Outputs - PIX4Dsurvey
Outputs of PIX4Dsurvey
PIX4Dsurvey can generate the following outputs which can be exported for use with third-party software:
Output Extension Description
Point clouds .las, .laz Point clouds according to selected input point clouds and selected terrain filter or ASPRS classes.
3D vectorized objects .dxf, .shp, .geojson, .zip (with .shp files) Polylines, catenaries, polygons, and markers. The placement of objects in layers is preserved.
Volume report .pdf, .html, .csv Detailed report of selected volumes.
Volume polygon .dxf, .shp, zip (with .shp files), geojson Base surface of the selected volumes.
3D Volume .xml (LandXML) Volume object (TIN of the volume).
Grid of points .dxf, .shp, geojson, .zip (with .shp files), .las, .laz Grid of points generated with the Grid of points algorithm.
TIN .xml (LandXML) TIN in LandXML format.
Contour lines .dxf, .shp, geojson, .zip (with .shp files) Contour lines generated with the Contour Lines algorithm. The placement of objects in layers is preserved.
Information: The actual coordinate values of exported geometries are in the coordinate system used in PIX4Dsurvey. When using the same coordinate system in PIX4Dsurvey and in third-party software, the outputs should automatically align.
Since the coordinate system is not directly defined in the .dxf format, an additional file (.prj) containing the coordinate system definition is automatically created. The .prj file can be used as a reference whenever additional information about the .dxf's coordinate system is needed.
Tip: It is possible to export outputs in a single .zip file that contains .shp, .shx, .dbf, and .prj files. Some third-party software support importing a single .zip file that contains multiple files instead of importing each file individually.
3 out of 3 found this helpful
2 comments
  • alonso estrada
    how export to autocad?
  • Kapil (Pix4D)
    Hello,
    For more information on using the outputs of Pix4D products on third-party software such as AutoCAD, I would recommend you to go through our support article on How to import Pix4D outputs to Autodesk.
    Regards,
