Pix4Dcapture guide to troubleshoot issues
11 out of 21 found this helpful
41 comments
  • jacob svendsen
    Hello i have an Dji Inspire 2 and a X4S camera on board.
    When i fly a mission the drone uploads and take off with no problems, after it sets the altitude it fly in a strange way to the mapping beginning and something happinibg in the camera setting, so when the mission starts, it taks pictures to the left or the right sides and the only thing i can do is to pause the mission, start up the dji go4 app and reset the camera gimble and then go back in pix4d and resume the mission and then it goes. Until it begin to map the other direktions, so the camera hang in same direktion as the mapping before?? If i use dronedeploy or map pilot i have no problems and Dji had tjeked the drone and gimble also, now i dont now what to do, please help me, im paying for this app and program
    Best Jacob
  • SGH SGH
    Jacon, I think this is the same issue I am having.  The gimbal yaws so the photographs are taken on an angle.  I don't experience this issue using Android however, only with the iOS version of the app.
    -Sean
  • Giovanni Ciucci
    Salve ,ho appena acquistato  un drone mavic 2 zoom e non sapevo che pix4d capture non lo supportava , come posso usare l'app con il mio drone ?
  • Gaël (Pix4D)
    Ciao Giovanni,
    il Mavic 2 Pro è attualmente supportato sulla versione iOS di Pix4Dcapture.
    Non è di prossima realizzazione il progetto di supportare Mavic 2 Zoom perciò non sarà possibile usarlo con Pix4Dcapture.
    Tuttavia, se i piani cambiano e avremo in progetto di supportarlo, lo comunicheremo appena possibile.
  • cesar salgado
    Hi, i planned a mission and it was flying correctly but sudenly said going to land on the app and it went aeay somewhere i dont find it yet. Please some one help me
  • Gaël (Pix4D)
    Hi Cesar,
    Thank you for contacting us. I noticed that you wrote us a ticket that seems to also be about the issue you are describing here. I will answer your ticket directly via our support system.
    Best,
  • Raffaele Dalessandri
    Buongiorno a tutti. Sono un felice possessore di Mavic 2 Pro ma ho il problema di avvio dell'applicazione sul Dji Smart Controller. Per il mio lavoro è utile l'app di Pix4D che ho scaricato ma non gira nel dispositivo. Da cosa può dipendere?
  • Gaël (Pix4D)
    Ciao Raffaele,
    Il Dji Smart Controller non è attualmente supportato su Pix4Dcapture, perciò non potrai usare la nostra app con questo controller. Nota che sarai in grado di pilotare il DJI Mavic 2 Pro con il controller di default.
    Ti suggerisco di dare un'occhiata alla nostra pagina web che contiene la lista di droni e camere supportate e e a questo thread della nostra Community.
    Cordiali saluti,
  • FLEURY BRUNO
    bonjour,
    j'ai chargé PIX4D capture en version Android je n'ai jamais pu démarrer la mission il m'indiquait crtl+DJI avec un écran noir. J'ai été obligé de désintaller PIX 4D capture pour pouvoir réaliser la mission.
    Pouvez me dire ce qu'il faut réaliser comme manipulation sur le smartphone pour que PIX4D capture fonctionne.
    CDT
  • Gaël (Pix4D)
    Bonjour Bruno,
    Si vous utilisez la version Android de Pix4Dcapture, il est impératif de télécharger Pix4Dcapture ainsi que son Plugin selon le drone que vous utilisez.
    Vous pouvez trouver les liens ici:  Pix4Dcapture et Ctrl+plugin.
    Une chose importante à vérifier est que l'application native de votre drone n'est pas selectionné par défaut: (Android) How to change default app when connecting to the drone.
    Cordialement,
  • SMT Mapping
    Hello,
    I have been setting missions and everything is fine for the drone to take off and head to the mission, but once it does, it just hovers there and won’t do anything else. I’ve tried all the troubleshooting I can think of in the app and with my tablet. I was flying yesterday and it was perfectly fine. Please let me know if you can help.
    Thanks
  • Gaël (Pix4D)
    Hi,
    Can you specify me what is your configuration? (drone, camera, mobile device)
    Also, on top of this troubleshooter, did you follow all the basic checks and troubleshooting steps described in this article? If properly followed, it will enable to solve most of the unexpected behaviors that can be encountered.
    Best,
  • Claudia Scaramella
    Buongiorno, Ho riscontrato un problema sul caricamento della missione sul drone. Durante la checklist prima del decollo non mi passa il check "camera set up" , impedendomi così di caricare il piano di volo sul drone. (il drone in oggetto è un Phantom 4 Pro V1)
    Ho provato con altri droni che due settimane fa hanno lavorato con l'App Pix4DCapture senza problemi, però ho riscontrato lo stesso problema anche su questi . (Inspire 1, Matrice 210, Matrice 210 RTK).
