What is Pix4Dsurvey?
What is the difference between Pix4Dsurvey, Pix4Dmapper, and Pix4Dmatic?
Can Pix4Dsurvey process data?
What is the difference between Pix4Dsurvey and CAD software?
Can Pix4Dsurvey replace the CAD products I typically use?
Can I import the vectorized data into CAD software?
Do I have access to Pix4Dsurvey if I other Pix4D licenses?
How do I try Pix4Dsurvey?
How can I download Pix4Dsurvey?
What hardware specifications do you need to run Pix4Dsurvey?
How much does Pix4Dsurvey cost?
How many computers can be bound to the same account?
Does Pix4Dsurvey run on the cloud or locally?
Can I use Pix4Dsurvey with no internet connection?
What are the inputs and outputs of Pix4Dsurvey?
What is the default coordinate system in Pix4Dsurvey?
What to do if "Las coordinate system unknown" error appears?
What is the largest point cloud I can import into Pix4Dsurvey?
Where can I submit the product feedback and feature requests?
Pix4Dsurvey bridges the gap between photogrammetry and CAD. It does so by providing access to the original images and the point cloud through Pix4D’s rayCloud™ to vectorize and extract points, polylines, polygons and catenaries for a shorter time to delivery. Additionally, Pix4Dsurvey supports very large datasets or a combination of many datasets with an optimal experience.
The software expands today’s possibilities by enabling the combination of photogrammetry and third party point clouds such as terrestrial laser scanners.
What is the difference between Pix4Dsurvey, Pix4Dmapper and Pix4Dmatic?
The main difference is that Pix4Dmapper and Pix4Dmatic are primarily a photogrammetry processing software while Pix4Dsurvey is a tool for vectorization of geospatial data.
Together they cover the complete workflow for transforming the acquired information (images, point clouds) to a deliverable suitable for CAD or GIS software.
Pix4Dsurvey does not calibrate the photogrammetric projects or generate dense point clouds. This is done by photogrammetric software Pix4Dmapper and Pix4Dmatic.
On the other hand, it is possible to post-process dense point clouds in Pix4Dsurvey by running Terrain filter and Grid of points processes.
The main difference is that Pix4Dsurvey supports the seamless import of Pix4D projects with accurate results and images.
Unlike CAD software with its focus on design, Pix4Dsurvey provides vectorization and extraction tools and is optimized for handling and manipulation of very large datasets and point clouds.
No. Pix4Dsurvey makes it easier to move from photogrammetry to your CAD product.
Yes, Pix4Dsurvey exports vectorized data that can be seamlessly imported into CAD or GIS software using .dxf and .shp format.
Pix4Dsurvey is not included in the Pix4Dmapper or Pix4Dmatic license. You can purchase it separately on the Pix4D online store.
Every Pix4D account comes with a trial of Pix4Dsurvey.
The latest release of Pix4Dsurvey is available on the Pix4D download page.
Pix4Dsurvey runs on both Mac and Windows.
This article covers Pix4Dsurvey’s minimum and recommended hardware specifications.
Pricing plans of the product are available on the Pix4D online store.
Each Pix4Dsurvey license is paired with a Pix4D account. It can run on one computer at a time, but the license is floating and can be used on any computer.
Pix4Dsurvey is a desktop-only application that runs locally on Windows or Mac.
Not today, but this is planned for future releases.
For now, the internet connection is required for the first login.
Pix4Dsurvey allows the import of Pix4Dmapper and Pix4Dmatic projects, as well as independent .las or .laz files. The full list of input files is available in this article.
The main output of Pix4Dsurvey are .dxf and .shp files that can be seamlessly imported in CAD or GIS software.
While Pix4Dsurvey requires a projected coordinate system, there is no default system. When Pix4Dmapper project is imported, Pix4Dsurvey will use the coordinate system defined in the Pix4Dmapper project file.
When importing an external point cloud the coordinate system information needs to be written in the .las file.
If you are trying to import the external point cloud in an existing project that was previously created using the Pix4Dmapper project, then the import is still possible. Just make sure that the coordinates of the external point cloud are in the same coordinate system as specified in the Pix4Dmapper project.
If you are importing an external point cloud in an empty project, then you need to make sure the coordinate system is written directly in the .las file.
You tell us! What you can process depends on your system resources, but we’ve successfully tested single file imports of 1.8 billion points on laptops, and more than 4 billion points in total.
Help us understand what you need most by sharing your use case and upvote other users' feedback on the Pix4D community.
سلام وقت بخیر حقیقت زبان انگلیسی مسلط نیستم لطفا به زبان فارسی ترجمه کنید ممنون فعلا از برنامه استفاده نکردم نمیدونم کیفیتش چطوری هست
Hi Amir,
Pix4Dsurvey is currently only in English. Feel free to download our product and start testing it! Let us know if you have any questions.
Cordial saludo
Estoy utilizando PIX4D Survey para organizar la nube de puntos pero cuando lo importo no se ve la nube de puntos esto por que puede pasar?
Hi Sara,
It is possible to increase the Point Size in the Pix4Dsurvey menu:
Best,
