Previous | Next |
Download
To download the software:
1. Go to the download page.
2. Download Pix4DReact for Windows or macOS.
Installation on macOS
Once the software has been downloaded, install it using the following steps:
1. Double-click the downloaded file.
2. Drag and drop the Pix4Dreact logo into Applications.
3. Navigate to Finder and click on the tab Applications.
4. Double-click Pix4Dreact to run the program.
5. (optional) If the pop-up appears, click Open.
Installation on Windows
1. Double-click the downloaded file. The Pix4Dreact Setup wizard starts.
2. (optional) If the Open file - Security Warning pop-up appears, click Run anyway.
3. In the Pix4Dreact Setup pop-up, click Next.
4. Read and agree to the End-User License Agreement to continue the installation. Click Next.
5. (optional) Click Change... to modify the destination path for installation and click Next.
6. Click Install.
7. (optional) In the software information window: "Do you want to allow the following program to install software on this computer?", click Yes.
8. Click Finish.
9. A shortcut is created on your desktop once the installation is completed.
Wonderful information, I am trouble with download but your article help me a lot to download some file like (open apk file). thanks for sharing with us.
Hi,
Could you please send us a technical request by contacting us here: https://support.pix4d.com/hc/en-us
Best,
Teodora
We just received our License for 4Dreact. Before I do an install, What is the process to transfer the license to another computer? Is it a simple uninstall and reinstall or do we have to take other steps?
Hi Eric,
For privacy reasons, we would kindly ask you to send us a technical request here: https://support.pix4d.com/hc/en-us
Best,
Teodora
From kevin@rmtroof.com
Kevin O'Connell
Received instructions from Autel for the EVO II Dual Rugged Bundle. Filled in the formstack screen with the proper serial # with an indication that the input was successful. Downloaded the software after registering. All I see is the trial version with the screen for payment processing. No screen for inputting the 8 digit key found on the license certificate. Need some help. Thanks.
Hi Kevin,
In the license certificate that you received, there is a section called Activation Instructions including a URL that you need to click to enter the license key. Have you done this?
If this gave you problems, please contact us here and send us the License Certificate you received so that we can further investigate what is wrong. I apologize for the inconvenience.
https://support.pix4d.com/hc/en-us/articles/360033726111/comments/360009007432 Among us mods for all of the people but only me
