Specifications of xmp.camera tags
The XMP namespace Camera is defined by Pix4D, URI: http://pix4d.com/camera/1.0
Note: For projects that require radiometric calculations (e.g. agriculture applications), refer to the camera XMP section as well as this page which gives the specifications for the different corrections to be applied: Exif/Xmp tags for radiometric correction.
(XMP) Camera
Key Value example Type Meaning
Xmp.Camera.ModelType "fisheye" XmpText Camera model type: one of "perspective" or "fisheye".
Xmp.Camera.PrincipalPoint 2.42299,1.850154 XmpText cx, cy in millimetres separated by comma.
Xmp.Camera.PerspectiveFocalLength 4.569165 XmpText For perspective camera: focal length in millimetres.
Xmp.Camera.PerspectiveDistortion
0.201690322,-0.358534038,
0.256185599,
0.004208643,0.000268361
XmpText For perspective camera: R1, R2, R3, T1, T2 separated by comma: How are the Internal and External Camera Parameters defined?.
Xmp.Camera.FisheyeAffineMatrix
1583.319083002,0,0,
1583.319083002
Ascii For fisheye camera: Affine matrix C, D, E, F separated by comma: How are the Internal and External Camera Parameters defined?.
Xmp.Camera.FisheyeAffineSymmetric 1 Boolean For fisheye camera: If symmetric affine matrix should be used (default false).
Xmp.Camera.FisheyePolynomial
0,1,-0.025178575,
0.167834214
Ascii For fisheye camera: Polynomial separated by comma: How are the Internal and External Camera Parameters defined?.
Xmp.Camera.RigName Airinov multiSPEC4C 1.1 XmpText Name of the rig model this image belongs to.
Xmp.Camera.RigCameraIndex 0 Short Corresponding camera index within the rig model.
Xmp.Camera.RigRelatives 0.3836, -1.27665, -0.1156 XmpText Rotation angles with respect to the reference camera. For angle convention in Pix4D: Yaw, Pitch, Roll and Omega, Phi, Kappa angles .
Xmp.Camera.CaptureUUID B9A2F3676304A83F92261B5245124F28 XmpText Unique identifier for one capture within a flight. This allows to find that capture across different rig cameras.
Xmp.Camera.FlightUUID 7F8DC95FFCADA339805BD53338EC888E XmpText Unique identifier for one flight
(XMP) Radiometric correction
Xmp.Camera.BandName {"Red", "NIR"} XmpSeq
Name of each band (sequence).
Single page image: one name for each band of the image.
Multipage image: one band name per image page. (Note: this allows only one band per page since the sequence of the sequence is not possible).
The band name must not start with the following characters: 0-9, ',', '(' or ')'.
Xmp.Camera.CentralWavelength {660, 800} XmpSeq Central wavelength of each band in nm. Similar to band names. If band names are not defined, default band names are generated.
Xmp.Camera.WavelengthFWHM {10, 10} XmpSeq Full-width half maximum of the wavelength distribution in nm.
Xmp.Camera.BlackCurrent
{10, 7}
XmpSeq Dark current for each band/page: Camera radiometric correction specifications.
Xmp.Camera.BandSensitivity {0.78, 0.043} XmpSeq The sensitivity of each band (pixel intensity value per irradiance).
Xmp.Camera.SunSensor {12.87, 9.72} XmpSeq Sun irradiance sensor (upwards looking sensor) raw value for each band.
Xmp.Camera.SunSensorExposureTime {0.1, 0.1} XmpSeq Sun irradiance sensor exposure time in seconds.
Xmp.Camera.SunSensorSensitivity {16.45, 14.08} XmpSeq Sun irradiance sensor sensitivity.
Xmp.Camera.InvalidPixel {"40,593,981,291"} XmpSeq List of bad pixels as comma-separated x,y coordinate list, one sequence for each band.
Xmp.Camera.VignettingPolynomial {"0.00325, 1.983e-6, 5.0983e-9"} XmpSeq Vignetting correction by radial polynomial: 1D polynomial coefficients (one string of comma-separated values per page, 1 string for RGB images): Camera radiometric correction specifications.
