What is the viDoc RTK rover?
How to use the Pix4Dcatch with viDoc RTK rover?
What are the recommended devices?
How are the images captured in Pix4Dcatch synchronized with the viDoc RTK rover?
How are the orientations of images set when using Pix4Dcatch+viDoc RTK rover?
Is the offset between the rover's antenna and the camera taken into account?
Can I generate a 3D model or 2D map in a coordinate reference system of my choice using Pix4Dcatch+viDoc?
What is the height reference of the geolocated images and how can I change it?
Will tilting the device during data acquisition have an impact on the accuracy of the 3D models?
How precisely is the RTK trajectory synchronized with the images?
Can viDoc RTK rover for Pix4Dcatch be used without an internet connection?
Can I do PPK or use my own base station?
Can I accurately acquire data with Pix4Dcatch + viDoc RTK rover over time?
Can I combine RTK drone data and terrestrial Pix4Dcatch + viDoc mobile phone data?
How can I purchase the viDoc RTK Rover
How can I get technical support for viDoc RTK rover?
Which geoids are compatible with PIX4Dcatch and the viDoc RTK rover?
The viDoc RTK rover is a device that can be mounted onto select Apple and Android devices. The rover, synchronized with Pix4Dcatch, geotags images with RTK accuracy in real-time, while connected to any NTRIP service, allowing absolute accuracy in 3D photogrammetric scanning.
Extensive research has revealed that it is possible to achieve 3D models with an absolute geolocation accuracy of less than 5 cm. More information is in the white paper.
Conceived by viGram GmbH., a German company led by professional surveyors, the viDoc RTK rover is designed with an eye for accuracy and works with Pix4Dcatch for image acquisition. The hand-held RTK rover is a replacement for more expensive ground surveying equipment that does not compromise on accuracy to achieve 3D, actionable results.
For more information see viDoc RTK rover product page.
Basic requirements:
- Pix4Dcatch app.
- viDoc RTK rover.
- NTRIP service subscription.
- Internet access.
- PIX4Dmatic, Pix4Dmapper, or Pix4Dcloud (Advanced) license or trial for processing.
Once the latest version of Pix4Dcatch is installed, select the viDoc RTK via Bluetooth settings. More information in the How to use Pix4Dcatch with viDoc RTK rover article.
The image acquisition in Pix4Dcatch is independently done from the recording of the GNSS data from the RTK rover. When the capture is complete and the project is saved, the geolocation information from the rover is tagged to the corresponding images based on the image timestamps. The orientation of the images is computed based on information from the AR tracking. In case part of the GNSS data has low accuracy (for example due to poor satellite visibility), relative AR positioning is used to improve the positions and accuracy.
The orientation of the geotagged images is indirectly computed from the internal IMU (Inertial Measurement Unit) of the mobile device and not from the viDoc RTK rover.
The offset is taken into account for select Apple devices. For more information: Recommended devices.
It is necessary to measure and enter the offset when pairing with an Android device. For more information: How to measure the offset - PIX4Dcatch (Android) with viDoc RTK rover.
Yes, you can select the coordinate system when uploading to PIX4Dcloud/PIX4Dcloud Advanced, in PIX4Dmatic or Pix4Dmapper, to get the 3D model or 2D map in a coordinate reference system of your choice. You can also transform the image geolocation in the desired coordinate system with third-party software.
- How to use coordinate reference systems in PIX4Dcatch.
- How to use coordinate systems in PIX4Dmatic.
- Change output coordinate system when uploading to PIX4Dcloud/PIX4Dcloud Advanced.
- Select Output Coordinate System in Pix4Dmapper article.
The height is based on the ellipsoid of the input horizontal coordinate reference system.
For more information: How to use PIX4Dcatch with the viDoc RTK rover.
In order to get the results georeferenced based on the local geoid, you can:
- Select the vertical coordinate reference system in PIX4Dmatic.
- Change the output coordinate system when uploading to PIX4Dcloud/PIX4Dcloud Advanced.
- Use third-party software and transform the heights from ellipsoid to geoid before importing them into Pix4Dmapper.
- Use the Geoid offset above ellipsoid option in Pix4Dmapper.
- Use Ground Control Points to apply the shift.
