English
Specifications of xmp.camera tags - PIX4Dmapper
The XMP namespace Camera is defined by Pix4D, URI: http://pix4d.com/camera/1.0
Note: For projects that require radiometric calculations (e.g. agriculture applications), refer to the camera XMP section as well as this page which gives the specifications for the different corrections to be applied: Exif/Xmp tags for radiometric correction.
(XMP) Camera
Key
Value example
Type
Meaning
Xmp.Camera.ModelType
"fisheye"
XmpText
Camera model type: one of "perspective" or "fisheye".
Xmp.Camera.PrincipalPoint
2.42299,1.850154
XmpText
c x, c y in millimetres separated by comma.
Xmp.Camera.PerspectiveFocalLength
4.569165
XmpText
For perspective camera: focal length in millimetres.
Xmp.Camera.PerspectiveDistortion
0.201690322,-0.358534038,
0.256185599,
0.004208643,0.000268361
XmpText
For perspective camera: R1, R2, R3, T1, T2 separated by comma: How are the Internal and External Camera Parameters defined?.
Xmp.Camera.FisheyeAffineMatrix
1583.319083002,0,0,
1583.319083002
Ascii
For fisheye camera: Affine matrix C, D, E, F separated by comma: How are the Internal and External Camera Parameters defined?.
Xmp.Camera.FisheyeAffineSymmetric
1
Boolean
For fisheye camera: If symmetric affine matrix should be used (default false).
Xmp.Camera.FisheyePolynomial
0,1,-0.025178575,
0.167834214
Ascii
For fisheye camera: Polynomial separated by comma: How are the Internal and External Camera Parameters defined?.
Xmp.Camera.RigName
Airinov multiSPEC4C 1.1
XmpText
Name of the rig model this image belongs to.
Xmp.Camera.RigCameraIndex
0
Short
Corresponding camera index within the rig model.
Xmp.Camera.RigRelatives
0.3836, -1.27665, -0.1156
XmpText
Rotation angles with respect to the reference camera. For angle convention in Pix4D: Yaw, Pitch, Roll and Omega, Phi, Kappa angles .
Xmp.Camera.CaptureUUID
B9A2F3676304A83F92261B5245124F28
XmpText
Unique identifier for one capture within a flight. This allows to find that capture across different rig cameras.
Xmp.Camera.FlightUUID
7F8DC95FFCADA339805BD53338EC888 E
XmpText
Unique identifier for one flight
Xmp.Camera.UID
12606478859240980328
XmpString
Globally unique image identifier. Unsigned integer, must be a random number uniformly distributed in the range [0, 264-1]. The same random sequence must not be repeated in different units or for different acquisitions.
(XMP) Radiometric correction
Key
Value example
Type
Meaning
Xmp.Camera.BandName
{"Red", "NIR"}
XmpSeq
Name of each band (sequence).
Single page image: one name for each band of the image.
Multipage image: one band name per image page. (Note: this allows only one band per page since the sequence of the sequence is not possible).
The band name must not start with the following characters: 0-9, ',', '(' or ')'.
Xmp.Camera.CentralWavelength
{660, 800}
XmpSeq
Central wavelength of each band in nm. Similar to band names. If band names are not defined, default band names are generated.
Xmp.Camera.WavelengthFWHM
{10, 10}
XmpSeq
Full-width half maximum of the wavelength distribution in nm.
Xmp.Camera.BlackCurrent
{10, 7}
XmpSeq
Dark current for each band/page: Camera radiometric correction specifications.
Xmp.Camera.BandSensitivity
{0.78, 0.043}
XmpSeq
The sensitivity of each band (pixel intensity value per irradiance).
Xmp.Camera.SunSensor
{12.87, 9.72}
XmpSeq
Sun irradiance sensor (upwards looking sensor) raw value for each band.
Xmp.Camera.SunSensorExposureTime
0.1
XmpText
Sun irradiance sensor exposure time in seconds.
Xmp.Camera.SunSensorSensitivity
{16.45, 14.08}
XmpSeq
Sun irradiance sensor sensitivity.
Xmp.Camera.InvalidPixel
{"40,593,981,291"}
XmpSeq
List of bad pixels as comma-separated x,y coordinate list, one sequence for each band.
Xmp.Camera.VignettingPolynomial
{"0.00325, 1.983e-6, 5.0983e-9"}
XmpSeq
Vignetting correction by radial polynomial: 1D polynomial coefficients (one string of comma-separated values per page, 1 string for RGB images): Camera radiometric correction specifications.
Xmp.Camera.VignettingCenter
{"542,912"}
XmpSeq
Vignetting correction by radial polynomial: Center point cx, cy in pixel (one string of comma-separated values per page): Camera radiometric correction specifications.
Xmp.Camera.VignettingPolynomial2DName
{"0,0,1,0, ..., 2,2,3,1"}
XmpSeq
Vignetting correction by 2D polynomial: name of coefficients: n,m for c_{n,m} separated by commas (one string of comma-separated values per page): Camera radiometric correction specifications.
{"0.633287676149, 1.47936368033, ..., -1.58329242609, 0.130259802058"}
XmpSeq
Vignetting correction by 2D polynomial: coefficients c_{n,m} for names given by Xmp.Camera.VignettingPolynomial2DName separated by commas (one string of comma-separated values per page): Camera radiometric correction specifications.