Xmp.Camera.VignettingCenter {"542,912"} XmpSeq Vignetting correction by radial polynomial: Center point cx, cy in pixel (one string of comma-separated values per page): Camera radiometric correction specifications.
Xmp.Camera.VignettingPolynomial2DName {"0,0,1,0, ..., 2,2,3,1"} XmpSeq Vignetting correction by 2D polynomial: name of coefficients: n,m for c_{n,m} separated by commas (one string of comma-separated values per page): Camera radiometric correction specifications.
Xmp.Camera.VignettingPolynomial2D {"0.633287676149, 1.47936368033, ..., -1.58329242609, 0.130259802058"} XmpSeq Vignetting correction by 2D polynomial: coefficients c_{n,m} for names given by Xmp.Camera.VignettingPolynomial2DName separated by commas (one string of comma-separated values per page): Camera radiometric correction specifications.
Xmp.Camera.ColorTransform
{1, -0.114886,-0.0456918,
-0.176716, 1, 0,
-0.0715561, 0, 1}
XmpSeq Sequence of double, color conversion matrix (for RGB: R2R, G2R, B2R, R2G, G2G, B2G, R2B, G2B, B2B). Considering the information as a 3x3 matrix M, (R,G,B)<sub>new</sub>= M * (R,G,B).
Xmp.Camera.IsNormalized 1 Boolean Defines whether the radiometric correction is required (value 0) or the data has already been corrected (value 1) and therefore should not be corrected.
(XMP) Radiometric calibration target
Xmp.Camera.Albedo {0.22, 0.19 , 0.37} XmpSeq For radiometric calibration target images: Albedo of the disk for each band/page.
Xmp.Camera.ReflectArea {"X1,Y1,X2,Y2,X3,Y3,X4,Y4", "X1,Y1,...", ...} XmpSeq For radiometric calibration target images: polygon defining the target area for each page.
Xmp.Camera.CalibrationPicture 2 Short
Specifies if this image is a radiometric calibration target: 0 = no, 1 = yes but invalid, 2 = yes and valid.
For Sequoia cameras: 0 = no, 1 and 2 = yes.
(XMP) Position and orientation
Key Value example(s) Type Meaning
Xmp.Camera.Yaw 72.7942 Rational or Double Orientation data in degrees. For more information on the definition of yaw, pitch, roll: Yaw, Pitch, Roll and Omega, Phi, Kappa angles.
Xmp.Camera.Pitch 1.7943 Rational or Double Orientation data in degrees. For more information on the definition of yaw, pitch, roll: Yaw, Pitch, Roll and Omega, Phi, Kappa angles.
Xmp.Camera.Roll 2.8909 Rational or Double Orientation data in degrees. For more information on the definition of yaw, pitch, roll: Yaw, Pitch, Roll and Omega, Phi, Kappa angles.
Xmp.Camera.HorizCS
EPSG:4326
EPSG:6318
XmpString The horizontal coordinate system used by the GPS receiver, i.e. by Exif.GPSInfo.GPSLatitude and Exif.GPSInfo.GPSLongitude, in the form auth:WKID, where auth is an authority (e.g. EPSG or ESRI) and WKID a well-known code.
Xmp.Camera.VertCS
EPSG:5773
EPSG:5703
XmpString The vertical coordinate system used by the GPS receiver, i.e. by Exif.GPSInfo.GPSAltitude, in the form auth:WKID, where auth is an authority (e.g. EPSG or ESRI) and WKID a well-known code, or the special value ellipsoidal for ellipsoidal height.
Xmp.Camera.GPSXYAccuracy 5 Rational Horizontal GPS Accuracy in meters.
Xmp.Camera.GPSZAccuracy 10 Rational Vertical GPS Accuracy in meters.
Xmp.Camera.GyroRate 0.0487 Rational Gyro rate during image acquisition, lower = better quality.
Xmp.Camera.IMUPitchAccuracy 0.113 Rational The value in degrees of 1-sigma of the Gaussian noise of the IMU Pitch measurement.
Xmp.Camera.IMURollAccuracy 0.087  Rational The value in degrees of 1-sigma of the Gaussian noise of the IMU Roll measurement.
Xmp.Camera.IMUYawAccuracy 1.250  Rational The value in degrees of 1-sigma of the Gaussian noise of the IMU Yaw measurement.
