Example datasets - PIX4Dfields
 Previous  |  Next
Get started with real data
Download any of these projects for free and explore PIX4D’s desktop functionalities with a real dataset.
Important: These datasets may only be used for personal or professional training. For commercial or promotional use, “Courtesy of PIX4D / pix4d.com” must be displayed and all the text linked to pix4d.com. For more information on usage, contact our marketing team.
Using real data demonstrates what PIX4Dfields software can do and will help you understand what is needed when collecting your own data.
Not sure where to begin?  Follow the instructions below each data set to create your first project.
LOGO_KB_Demo_Projects_Fields.pngPIX4Dfields example projects
Rostock Sequoia multispectral download dataset
The goal of this project is to obtain an NDVI index map of a field using the Sequoia camera that captures Green, Red, Red edge and NIR wavelengths.
General project information
Project
Location Germany
Average Ground Sampling Distance (GSD) 10.0 cm / 3.94 in
Area covered 0.449 km2 / 44.9 ha / 0.173 sq. mi. / 110.95 acres
Output coordinate system WGS84 / local Transverse Mercator
Image acquisition
UAV eBee (senseFly)
Image acquisition plan 1 flight, grid flight plan, 106 meters flight height
Camera Sequoia (Green, Red, Red edge, NIR)
Images
Number of images 1804
Image size 1280x960
Image geolocation coordinate system WGS84
Download project files
The dataset can be downloaded here.
  • Images: Red, Green, Red edge and NIR images in TIFF format.
  • Boundary: project file that can be opened in PIX4Dfields.
Start a new project in PIX4Dfields
To begin processing the dataset, follow the guide A project step-by-step.
Rostock S.O.D.A. RGB camera download dataset
The goal of this project is to obtain a VARI index map of a field using the S.O.D.A camera that captures Red, Green, Blue wavelengths.
Project
Location Germany
Average Ground Sampling Distance (GSD) 2.80 cm / 1.10 in
Area covered 0.483 km2 / 48.3 ha / 0.186 sq. mi. / 119.35 acres
Image acquisition
UAV eBee (senseFly)
Image acquisition plan 1 flight, grid flight plan, 119 meters flight height
Camera S.O.D.A. (Red, Green, Blue)
Images
Number of images 374
Image size 5472x3648
  • Images: Red, Green, Blue images in JPG format.
10 out of 14 found this helpful
3 comments
  • surasak pangmo
    good
  • Gezahagn Seboka
    I' m interested to learn about Pix4D together with drone application in agriculture. I work for Ethiopian Sugar Corporation.
  • Fernanda Bosmediano
    Hi,
    Happy to read about your interest in learning about our solutions. We have different materials that can help you to get familiarized with Pix4Dfields.  Please have a look here:  https://www.pix4d.com/product/pix4dfields. You will find use cases from our users, links to our knowledge base, and FAQ.
    Also, we have many webinars as well that I would recommend watching as we share how the software works. Still, we also give some examples of real applications that will help you to start learning about drone imagery in agriculture. https://www.pix4d.com/webinars-and-ebooks
    For further questions you can contact our sales team: https://www.pix4d.com/contact
    Sincerely,
    Edited by Fernanda Bosmediano