Xmp.Camera.ColorTransform
{1, -0.114886,-0.0456918,
-0.176716, 1, 0,
-0.0715561, 0, 1}
XmpSeq
Sequence of double, color conversion matrix (for RGB: R2R, G2R, B2R, R2G, G2G, B2G, R2B, G2B, B2B). Considering the information as a 3x3 matrix M, (R,G,B) new= M * (R,G,B).
Xmp.Camera.IsNormalized
1
Boolean
Defines whether the radiometric correction is required (value 0) or the data has already been corrected (value 1) and therefore should not be corrected.
(XMP) Radiometric calibration target
Key
Value example
Type
Meaning
Xmp.Camera.Albedo
{0.22, 0.19 , 0.37}
XmpSeq
For radiometric calibration target images: Albedo of the disk for each band/page.
Xmp.Camera.ReflectArea
{"X1,Y1,X2,Y2,X3,Y3,X4,Y4", "X1,Y1,...", ...}
XmpSeq
For radiometric calibration target images: polygon defining the target area for each page.
Xmp.Camera.CalibrationPicture
2
Short
Specifies if this image is a radiometric calibration target: 0 = no, 1 = yes but invalid, 2 = yes and valid.
For Sequoia cameras: 0 = no, 1 and 2 = yes.
(XMP) Position and orientation
Key
Value example(s)
Type
Meaning
Xmp.Camera.Yaw
72.7942
Rational or Double
Orientation data in degrees. For more information on the definition of yaw, pitch, roll: Yaw, Pitch, Roll and Omega, Phi, Kappa angles.
Xmp.Camera.Pitch
1.7943
Rational or Double
Xmp.Camera.Roll
2.8909
Rational or Double
Xmp.Camera.HorizCS
EPSG:4326
EPSG:6318
XmpString
The horizontal coordinate system used by the GPS receiver, i.e. by Exif.GPSInfo.GPSLatitude and Exif.GPSInfo.GPSLongitude, in the form auth:WKID, where auth is an authority (e.g. EPSG or ESRI) and WKID a well-known code.
Xmp.Camera.VertCS
EPSG:5773
EPSG:5703
XmpString
The vertical coordinate system used by the GPS receiver, i.e. by Exif.GPSInfo.GPSAltitude, in the form auth:WKID, where auth is an authority (e.g. EPSG or ESRI) and WKID a well-known code, or the special value ellipsoidal for ellipsoidal height.
Xmp.Camera.GPSXYAccuracy
5
Rational
Horizontal GPS Accuracy in meters.
Xmp.Camera.GPSZAccuracy
10
Rational
Vertical GPS Accuracy in meters.
Xmp.Camera.GyroRate
0.0487
Rational
Gyro rate during image acquisition, lower = better quality.
Xmp.Camera.IMUPitchAccuracy
0.113
Rational
The value in degrees of 1-sigma of the Gaussian noise of the IMU Pitch measurement.
Xmp.Camera.IMURollAccuracy
0.087
Rational
The value in degrees of 1-sigma of the Gaussian noise of the IMU Roll measurement.
Xmp.Camera.IMUYawAccuracy
1.250
Rational
The value in degrees of 1-sigma of the Gaussian noise of the IMU Yaw measurement.
Xmp.Camera.NominalCameraDistance
25.87
Rational
Nominal GPS distance between calibrated cameras in meters in order to have a decent overlap. Use to dynamically remove the cameras with worst quality as determined by the GyroRate such the target distance is as specified.
Xmp.Camera.AboveGroundAltitude
25.3
Rational or Double
Altitude above ground/take-off location in meters (from the altimeter of the drone).
(XMP) Sun irradiance position and orientation
Key
Value example
Type
Meaning
Xmp.Camera.SunSensorYaw
72.7942
Rational or Double
Sun irradiance sensor orientation data in degrees. For more information on the definition of yaw, pitch, roll: Yaw, Pitch, Roll and Omega, Phi, Kappa angles.
Xmp.Camera.SunSensorPitch
1.7943
Rational or Double
Xmp.Camera.SunSensorRoll
2.8909
Rational or Double
Xmp.Camera.SunSensorRelativeRotation
175, 0, 0
XmpSeq
Relative angle between camera and sunshine sensor in the omega, phi, kappa system (same as rig relatives).
(XMP) Bit-depth reduction
Key
Value example
Type
Meaning
Xmp.Camera.TransformAlpha
{55684.1, 58672.8, 58889.1}
XmpSeq
Sequence of double, alpha parameter for each band.
This and the following two tags are used to undo a gamma transform which has been applied to fit data in 8bit space without losing the dynamic range:
pixel_final = alpha * pixel_normalized^gamma + beta;
where pixel_normalized is the pixel value stored in the JPG image scaled to the [0,1] interval.
Xmp.Camera.TransformBeta
{9850.9, 6862.2, 6645.91}
XmpSeq
Sequence of double, beta parameter for each band.
Xmp.Camera.TransformGamma
{2.12109, 2.6243, 2.33549}
XmpSeq
Sequence of double, gamma parameter for each band.
(XMP) Miscellaneous
Key
Value example
Type
Meaning
Xmp.Camera.SensorBitDepth
14
Short
Bit depth of the original sensor
Xmp.Camera.SensorTemperature
43.4
Double
Temperature of the sensor (degree Celcius)