Xmp.Camera.NominalCameraDistance 25.87 Rational Nominal GPS distance between calibrated cameras in meters in order to have a decent overlap. Use to dynamically remove the cameras with worst quality as determined by the GyroRate such the target distance is as specified.
Xmp.Camera.AboveGroundAltitude 25.3 Rational or Double Altitude above ground/take-off location in meters (from the altimeter of the drone).
(XMP) Sun irradiance position and orientation
Xmp.Camera.SunSensorYaw 72.7942 Rational or Double Sun irradiance sensor orientation data in degrees. For more information on the definition of yaw, pitch, roll: Yaw, Pitch, Roll and Omega, Phi, Kappa angles.
Xmp.Camera.SunSensorPitch
1.7943 Rational or Double Sun irradiance sensor orientation data in degrees. For more information on the definition of yaw, pitch, roll: Yaw, Pitch, Roll and Omega, Phi, Kappa angles.
Xmp.Camera.SunSensorRoll 2.8909 Rational or Double Sun irradiance sensor orientation data in degrees. For more information on the definition of yaw, pitch, roll: Yaw, Pitch, Roll and Omega, Phi, Kappa angles.
Xmp.Camera.SunSensorRelativeRotation 175, 0, 0 XmpSeq Relative angle between camera and sunshine sensor in the omega, phi, kappa system (same as rig relatives).
(XMP) Bit-depth reduction
Xmp.Camera.TransformAlpha {55684.1, 58672.8, 58889.1} XmpSeq
Sequence of double, alpha parameter for each band.
This and the following two tags are used to undo a gamma transform which has been applied to fit data in 8bit space without losing the dynamic range:
pixel_final = alpha * pixel_normalized^gamma + beta;
where pixel_normalized is the pixel value stored in the JPG image scaled to the [0,1] interval.
Xmp.Camera.TransformBeta {9850.9, 6862.2, 6645.91} XmpSeq Sequence of double, beta parameter for each band.
Xmp.Camera.TransformGamma {2.12109, 2.6243, 2.33549} XmpSeq Sequence of double, gamma parameter for each band.
(XMP) Miscellaneous
Xmp.Camera.SensorBitDepth 14 Short Bit depth of the original sensor
Xmp.Camera.SensorTemperature 43.4 Double Temperature of the sensor (degree Celcius)
1 out of 6 found this helpful
3 comments
  • Phil Harvey
    Technical details about the format are lacking somewhat.  Where are the definitions for the data types that you mention?  ie. By "Rational", do you mean a text string with a rational value expressed as the ratio of two integers (like "345/100" for example)? -- this is the way XMP Exif Rational values are stored.  And what is a "Double" -- do you allow exponential notation, and if so what is the format, and is the range limited to that of an IEEE 8-byte double?  Also, how is "ASCII" different from "XMPText"?  How is Short different from a regular integer (is it limited to < 65536)?  And for XmpSeq, you should say "Seq of Double" or something similar -- sometimes the type isn't specified.  In general, it would be much clearer if you used the same terminology as the XMP specification, and referred to that specification for the details.  And an XMP Boolean is typically a string which is either "True" or "False", but you seem to be using an integer for this (with values of "0" and "1"?).  And one more thing:  What is the namespace URI and preferred namespace prefix? -- these must be defined somewhere but I can't find them.
  • Avatar
    Momtanu (Pix4D)
    Hi Phil, Pix4D uses exiv2 to read the EXIF/XMP tags. You can have a look at their website for the data types (https://www.exiv2.org/sample.html)
  • Jackson tang
    @...: pix4d can recognize DJI xmp tag (XMP-drone-dji DewarpData).  but .I have a question. DJI distortion tag (XMP-drone-dji DewarpData) is customized. If other companies want to save the distortion parameters of their cameras to the photo exif, which tag should be saved to? Convenient pix4d to recognize this tag 。
    This tag (Xmp.Camera.PerspectiveDistortion) was introduced above. Is it possible to recognize this tag by pix4D? in short. pix4D is for the distortion parameters of the lens. It can be retrieved from both places. 1. XMP-drone-dji DewarpData, 2. Xmp.Camera.PerspectiveDistortion. Is my understanding correct?
