How to import and export Tie Points marks - PIXDmatic
If Tie Points are marked in PIX4Dmatic or PIX4Dmapper project they can be exported and imported into a PIX4Dmatic project. This way it is not needed to mark them in the images again.
Marks file structure
The text file with Tie Points marks needs to contain the following:
  • Image name,
  • Tie Point name,
  • image coordinate x,
  • image coordinate y,
  • zoom level.
image_name,GCP1,3830.31,123.113,1.22678
Information: The image coordinate system has as origin the upper left part of the image. Its axes are oriented as shown in the image below:
How to export marks in PIX4Dmatic
How to export marks in PIX4Dmapper
Important: The following settings need to be applied for a seamless import into PIX4Dmatic:
  • File format: PIX4D marks files (*.txt, *.csv).
  • Marks' Zoom Level - unselected.
  • Image Directory - Selected.
  • Data Delimiter - Comma.
    Select the Image Directory and Data Delimiter - Comma.
How to import marks in PIX4Dmatic
2 out of 4 found this helpful
