Example use cases - PIX4Dfields
 Previous  |  Next
Get started with real data
Using real data demonstrates what PIX4Dfields software can do and will help you understand what is needed when collecting your own data.
Register for a 15-day trial license and download any of these example use cases for free to explore PIX4Dfields functionalities with real data. Not sure where to begin? Follow the instructions below to create your first project.
LOGO_KB_Demo_Projects_Fields.pngPIX4Dfields example projects
PIX4Dfields projects are ready to be opened without the need for processing the images. Once the .zip is downloaded, and PIX4Dfields is closed, double-click on the .p4f file, it will automatically open PIX4Dfields and import the project.
Detecting weed in a wheat field download project
The goal of this project is to detect weeds in a winter wheat field with the help of the Magic Tool.
General project information
Average Ground Sampling Distance (GSD) 11.5 cm / 4.52 in
Area covered 8.6 ha / 21.25 acres
Image acquisition plan 1 flight, grid flight plan.
Camera RGB
Measuring lodging (wind damage) in a wheat field  download project
The goal of this project is to detect lodging in a winter wheat field with the help of the Magic Tool.
Average Ground Sampling Distance (GSD) 3.53 cm / 1.39 in
Area covered 13 ha / 32 acres
Camera RGB
Detecting weed on fallowdownload project
The goal of this project is to detect weeds on fallow with the help of the Magic Tool.
Average Ground Sampling Distance (GSD) 1 cm / 0.40 in
Area covered 1 ha / 0.47 acres
Camera RGB
Measuring affected flooded corn download project
The goal of this project is to calculate the area of flooded corn. It also serves as a comparison between drone images and satellite images.
Project
Average Ground Sampling Distance (GSD) Drone: 12.4 cm / 4.88 in
Satellite: 10 mts / 393 in
Area covered 61 ha / 150acres
Camera Multispectral
LOGO_KB_Demo_Projects_Fields.pngPIX4Dfields example datasets
Datasets are the raw images taken by the drone. Once dataset is downloaded, process the dataset following  A project step-by-step.
Variable rate nitrogen fertilization in wheat download dataset
The goal of this project is to obtain an NDVI index map of a field using the Sequoia camera that captures Green, Red, Red edge and NIR wavelengths.
Project
Location Germany
Average Ground Sampling Distance (GSD) 10.0 cm / 3.94 in
Area covered 0.449 km2 / 44.9 ha / 0.173 sq. mi. / 110.95 acres
Output coordinate system WGS84 / local Transverse Mercator
Image acquisition
UAV eBee (senseFly)
Image acquisition plan 1 flight, grid flight plan, 106 meters flight height
Camera Sequoia (Green, Red, Red edge, NIR)
Images
Number of images 1804
Image size 1280x960
Image geolocation coordinate system WGS84
Download project files
The dataset can be downloaded here.
  • Images: Red, Green, Red edge and NIR images in TIFF format.
  • Boundary: project file that can be opened in PIX4Dfields.
Start a new project in PIX4Dfields
To begin processing the dataset, follow the guide A project step-by-step.
RGB dataset of wheat download dataset
The goal of this project is to obtain a VARI index map of a field using the S.O.D.A camera that captures Red, Green, Blue wavelengths.
Project
Location Germany
Average Ground Sampling Distance (GSD) 2.80 cm / 1.10 in
Area covered 0.483 km2 / 48.3 ha / 0.186 sq. mi. / 119.35 acres
Image acquisition
UAV eBee (senseFly)
Image acquisition plan 1 flight, grid flight plan, 119 meters flight height
Camera S.O.D.A. (Red, Green, Blue)
Images
Number of images 374
Image size 5472x3648
  • Images: Red, Green, Blue images in JPG format.
Important: These datasets may only be used for personal or professional training. For commercial or promotional use, “Courtesy of PIX4D / pix4d.com” must be displayed and all the text linked to pix4d.com. For more information on usage, contact our marketing team.
13 out of 17 found this helpful
3 comments
  • surasak pangmo
    good
  • Gezahagn Seboka
    I' m interested to learn about Pix4D together with drone application in agriculture. I work for Ethiopian Sugar Corporation.
  • Fernanda Bosmediano
    Hi,
    Happy to read about your interest in learning about our solutions. We have different materials that can help you to get familiarized with Pix4Dfields.  Please have a look here:  https://www.pix4d.com/product/pix4dfields. You will find use cases from our users, links to our knowledge base, and FAQ.
    Also, we have many webinars as well that I would recommend watching as we share how the software works. Still, we also give some examples of real applications that will help you to start learning about drone imagery in agriculture. https://www.pix4d.com/webinars-and-ebooks
    For further questions you can contact our sales team: https://www.pix4d.com/contact
    Sincerely,
    Edited by Fernanda Bosmediano