The antenna on the viDoc RTK rover has the best visibility of satellites when it is directly pointing upwards (90 degrees). The more the antenna is tilted from the 90-degree position, the lower its accessibility to satellites. Hence, it is recommended to only slightly tilt the device from the ideal 90-degree position to a maximum of 20 degrees.
The images acquired from Pix4Dcatch+viDoc should be precisely synchronized to within 100ms.
Please ensure that the device clock is synchronized. In order to synchronize the clock in your iPhone or iPad:
- Open the Settings app.
- Tap "General".
- Tap "Date & Time".
- Verify that "Set Automatically" is toggled to the right and appears green.
No, you need an internet connection during data capture to stay connected to the NTRIP service.
An internet connection is also needed every time Pix4Dcatch is started for logging into the app and uploading the data to Pix4Dcloud for generating the 3D model.
The viDoc RTK rover only allows access to an NTRIP service to receive real-time correctional GNSS data. It is not possible to do PPK or to connect to your own base station.
Yes, Pix4Dcatch with viDoc RTK rover allows to capture and process a 4D model and visualize it on Pix4Dcloud Advanced's timeline. Due to the RTK accuracy, the 3D models at different times are registered with cm accuracy. You can use Pix4Dcloud Advanced sliders to compare orthomosaics or track volume changes of small stockpiles.
Drone RTK flights, as well as Pix4Dcatch RTK data, can be combined in a single project inside Pix4Dmapper to obtain a 3D model that has the overview and roof data (from drone imagery) as well as the terrestrial details (from Pix4Dcatch mobile phone data).
More information about how to process such datasets is in the How to merge projects article.
How can I purchase the viDoc RTK Rover?
Contact us directly for the purchase of the viDoc RTK rover.
How can I get technical support for the viDoc RTK rover?
Pix4D customers: For technical questions, contact our support team.
Not a customer yet? Contact sales or post on the Pix4D Community.
The following list contains the geoids available to PIX4Dcatch using the viDoc RTK rover.
Country or region | Vertical coordinate reference system | Geoid |
Global | EGM2008 height - (EPSG:3855) | EGM2008 |
EGM96 height - (EPSG:5773) | EGM96 | |
Australia | AHD height - (EPSG:5711) AHD (Tasmania) height - (EPSG:5712) |
AUSGeoid98 |
AUSGeoid09 | |
AHD height - (EPSG:5711) | AUSGeoid2020 | |
Austria | EVRF2000 Austria height - (EPSG: 9274) | Austrian Geoid 2008 |
Canada | CGVD28 height - (EPSG:5713) | CGG2000/HTv2.0 |
CGVD2013 height - (EPSG:6647) | CGG2013 | |
CGVD2013(CGG2013a) height - (EPSG:9245) | CGG2013a | |
Czechia and Slovakia | Baltic 1957 height - (EPSG: 8357) | DVRM05 |
Denmark - onshore | DNN height - (EPSG:5733) | DNN |
DVR90 height - (EPSG:5799) | DVR90 | |
Faroe Islands - onshore | FVR09 height - (EPSG: 5317) | FVR09 |
France - mainland onshore | NGF-IGN69 height - (EPSG:5720) | RAF09 |
RAF18 | ||
France - Corsica onshore | NGF-IGN78 height - (EPSG: 5721) | RAC09 |
Gibraltar - onshore and Spain - mainland onshore | Alicante height - (EPSG: 5782) | EGM08-REDNAP |
Greenland - onshore and offshore between 58°N and 85°N and west of 7°W | GVR2016 height - (EPSG: 8267) | GGEOID2016 |
Greenland - onshore and offshore between 59°N and 84°N and west of 10°W | GVR2000 height - (EPSG: 8266) | GGEOID2000 |
Iceland - onshore | ISH2004 height - (EPSG: 8089) | IceGeoid2011 |
