Pix4Dreact USNG
 Previous  |  Next
What is USNG?
The United States National Grid (USNG) is a map grid and a corresponding method of identifying cells in that grid. USNG codes can reference grid cells of different sizes depending on the accuracy needed. For example, 33U UU 91899 18914 addresses a 1m x 1m square, and 33U UU 918 189 addresses a 100m x 100m square at the same location. This makes this system perfect for communication locations over radio or phone. While USNG is mostly used by US public safety professionals today it is a worldwide system and not limited to the United States.
Tip: The following video What is USNG? from Fire Engineering can give you more insights into this feature.
More resources:
Turn on/off USNG(US National Grid)-visibility in Pix4Dreact
To turn on/off the USNG’s visibility:
  1. Turn on: Click on the USNG-button next to Enter GPS or USNG bar, when USNG is not visible and the USNG-button is black.
  2. Turn off: When USNG is visible, click on blue colored USNG-button.
Turn on/off USNG-labels
To turn on/off the USNG’s labels:
  1. Turn on: When the USNG is visible, click on the labels invisible-icon under the blue USNG-button.
  2. Turn off: When USNG and the labels are visible, click on the labels visible-icon under the blue USNG-button.
Change USNG color
To change the USNG color:
  1. When the USNG is visible, click the colored rectangle under the label visibility icon.
  2. Choose a color of your liking
Note: Depending on the coloring and terrain structure of your basemap the best visible color might differ from project to project.
Jump to USNG cell
To jump directly to any USNG cell:
  1. Enter a valid USNG code into the Enter GPS or USNG-bar
  2. Click on the “Go”-button next to the Enter GPS or USNG-bar
Note: You can enter any valid USNG code in any USNG resolution. The jump will end in the exact cell and appropriate zoom level. To pull out or hide the search function independently from the USNG grid visibility click on the arrow next to the search bar.
Jump to GPS location
To jump directly to a GPS coordinate:
  1. Enter a valid GPS coordinate into the Enter GPS or USNG-bar
Note: To pull out or hide the search function independently from the USNG grid visibility click on the arrow next to the search bar.
Copy USNG code from a point on the map
To copy a USNG code from a point on the map:
  1. Go with the mouse cursor to the point you want to copy the USNG code from
  2. Click on a point
  3. A position pop up appears
  4. Select and then copy the USNG code from this position pop up
  5. Close pop up
USNG code of cursor position on the map
  1. You find the USNG code of your current mouse cursor position under the Enter GPS or USNG-bar.
  2. The black numbers describe the USNG code of your current mouse cursor position respectively to the current zoom level
  3. All numbers (black and grey) show the most detailed USNG code of your current mouse cursor position.
USNG code in annotations (and PDF)
  • In Pix4Dreact: An annotation’s USNG code is (together with its GPS coordinates) part of every annotation info. It is displayed when editing an annotation and on the right side tab.
  • In PDF: An annotation’s USNG code is (together with its GPS coordinates) displayed in the PDF together with the respective annotation.
1 out of 1 found this helpful
