Keyboard shortcuts - PIXDsurvey
PIX4Dsurvey supports the use of shortcuts to expedite common operations and boost efficiency while performing certain tasks.
The following shortcuts are available:
General shortcuts
Edit
View
Window
Tools
Category Action Windows Mac Note
General shortcuts New project Ctrl + N ⌘ + N
Open project Ctrl + O ⌘ + O
Save project Ctrl + S ⌘ + S
Close project Ctrl + W or Ctrl + F4 ⌘ + W In the case of unsaved changes, an additional pop-up is displayed
Exit software Alt + F4 ⌘ + Q In the case of unsaved changes, an additional pop-up is displayed
Open the PIX4D Support website F1 ⌘ + ?
Edit Undo the previous action Ctrl + Z ⌘ + Z To reverse the last action(s)
Redo the previous action Ctrl + Y ⌘ + ⇧ + Z To reverse the last Undo(s). The function is only available after the Undo command
Invert selection Ctrl + Shift + I ⌘ + ⇧ + I To select all the elements that do not belong to the current selection
Delete the selected object Del, or backspace Del, or backspace An object needs to be selected
Accept edits Enter Enter Accept edits after adjusting the position of the vertex
Discard edits Esc Esc During the object vectorization and editing
Move to the next vertex Tab Tab Move to the next vertex in the selected geometry
Move to the previous vertex Shift + Tab Shift + Tab Move to the previous vertex in the selected geometry
View Hide all panels Ctrl + Shift + H ⌘ + ⇧ + H To close all panels and display only the 3D view
Hide image panel Ctrl + I ⌘ + I Toggle on and off the display of the image panel
Cameras Alt + C Option + C Toggle on/ off cameras. Only available when importing projects with calibrated camera positions
Orthographic view 5 5 Switch to orthographic view
Perspective view 6 6 Switch to perspective view
Zoom to fit all content Ctrl + 1 ⌘ + 1 The scene is zoomed out to the whole extent
Zoom to selection Ctrl + 2 ⌘ + 2 Zoom on the selected object
Top view 7 7 View from the top. The scene is zoomed out to the whole extent
Window Minimize Ctrl + M ⌘ + M To minimize PIX4Dsurvey
Show next tab Ctrl + Tab ⌃ + Tab To move to the next project in the project bar
Show previous tab Ctrl + Shift + Tab ⌃ + ⇧ + Tab To move to the previous project in the project bar
Tools Polyline L L Enable the Polyline tool
Marker M M Enable the Marker tool
Polygon A A Enable the Polygon tool
Catenary U U Enable the Catenary tool
Volume measurement V V Enable the Volume measurement tool
Assisted road marking R R Enable the Assisted road marking tool
Color selection Shift + C ⇧ + C Enable the Color selection tool
Single selection S S Enable the Single selection tool
Rectangle selection D D Enable the Rectangle selection tool
Rectangle selection - usage CTRL + left-click ⌘ + left-click Hold CTRL or ⌘ and draw a Rectangle selection
Polygon selection F F Enable the Polygon selection tool
Change selection mode W W To rotate between the Single, Rectangle, and Polygon selection when in selection mode.
Exit selection ESC ESC To unselect and to exit from Rectangle or Polygon back to Single selection.
Marker creation in the image viewer Shift + M ⇧ + M Add a marker on the selected image
3 out of 3 found this helpful
