Pix4Dreact release notes
 Previous  |  Next
Current version 1.1
1.1.0 February 18, 2020 New, bug fix
Version 1.1.0
New
  • Ability to switch language between English, German, Japanese and Spanish.
  • Import images by selecting a folder.
Improvements
  • RGB orthomosaics sometimes generated large files.
  • Tool buttons did not display with some screen resolutions.
  • Text did not show correctly on some computers.
  • App did not start for certain old graphic card drivers.
Versions 1.0
1.0.0 October 23, 2019 Initial release
1.0.1 December 3, 2019 New, bug fix
Version 1.0.0
Pix4Dreact is a new fast-mapping software built for emergency response and public safety. Pix4Dreact creates 2D maps from aerial imagery which provide up-to-date and reliable information in the field.
  • Fast and accurate maps while in the field.
  • Orthomosaic generation from drone images with no internet connection or cloud processing required (internet connection is only required during the first software activation).
  • Measurement and Marker tools.
  • Import and Export functionality.
  • PDF report for fast evaluation of the results and sharing with other stakeholders.
Version 1.0.1
New
  • Support for the DJI Mavic 2 Enterprise Dual drone (RGB only).
Note: This drone generates both a low and a high resolution version of each image. When importing the images in Pix4Dreact, a warning message will be displayed. This message appears, because Pix4Dreact does not support the processing of the low resolution images. Click PROCESS to continue and allow the software to process the high resolution images.
Improvements
  • Regular updates include stability and minor bug fixes.
0 out of 0 found this helpful
3 comments
  • marcelo martinez
    We downloaded the last version 1.01 and when we try to produce an orthomosaic with images captured with a Mavic Enterprise Duo , it is not possible to process them . A alert is shown alerting that the camera is not supported at this time . . Any help ?
  • Fernanda Bosmediano
    Hi Marcelo,
    Thank you for reaching out to us. Currently, Mavic 2 Enterprise Dual- RGB camera is supported. We do support this resolution (4056x3040). You can create a ticket for us, please send us your dataset with that we can be able to assist you in an effective way.
    Cheers
    Edited by Fernanda Bosmediano
  • eduardo ledesma
    Thank you Fernanda , today we tested the REACT with a image capture mission using a MAVIC Enterprise Duo ,  using the resolution you advise ( 4056x3040) and it works perfect ! ... Thanks a lot !
