Category |
Action |
Windows |
Mac |
Note |
General shortcuts |
New project |
Ctrl + N |
⌘ + N |
Open project |
Ctrl + O |
⌘ + O |
Save project |
Ctrl + S |
⌘ + S |
Close project |
Ctrl + W or Ctrl + F4 |
⌘ + W |
In the case of unsaved changes, an additional pop-up is displayed |
Exit software |
Alt + F4 |
⌘ + Q |
Open the PIX4D Support website |
F1 |
Edit |
Undo the previous action |
Ctrl + Z |
⌘ + Z |
Revert the last action(s) |
Redo the previous action |
Ctrl + Y or Ctrl + Shift + Z |
⌘ + ⇧ + Z |
Revert the last Undo(s). The function is only available after the Undo command |
Invert selection |
Ctrl + Shift + I |
⌘ + ⇧ + I |
To select all the elements that do not belong to the current selection |
Delete the selected object |
Del, or backspace |
Del, or backspace |
An object needs to be selected |
Accept edits |
Enter |
Enter |
Accept edits after adjusting the position of the vertex |
Discard edits |
Esc |
Esc |
During the object vectorization and editing |
Select next vertex |
Tab |
Tab |
Select the next vertex in the selected geometry |
Select previous vertex |
Shift + Tab |
Shift + Tab |
Select the previous vertex in the selected geometry |
View |
Hide all panels |
Ctrl + Shift + H |
⌘ + ⇧ + H |
To close all panels and display only the 3D view |
Hide image viewer |
Ctrl + I |
⌘ + I |
Toggle on and off the display of the image viewer |
Orthographic view |
5 |
5 |
Switch to orthographic view |
Perspective view |
6 |
6 |
Switch to perspective view |
Zoom to fit all content |
Ctrl + 1 or C |
⌘ + 1 |
The scene is zoomed out to the whole extent |
Zoom to selection |
Ctrl + 2 |
⌘ + 2 |
Zoom on the selected object |
Top view |
7 |
7 |
View from the top. The scene is zoomed out to the whole extent |
Window |
Minimize |
Ctrl + M |
⌘ + M |
To minimize PIX4Dsurvey |
Show next tab |
Ctrl + Tab |
⌃ + Tab |
To move to the next project in the project bar |
Show previous tab |
Ctrl + Shift + Tab |
⌃ + ⇧ + Tab |
To move to the previous project in the project bar |
Tools |
Polyline |
L |
L |
Enable the Polyline tool |
Marker |
M |
M |
Enable the Marker tool |
Polygon |
P |
P |
Enable the Polygon tool |
Catenary |
U |
U |
Enable the Catenary tool |
Circle |
C |
C |
Enable the Circle tool |
Volume measurement |
V |
V |
Enable the Volume measurement tool |
Assisted road marking |
Shift + R |
⇧ + R |
Enable the Assisted road marking tool |
Color selection |
Shift + C |
⇧ + C |
Enable the Color selection tool |
Road selection |
Shift + A |
⇧ + A |
Enable the Road selection tool |
Simple selection |
S |
S |
Enable the Simple selection tool |
Simple selection - how to draw the rectangle |
S and then Ctrl + mouse drag |
S and then ⌘ + mouse drag |
After enabling Simple selection (S), press Ctrl or ⌘ and click and drag the cursor over the area to select Release the mouse button to finish the selection |
Simple selection - how to draw the polygon |
S and then Ctrl + left-click |
S and then ⌘ + left-click |
After enabling simple selection (S), press Ctrl or ⌘ and click on the vertices of the polygon you want to draw to select |
Rectangle selection |
D |
D |
Enable the Rectangle selection tool |
Rectangle selection - how to draw the rectangle |
D and then left-click |
After enabling the Rectangle selection (D), press the left mouse button once, move the mouse to create a rectangle, left-click again to close the rectangle and confirm the selection |
Polygon selection |
F |
F |
Enable the Polygon selection tool |
Change selection mode |
W |
W |
To rotate between the Simple, Rectangle, and Polygon selection when in selection mode |
Exit selection |
ESC |
ESC |
To unselect and to exit from Rectangle or Polygon back to Simple selection |
Marker creation in the image viewer |
Shift + M |
⇧ + M |
Add a marker on the selected image |
Bookmark camera |
Ctrl + D |
⌘ + D |
Bookmark current view |
Stockpile detection |
Shift + S |
⇧ + S |
Enable the Stockpile detection tool |
Assign to class |
Ctrl + L |
⌘ + L |
To assign selected points to an ASPRS or Terrain class |
Other |
Change language |
F4 |
Cycle between available languages |
Reset onboarding |
F7 |
Sets all the onboarding as unseen making them again available again for review |
