.
  • Becca Fenwick
    Hi - we use the zenmuse X7 on DJI M210rtk as well as Micasense Rededge and Altum for our large mapping projects (500-7,000 acres) at 2-8cm resolution. It would be amazing if you supported these cameras! At the moment we have to process each flight (or part of a flight) separately. Hopefully we can start to use this soon!
  • Jeffrey Hill
    Very disappointing. Pix4Dmatic failed miserably.  I tried to add 2232 images and got the message 1895 Images FAILED TO LOAD. The odd thing is that 1423 of them were from my DJI Phantom 4 Pro and 809 of them from Canon 5DS R, so I'm not sure why only 348 images were loaded. Who knows why Pix doesn't support the Canon 5DS R. It's a top-rated photogrammetry camera.
    This is a link to my 3D model on SketchFab: https://skfb.ly/6VRuU of the image set I tried to load. It was made by RealityCapture by CaptureReality, only taking four days to process. I was hoping to compare your product to RealityCapture, but it seems that Pix isn't up for it.
  • Johannes
    We have a huge dataset from the oblique camera SHAREUAV PSDK102S - processing in pix4dMatic would be awesome.
  • edgardo Prado arce
    Hola.
    Tengo las imagnes tomadas con el Phantom 4 Pro, pero no las reconoce el PIX4DMATIC, podrian ayudarme?
  • Ys Wong
    Please add Sony A7R 36MP f=28mm. Thanks
  • Brigitte Kuhn
    Please add the Zenmuse x5
  • Benjamin Pille
    Hi,
    Unfortunately, The Sony A7RIII is not supported...
    Any chance this is added in the future?
    Thanks.
  • Sebastien Bilodeau
    Hi, is it possible to add the Sony 7RII, f5.6, 35mm lens to work in pix4d Matic? Thanks.