Ireland - onshore United Kingdom (UK) - Northern Ireland (Ulster) - onshore | Malin Head height - (EPSG: 5731) | OSGM15 |
Isle of Man - onshore | Douglas height - (EPSG: 5750) | OSGM15 |
Japan - onshore mainland - Hokkaido, Honshu, Shikoku, Kyushu | JGD2011 (vertical) height - (EPSG: 6695) | GSIGEO2011 |
Switzerland and Liechtenstein | LN02 height - (EPSG:5728) | CHGeo2004 |
LN95 height - (EPSG:5729) | ||
Mexico | NAVD88 height - (EPSG: 5703) | GEOID03, GEOID06, GEOID09, GEOID12A, GEOID12B, GEOID18, GEOID99, GGM10 |
Netherlands - onshore, including Waddenzee, Dutch Wadden Islands, and 12-mile offshore coastal zone | NAP height - (EPSG: 5709) | NLGEO2018 |
New Zealand | NZVD2009 height - (EPSG:4440) | NZGeoid2009 |
NZVD2016 height - (EPSG:7839) | NZGeoid2016 | |
Northern Mariana Islands - onshore - Rota, Saipan, and Tinian | NMVD03 height - (EPSG:6640) | GEOID12A |
GEOID12B | ||
Norway - onshore | NN54 height - (EPSG:5776) | HREF2008a |
NN2000 height - (EPSG:5941) | HREF2018b | |
Puerto Rico - onshore | PRVD02 height - (EPSG:6641) | GEOID12A |
GEOID12B | ||
GEOID18 | ||
South Africa - onshore | SA LLD height - (EPSG: 9279) | SAGEOID2010* |
Spain - Balearic Islands - Ibiza and Formentera | Ibiza height - (EPSG:9394) | EGM08-REDNAP |
Spain - Balearic Islands - Mallorca | Mallorca height - (EPSG:9392) | |
Spain - Balearic Islands - Menorca | Menorca height - (EPSG:9393) | |
Spain - Canary Islands - El Hierro | El Hierro height - (EPSG:9401) | |
Spain - Canary Islands - Fuerteventura | Fuerteventura height - (EPSG:9396) | |
Spain - Canary Islands - Gran Canaria | Gran Canaria height - (EPSG:9397) | |
Spain - Canary Islands - La Gomera | La Gomera height - (EPSG:9399) | |
Spain - Canary Islands - La Palma | La Palma height - (EPSG:9400) | |
Spain - Canary Islands - Lanzarote | Lanzarote height - (EPSG:9395) | |
Spain - Canary Islands - Tenerife | Tenerife height - (EPSG:9398) | |
Spain - Ceuta | Ceuta 2 height - (EPSG:9398) | |
St Helena, Ascension, and Tristan da Cunha - St Helena Island - onshore | SHVD2015 height - (EPSG: 7890) | EGM2008 |
Sweden - onshore | RH2000 height - (EPSG: 5613) | SWEN17 |
United Kingdom (UK) | ODN height - (EPSG:5701) | OSGM15 |
United Kingdom (UK) - Great Britain - England - Isles of Scilly onshore | St Marys height - (EPSG:5749) | |
United Kingdom (UK) - Great Britain - Scotland - Orkney Islands onshore | ODN Orkney height - (EPSG:5740) | |
United Kingdom (UK) - Great Britain - Scotland - Outer Hebrides onshore | Stornoway height - (EPSG:5746) | |
United Kingdom (UK) - Great Britain - Scotland - Shetland Islands onshore | Lerwick height - (EPSG:5742) | |
United Kingdom (UK) - Northern Ireland (Ulster) - onshore | Belfast height - (EPSG:5732) | |
United Kingdom (UK) – offshore between 2km from shore and boundary of UKCS within 49°46'N to 61°01'N and 7°33'W to 3°33'E | ODN (Offshore) height - (EPSG:7707) | |
United States (USA) | NAVD88 height (US Survey foot) - (EPSG: 6360) | GEOID03, GEOID06, GEOID09, GEOID12A, GEOID12B, GEOID18, GEOID99, GGM10* |
United States (USA) - onshore - Arizona, Michigan, Montana, North Dakota, Oregon, South Carolina | NAVD88 height (foot) - (EPSG: 8228) | |
United States (USA) | NAVD88 height - (EPSG: 5703) | |
Mexico | ||
US Virgin Islands - onshore - St Croix, St John, and St Thomas | VIVD09 height - (EPSG: 6642) | GEOID12A, GEOID12B, GEOID18 |
American Samoa - Tutuila island | ASVD02 height - (EPSG: 6643) | GEOID12A, GEOID12B |
Guam - onshore | GUVD04 height - (EPSG: 6644) | GEOID12A, GEOID12B |
* Geoid not available in PIX4Dcloud / PIX4Dcloud Advanced
