Get started with real data
Using real data demonstrates what PIX4Dfields software can do and will help you understand what is needed when collecting your own data.
Register for a 15-day trial license and download any of these example use cases for free to explore PIX4Dfields functionalities with real data. Not sure where to begin? Follow the instructions below to create your first project.
PIX4Dfields example projects
PIX4Dfields projects are ready to be opened without the need for processing the images. Once the .zip is downloaded, and PIX4Dfields is closed, double-click on the .p4f file, it will automatically open PIX4Dfields and import the project.
The goal of this project is to detect weeds in a winter wheat field with the help of the Magic Tool. |
General project information |
Average Ground Sampling Distance (GSD) |
11.5 cm / 4.52 in |
Area covered |
8.6 ha / 21.25 acres |
Image acquisition plan |
1 flight, grid flight plan. |
Camera |
RGB |
The goal of this project is to detect lodging in a winter wheat field with the help of the Magic Tool. |
3.53 cm / 1.39 in |
Area covered |
13 ha / 32 acres |
Camera |
RGB |
The goal of this project is to detect weeds on fallow with the help of the Magic Tool. |
1 cm / 0.40 in |
Area covered |
1 ha / 0.47 acres |
Camera |
RGB |
The goal of this project is to calculate the area of flooded corn. It also serves as a comparison between drone images and satellite images. |
Project |
Drone: 12.4 cm / 4.88 in Satellite: 10 mts / 393 in |
Area covered |
61 ha / 150acres |
Camera |
Multispectral |
PIX4Dfields example datasets
Datasets are the raw images taken by the drone. Once dataset is downloaded, process the dataset following A project step-by-step.
The goal of this project is to obtain an NDVI index map of a field using the Sequoia camera that captures Green, Red, Red edge and NIR wavelengths. |
Project |
Location |
Germany |
10.0 cm / 3.94 in |
Area covered |
0.449 km2 / 44.9 ha / 0.173 sq. mi. / 110.95 acres |
Output coordinate system |
WGS84 / local Transverse Mercator |
Image acquisition |
UAV |
eBee (senseFly) |
1 flight, grid flight plan, 106 meters flight height |
Camera |
Sequoia (Green, Red, Red edge, NIR) |
Images |
Number of images |
1804 |
Image size |
1280x960 |
Image geolocation coordinate system |
WGS84 |
Download project files |
The dataset can be downloaded here.
- Images: Red, Green, Red edge and NIR images in TIFF format.
- Boundary: project file that can be opened in PIX4Dfields.
Start a new project in PIX4Dfields
To begin processing the dataset, follow the guide A project step-by-step. |
The goal of this project is to obtain a VARI index map of a field using the S.O.D.A camera that captures Red, Green, Blue wavelengths. |
Project |
Location |
Germany |
2.80 cm / 1.10 in |
Area covered |
0.483 km2 / 48.3 ha / 0.186 sq. mi. / 119.35 acres |
Image acquisition |
UAV |
eBee (senseFly) |
1 flight, grid flight plan, 119 meters flight height |
Camera |
S.O.D.A. (Red, Green, Blue) |
Images |
Number of images |
374 |
Image size |
5472x3648 |
WGS84 |
- Images: Red, Green, Blue images in JPG format.
Important: These datasets may only be used for personal or professional training. For commercial or promotional use, “Courtesy of PIX4D / pix4d.com” must be displayed and all the text linked to pix4d.com. For more information on usage,
contact our marketing team.
good
I' m interested to learn about Pix4D together with drone application in agriculture. I work for Ethiopian Sugar Corporation.
Hi,
Happy to read about your interest in learning about our solutions. We have different materials that can help you to get familiarized with Pix4Dfields. Please have a look here: https://www.pix4d.com/product/pix4dfields. You will find use cases from our users, links to our knowledge base, and FAQ.
Also, we have many webinars as well that I would recommend watching as we share how the software works. Still, we also give some examples of real applications that will help you to start learning about drone imagery in agriculture. https://www.pix4d.com/webinars-and-ebooks
For further questions you can contact our sales team: https://www.pix4d.com/contact
Sincerely,