    Ho effettuato la procedura come da voi indicata (disinstallare, installare, resettare ,ecc.) ma allo stato attuale mi trovo con un app inutilizzabile. Sarei felice di sapere poter risolvere il problema.
    Grazie
  • Gaël (Pix4D)
    Ciao Claudia,
    Grazie per aver provato il nostro troubleshooter.
    Inoltre, ti suggerirei di consultare questo altro articolo sulla nostra Knowledge Base per risolvere il problema.
    Stai usando la versione iOS o Android di Pix4Dcapture?
    Può succedere che la missione non venga caricata sul drone o che lo stato della fotocamera non sia pronto.
    In questo caso, suggeriamo:
    - Di controllare nell'applicazione del produttore che tutto vada bene con il drone e che non provienga da un difetto del drone. Dovresti essere in grado di scattare le immagini, avere il feed live della fotocamera, pilotare manualmente il drone.
    -  Di riavviare da capo la missione. Per fare ciò, chiudere e forzare l'uscita dall'app, scollegare il cavo dal dispositivo mobile, spegnere il telecomando e il drone. Quindi accendere il drone e il controller, ricollegare il cavo USB e aprire Pix4Dcapture. Su Android, è necessario avviare Pix4Dcapture da Ctrl + plugin.
    - Di ridurre le dimensioni della missione e/o utilizzare la modalità Veloce per scattare le immagini se si utilizza la versione iOS di Pix4Dcapture.
    - Se possibile, utilizzare un'altra applicazione di terze parti per vedere se è in grado di risolvere il problema.
    Puoi inviarmi uno screenshot del problema mentre viene visualizzato sullo schermo il popup della checklist di decollo?
    Grazie mille
  • Da Costa Manuel
    bonjour
    j'utilise depuis plusieurs mois le parrot bebop 2 avec PIX4D sur IOS
    depuis les mises à jour soit de l'IOS ou du logiciel PIX4D, le drone ne se connecte plus. (j'ai vérifié les connections du drone via Free Fligt PRO et tout fonctionne)
    J'ai un IPAD en IOS 10 et donc avec une version plus ancienne de PIX4D et le drone se connecte et j'ai accès sans aucun soucis au fonctionnalité de Pix 4d
    Je pense qu'il existe un beug entre la nouvelle version de pix4d et de IOS pour le drone parrot bebop2
    dans l'attente d'une vérification de votre part sur la compatibilité de pix4d / IOS >10 et bebop 2
    cdt
    Manuel
  • Gaël (Pix4D)
    Bonjour Manuel,
    Avant d'aller plus loin dans les investiguations, pouvez vous me dire si vous utilisez bien votre Bebop 2 avec le SkyController 2? Il n'est pas possible d'utiliser Pix4Dcapture en utilisant simplement la connection Wi-Fi avec le Bebop 2.
    Voici mes recommendations:
    - Soyez sur de bien avoir quitté Free Flight Pro avant de lancer Pix4Dcapture. Si non, Il faut sinon forcer la fermeture de l'application native: (Android, iOS) How to force quit an app
    - Réinstaller complêtement Pix4Dcapture.
    Avez vous suivis les étapes décrites dans notre article de résolution de problèmes? Si il est correctement suivi, il permet de résoudre la plupart des problèmes qui peuvent être rencontrés.
    Salutations,
  • Da Costa Manuel
    bonjour Gael
    je n'utilise pas le skycontroller 2
    la problématique est que la nouvelle version de PIX4D ne se connecte pas au bebop 2
    j'ai toujours utilisé le drone et la planification de vol de PIX4D jusqu'à la mise à jour.
    D'ailleurs avec IOS10.2 sur une ancienne tablette cela fonctionne.
    cdt
  • Gaël (Pix4D)
    Bonjour Manuel,
    Depuis la version iOS V3.0 de Pix4Dcapture et comme décrit dans la release note associée, le bebop 2 ne peux être utilisé qu'avec le SkyController 2 en raison des instabilités de la connection avec le Wi-FI.
    • (3.0.0) Bebop 2 can only be used with Skycontroller 2 and not with the WiFi anymore.
    Je peux donc vous suggérer:
    - De continuer à utiliser la configuration qui fonctionne encore pour vous.
    - D'obtenir le SkyController 2 pour pouvoir utiliser Pix4Dcapture.
    Cordialement.
  • Joseph Oakes
    Hello,
    I am trying to connect a DJI M200 V2, with an MicaSense Altum onboard, to a android tablet using Pix4D Capture v4.5.
