AutoGCPs detection functionality - PIX4Dcloud Advanced
This article explains how to include GCPs on PIX4Dcloud Advanced for their automatic detection.
Access: This feature is only available on PIX4Dcloud Advanced and when a 3D map or a 2D orthomosaic template is selected.
Image and GCP requirements
For the AutoGCPs detection algorithm to be successful, the following requirements regarding the images and the GCPs have to be met. Additional information and best practices are available at Automatic detection of targets - AutoGCP algorithm.
Image requirements
  • Image quality has to be good (blurry or low contrast images make the algorithm fail).
  • Images have to be geolocated (5-10 m accuracy is enough) in WGS84 (EPSG:4326).
  • Images have to be taken at nadir or slightly oblique angles.
GCP requirements
  • Squared, diagonal and Aeropoints targets are supported.
  • The recommended size is 20 times the average GSD of the project.
    Example: If the average GSD of the projects is 2.5 cm (1 inch), the recommended target size is 50 cm (20 inch).
  • Black and white targets are supported. Other colors may work in some circumstances.
  • GCPs must be placed at a distance of at least 10 m from each other.
  • GCPs must have a projected coordinate system whose definition is included at https://epsg.io.
Supported targets
Warning: If the AutoGCPs detection algorithm fails, the processing will run with no GCPs.
Upload the GCP file
  1. Follow the instructions to create a new dataset.
  2. Once at step 4. GCPs automation, select Upload file.
  3. Browse the CSV file which contains the GCPs' details and click Open.
  4. The GCPs are imported.
  5. (Optional) Click Replace file to upload a new GCP file.
  6. (Optional) Click delete.pngto delete the GCP file.
Important: The format of the file is described here.
  • First column (required): Label.
  • Second column (not required): Type (either GCP or CHECKPOINT with capital letters). The default value is GCP.
  • Third column (required): X coordinate.
  • Fourth column (required): Y coordinate.
  • Fifth column (required): Z coordinate.
  • Sixth column (not required): XY accuracy.
  • Seventh column (required if the sixth column is defined): Z accuracy.
Fields should be separated by commas and there should be no header. See the following example.
Example: File with 5 GCPs and 1 Check point in projected coordinates without accuracy values
001_,GCP,4392829.089,5386534.037,424.524
002_,GCP,4392772.823,5386545.0894,424.582
003_,GCP,4392732.981,5386516.197,424.723
004_,CHECKPOINT,4392761.505,5386468.789,422.646
005_,GCP,4392755.707,5386431.546,426.298
006_,GCP,4392832.252,5386456.906,427.001
Define the GCP coordinate system and target size
Once the CSV file is uploaded, specify the additional properties for the GCPs.
Important: Notice that only projected coordinate systems can be selected. If the GCPs are given in feet, the .prj file which defines the coordinate system must be also given in feet.
Warning: The output coordinate system and the GCPs coordinate system must be the same. In case the user selects a different coordinate system for the GCPs, the output coordinate system previously defined will be overwritten.
  • Diagonal target size: Specify the diagonal length of the targets in centimeters or inches.
Example: For AeroPoints, whose dimensions are 544mm (W) x 544mm (L) x 32mm (H), the correct diagonal length to give in input is 77 cm or 30 in.
See and edit the defined control points
Click See and edit control points to access the control points Table.
Control points Table
The Control points Table lists the imported control points and its properties.
  • Ensure that the imported coordinates are correct
  • (Optional) Change the Type of the control points by opening the dropdown menu and select GCP or Checkpoint
  • (Optional) If the values are inverted, easily swap Easting with Northing coordinates, by opening the dropdown menu available when clicking one of the two words in the table header.
Control points Map
By clicking Map, an OpenLayers map is displayed with the GCPs and Checkpoints.
  • Ensure that the control points are displayed at the expected locations. If this is not the case, the coordinate system and/or values have been incorrectly defined.
  • (Optional) Click on a point to switch from GCP to CP or the other way around.
  • (Optional) Click Save to save the changes.
Start processing
Click Process to conclude the dataset creation and to start uploading the input files for processing.
  • The dataset starts to be processed.
  • The AutoGCPs detection algorithm will run. In case the GCPs are not found, an email is sent to the user email address explaining that no GCPs were found and the processing will be done without using them.
  • When the process is finished, an email is sent and the Quality Report of the project is attached.
  • In the Files > GCPs section of the project, if the GCPs were detected by the algorithm, the details of the GCP marks will be shown.
AutoGCP report
An AutoGCP report (PDF) is also generated and available for download. This report shows the detected marks for each point and it is intended to be used to ensure the GCPs have been correctly marked automatically. More information on how to download this report in How to download results from PIX4Dcloud.
An example of report for AutoGCPs marking follows.
5 out of 5 found this helpful
4 comments
  • Rio Hondo GIS Program
    Would ground control points with labels for for this workflow?
  • Alice (Pix4D)
    Hi,
    They are not officially supported in Pix4Dcloud Advanced but they have been recognized in some test projects we made.
  • Seth Shank
    The instructions say "Once at step 3. GCPs automation, select Upload file.", but I do not see a button to press to upload a CSV file. Can you point out where it is?
  • Alice (Pix4D)
    Hi Lael, there was a mistake in the article, thank you for pointing this out. I have corrected it. The GCPs automation is the fourth and last step of the New dataset creation and, as the first Access message box says, it is only available for users having a Pix4Dcloud Advanced license. To use GCPs on the basic Pix4Dcloud, you can follow the instructions in this article. I would also recommend that you have a look at this article and contact us via ticket system if you have any questions.
