Inputs - PIX4Dsurvey
Inputs
PIX4Dsurvey allows the import of PIX4Dmapper and PIX4Dmatic projects, vector files, as well as external point clouds.
Extension
Description
.dxf
.dxf files with 2D and 3D objects. You can learn more on the Project Management > Import vector files page.
.shp
.shp files with 2D and 3D objects. You can learn more on the Project Management > Import vector files page.
.geojson, .json
GeoJSON files with 2D and 3D objects. You can learn more on the Project Management > Import vector files page.
.las, .laz
Point clouds made with PIX4Dmapper, PIX4Dmatic, laser scanners, LiDAR, or other third-party tools. You can learn more on the Project Management > Import point clouds page.
Version 1.4 and lower are supported.
.txt, .csv, .xyz
Surveyor text files for marker creation. You can learn more on the Import surveyor text files page.
.p4d
PIX4Dmapper project file
Created with PIX4Dmapper version 3.0.17 and higher
.p4m
PIX4Dmatic project file
Created with PIX4Dmatic version 1.0.1 and higher
.p4s
PIX4Dsurvey project file
Note: Imported text files or vector files always show up at the top of the layer list.
