Previous | Next |
Pix4Dsurvey allows you to vectorize point clouds made with Pix4Dmapper, Pix4Dmatic, laser scanners, LiDAR or other third-party tools and to assign the objects to layers. You can precisely define the position of the geometry by using original images or the vertex editor.
Vectorization tools in Pix4Dsurvey
How to use vectorization tools in Pix4Dsurvey
Editing geometry in the 3D view
Editing geometry on images
Editing geometry with vertex editor
The following tools are available:
Simple selection (default).
Rectangular selection
Polyline.
Marker.
Polygon.
Catenary.
Vectorization tools specifics:
- Simple selection (default): Click on the object to select it. Right-click on the object to use Move to layer or Delete geometry options.
- Rectangular selection: Hold down Ctrl to freeze the screen and select the points in the point cloud. Right-click on the selected points to use Recycle, and Assign to options.
- Polyline: Minimum two points need to be clicked in the 3D view to define a polyline.
- Marker: Click on a point in the 3D view to create a marker.
- Polygon: Minimum three points need to be clicked in the 3D view to define a polygon.
- Catenary: For vectorization of freely hanging power lines, chains and ropes. Minimum three points need to be clicked in the 3D view.
To use the vectorization tools:
- Select the tool on the toolbar.
- Left-click on the point cloud in the 3D view to create the first vertex and to start the vectorization.
- Continue using left-click to add more vertices to the geometry.
- (Optional) Press the Esc key to cancel the vectorization.
- To finish the geometry:
- Either Right-click in the 3D view to add the last vertex and to finish the geometry.
- Or press Enter to accept the edits and to finish the geometry.
- (Optional) Right-click again to exit the vectorization tool and to change to
To move the vertex in the 3D view:
- Use the Simple selection tool to click on an object.
- Click on the existing geometry.
- Click on the vertex and drag it to the new position.
After moving the vertex to the new position, the edits are automatically taken into account and you can continue creating new geometries or edit existing ones.
To add a vertex to existing geometry:
- Hover over the section where you would like to add the vertex.
- Click to create a new vertex.
To remove a vertex from existing geometry:
- Click on the vertex and press the Delete key.
To split the polyline
- Right-click on the vertex where you would like to split the polyline.
- Click Split polyline.
After the polyline is split, two separate polylines are created. The polylines share the vertex in which they were split.
To move the vertex on the images:
- Click on the vertex on the image and drag it to the new position on at least two images.
- Click Ctrl + Enter to accept the edits.
- (Optional) Hit the Esc key to cancel the edit.
After moving the vertex to the new position on at least two images, the position of the vertex is automatically changed and updated.
It is possible to manually adjust the coordinates of created vertexes.
To move the vertex using the vertex editor:
- Click on the vertex. The dialog Coordinates opens in the bottom left corner of the screen.
- Edit the coordinate values by:
- Typing the new coordinate values.
- Adjusting the coordinate values with the +/- button.
I like the simplicity of adding geometry. I'm testing it on the example dataset. Is there a way to delete a vertex without deleting the geometry?
Hi Aaron, great to hear you are trying out Pix4Dsurvey.
To delete an individual vertex you can:
Best,
I am really enjoying this product. Is there a way to create an arc on pavement areas and curbs?
Hi,
At the moment, the tool that would create an arc based on a few clicked points is not implemented in Pix4Dsurvey. But the idea is interesting, and we will consider it for future releases.
Feel free to also check the Pix4Dsurvey Feature request post to add more suggestions.
Best,
Hola,
Como logro realizar que mi polígono abarque la superficie seleccionada y no sea solo en 2d.
Saludos.
Hi Manuel,
The polyline is defined by the 3D vertices that you click on the model. The polyline will connect the defined vertices but will not exactly follow the terrain as in the case of cross-sections.
Could you tell me more about why would you find it beneficial for the polyline to follow the terrain?
Best,
Hola Blaz,
Gracias por contestar.
Me resultara beneficioso ya que obtendría la superficie dentro del polígono, para comparar superficies de vuelos semanales y obtener volúmenes entre superficies.
