Outputs of PIX4Dsurvey
PIX4Dsurvey can generate the following outputs which can be exported for use with third-party software:
Output | Extension | Description |
Point clouds | .las, .laz | Point clouds according to selected input point clouds and selected terrain filter or ASPRS classes. |
3D vectorized objects | .dxf, .shp, .geojson, .zip (with .shp files) | Polylines, catenaries, polygons, and markers. The placement of objects in layers is preserved. |
Volume report | .pdf, .html, .csv | Detailed report of selected volumes. |
Volume polygon | .dxf, .shp, zip (with .shp files), geojson | Base surface of the selected volumes. |
3D Volume | .xml (LandXML) | Volume object (TIN of the volume). |
Grid of points | .dxf, .shp, geojson, .zip (with .shp files), .las, .laz | Grid of points generated with the Grid of points algorithm. |
TIN | .xml (LandXML) | TIN in LandXML format. |
Contour lines | .dxf, .shp, geojson, .zip (with .shp files) | Contour lines generated with the Contour Lines algorithm. The placement of objects in layers is preserved. |
how export to autocad?
Hello,
For more information on using the outputs of Pix4D products on third-party software such as AutoCAD, I would recommend you to go through our support article on How to import Pix4D outputs to Autodesk.
Regards,
