Previous | Next |
Outputs of Pix4Dsurvey
Pix4Dsurvey can generate the following outputs which can be exported for use with third-party software:
Output | Extension | Description |
3D vectorized objects | .dxf, .shp, .zip (with .shp files) | Polylines, catenaries, polygons, and markers. The placement of objects in layers is preserved. |
Grid of points | .dxf, .shp, .zip (with .shp files) | Grid of points generated with the Grid of points algorithm. |
TIN | .xml | TIN in LandXML format. |
how export to autocad?
Hello,
For more information on using the outputs of Pix4D products on third-party software such as AutoCAD, I would recommend you to go through our support article on How to import Pix4D outputs to Autodesk.
Regards,
