Previous | Next |
Current Version 1.4.1
Version | Release date | Release type |
1.4.1 | December 15, 2021 | New, bug fix |
Version 1.4.1 |
New
- Support for DJI Mavic 2 Enterprise Advanced (RGB only)
Fix/Improvement
- Fixed an issue where the processed map looked blue for some GPU models under some conditions.
Version 1.4.0
1.4.0 | November 04, 2021 | New, bug fix |
Version 1.4.0 |
New
- Upload outputs (ortho, surface model) directly to PIX4Dcloud for sharing.
- GPU acceleration to reduce processing time.
- Now available in Ukrainian.
- Layer export menu with option to scale output size and option to include overviews for faster opening of the output in a third-party GIS solution.
- Export menu redesign.
Fix/Improvement
- Importing a project now displays a progress bar.
- Custom basemaps now display when exporting a snapshot or PDF report.
- Markers now correctly export the “name” value.
- Improved marker line measurement accuracy.
Versions 1.3.0
1.3.0 | April 21, 2021 | New, bug fix |
Version 1.3.0 |
New
- Customize the PDF report with your own logo and contact details.
- US National Grid map overlay with the ability to jump to a specific cell by either USNG code or GPS coordinates.
- Number of markers for each map visible on the dashboard.
- Now available in French, Italian, Korean and Russian.
- Redesigned menu for managing markers and the ability to import markers from a shapefile.
- Ability to switch the base map from within a project. Select either satellite, street, none or custom (when set).
Versions 1.2.0
1.2.0 | September 17, 2020 | New, bug fix |
Version 1.2.0 |
New
- Selectable color for markers (point, line, area).
- Improved look and feel of markers.
- Set a custom basemap via URL (tiled web map format).
- Export markers as shapefiles.
- Available on macOS (10.15 and above).
- Support for new cameras: Skydio 2.
- Additional languages: Chinese and Portuguese.
Fix/Improvement
- Increased maximum zoom level to support very high-resolution maps.
- JPEG (screenshot) export now correctly exports elevation model if selected.
- Improved PDF report export speed and stability.
Versions 1.1
1.1.3 | July 1st, 2020 | New, Known issues |
1.1.2 | May 28, 2020 | Bug fix |
1.1.1 | March 17, 2020 | Bug fix |
1.1.0 | February 18, 2020 | New, bug fix |
Version 1.1.3 |
New
- Support for Autel EVO II Pro camera
- Support for Autel EVO II Dual camera (RGB only)
- Support for DJI Zenmuse XT2 camera (RGB only)
Known issues
Exporting an elevation model as a screenshot gives as output the orthomosaic.
Version 1.1.2 |
New
- Support for Autel EVO I camera.
- Support for Autel EVO II 8K camera.
- Suppor for Zenmuse X7 (35mm lens) camera.
- Support for Parrot Anafi Thermal camera (RGB only).
Fix
- Essential update to allow continued functionality of the default basemap.
- Processing fixes and extended camera support.
Version 1.1.1 |
Improvements
- Login/logout not possible in some instances.
- Satellite basemap did not display in some instances.
Version 1.1.0 |
New
- Ability to switch language between English, German, Japanese and Spanish.
- Import images by selecting a folder.
Improvements
- RGB orthomosaics sometimes generated large files.
- Tool buttons did not display with some screen resolutions.
- Text did not show correctly on some computers.
- App did not start for certain old graphic card drivers.
Versions 1.0
1.0.0 | October 23, 2019 | Initial release |
1.0.1 | December 3, 2019 | New, bug fix |
Version 1.0.0 |
Pix4Dreact is a new fast-mapping software built for emergency response and public safety. Pix4Dreact creates 2D maps from aerial imagery which provide up-to-date and reliable information in the field.
- Fast and accurate maps while in the field.
- Orthomosaic generation from drone images with no internet connection or cloud processing required (internet connection is only required during the first software activation).
- Measurement and Marker tools.
- Import and Export functionality.
- PDF report for fast evaluation of the results and sharing with other stakeholders.
Version 1.0.1 |
New
- Support for the DJI Mavic 2 Enterprise Dual drone (RGB only).
Improvements
- Regular updates include stability and minor bug fixes.
We downloaded the last version 1.01 and when we try to produce an orthomosaic with images captured with a Mavic Enterprise Duo , it is not possible to process them . A alert is shown alerting that the camera is not supported at this time . . Any help ?
Hi Marcelo,
Thank you for reaching out to us. Currently, Mavic 2 Enterprise Dual- RGB camera is supported. We do support this resolution (4056x3040). You can create a ticket for us, please send us your dataset with that we can be able to assist you in an effective way.
Cheers
Thank you Fernanda , today we tested the REACT with a image capture mission using a MAVIC Enterprise Duo , using the resolution you advise ( 4056x3040) and it works perfect ! ... Thanks a lot !
When do you plan to support the Mavic 2 Enterprise Zoom. Our department has invested in both the Duo and the Zoom and would like to be able to deploy both of these to do this important task using React.
Larry
Hey Lawrence,
We currently do not have the Mavic 2 Enterprise Zoom in our database. However, when a RGB camera is not in our database, you can still process the images following the workflow in our article User-provided camera parameter file for Pix4Dreact. We will be in contact with you on the ticket that you submitted to Pix4Dsupport.
Kind regards,
Hi I like what is going on so far
