How to create a map
 Previous  |  Next
New map
To create a new map:
1. On the dashboard, click add.png at the bottom right corner of the window.
2. On the left side, click IMPORT IMAGES.
3. On the pop-up Open, select the images and click Open.
4. (optional) Adjust the Processing options by clicking the settings icon (mceclip1.png). For more information, see Processing options.
5. Click START PROCESSING at the bottom left corner of the window.
Open map
To open an existing map:
1. On the dashboard, all the maps created with this account will be visible.
2. Click on the desired map.
Open previously created orthomosaic
To open an orthomosaic which was created beforehand:
1. On the dashboard, click mceclip0.png at the bottom right corner of the window.
2. On the left side, click IMPORT GEOTIFF to open an existing orthomosaic.
Example projects
Explore Pix4Dreact’s functionalities by downloading example projects.
For more information, see Pix4Dreact example dataset.
2 out of 2 found this helpful