    The drone is calibrated using the DJI Pilot app. Everything is green and ready to fly following what DJI Pilot is saying.
    I close this app (fully close, not only reduced), and open the plug-in, which connect to the drone successfully. From the plug-in, I launch Pix4D Capture. It connect successfully to the drone also
    I prepare the mission, and clic "start". It tells me successful connection to the drone. I clic next to the check list.
    Only the first line with successful connection to the drone is checked. However, on the main problem, it says the drone require calibration using DJI Go (I cannot use DJI Go with this drone model, but DJI Pilot) but the drone is already calibrated.
    Besides, a second error in the check list is that the mission is not uploading to the drone.
    So finally, I never managed to go forward, and start the mission.
    Any help?
  • Gaël (Pix4D)
    Hello Joseph,
    The DJI Matrice 200 V2 series is not supported by Pix4Dcapture at the moment. I will share your interest with the developer's team and the Product Owner.
    We always recommend making sure that your drone is compatible with our application before using it. You can find the list of supported drones and cameras here.
    Best regards,
  • Carmen Morales
    Hola,
    Tengo un DJI inspire 2 con cámara RGB Zenmuse X4S y Pix4Dcapture para IOS. Cuando realizo la misión todo parece correcto y el dron toma fotos de toda la parcela. Cuando analizo con Pix4Dmapper solo aparecen un grupo de fotos pero no de toda la parcela. ¿Cómo puedo solucionarlo? ¿Dónde está el problema?
    Saludos
    Carmen
    Edited by Carmen Morales
  • Sonny Chun
    Cannot connect to server
  • Gaël (Pix4D)
    Hola Carmen,
    ¿Está volando usando el modo Rápido o Seguro para tomar imágenes?
    Si mi comprensión es correcta, no todas las imágenes fueron adquiridas por Pix4Dcapure aunque los pequeños iconos de la cámara que se pueden ver durante el vuelo se mostraran correctamente?
    ¿Es posible enviar una captura de pantalla de la misión Pix4Dcapture y las imágenes que tiene en Pix4Dmapper?
    ¿Cómo se consiguieron las imágenes del dron para analizarlas en Mapper? ¿Las ha sacado directamente de la tarjeta SD?
    Además, el problema descrito puede ocurrir utilizando el modo rápido cuando se produce una pérdida de conexión. En este caso, el icono de la pequeña cámara se muestra correctamente cuando se vuela en la misión, pero la imagen no se toma
    Le recomendaría entonces:
    - Asegúrese de tener una conexión fiable con el dron durante toda la misión.
    - Usando el modo seguro ya que no depende de la conexión con el dron para tomar imágenes.
    Además, cuando se produce un comportamiento inesperado, se recomienda:
    - Siga basic checks and troubleshooting steps. Si se sigue correctamente, permitirá resolver la mayoría de los problemas que pueden encontrar los usuarios.
    - Reinicie su misión desde cero. Para ello, cierre la aplicación, desconecte el cable del dispositivo móvil, apague el control remoto y el drone. A continuación, encienda el drone y el controlador, vuelva a conectar el cable USB y abra Pix4Dcapture.
    Saludos
  • Alexis Contreras D
    Buenas tardes, tengo 2 puntos que no sé si ya estan implementados (en este caso necesitaré soporte) o en el caso que no, sean una sugerencia de mejoramiento del PIX4DCapture.
    1.- Si abro el PIX4D Capture en mi celular para crear un nuevo proyecto, me gustaria que estuviera disponible este proyecto de vuelo en otro dispositivo para poder ejecutar el vuelo. Es decir, si tengo varios dispositivos con el PIX4D Capture, con solo iniciar sesion, me gustaria contar con los demas proyectos guardados.
    2.- Espero se pueda usar el PIX4D Capture en el PC ya que es mas fácil crear un plan de vuelo, ya que el celular cuenta con una pantalla mas pequeña. Junto con el punto 1, seria solo salir al campo y ejecutar el proyecto de vuelo.
    Por otro lado, me gustaría comentar que las siguientes herramientas serían de gran utilidad para crear los planes de vuelo:
    3.- Que sea capaz de marcar al menos 3 puntos según ubicación del GPS, es decir me posiciono en el punto A lo grabo en el PIX4D Capture, luego voy al punto B y lo grabo, luego voy al punto C y lo grabo, el PIX4D Capture debiera automáticamente darme un polígono aproximado que encierre estos 3 puntos de tal manera de establecer los limites de la misión.
    4.- En versión para IPhone no encuentro disponibles varias misiones para un mismo proyecto.
    5.- La opcion de POLYGON for 2D maps podria estar disponible tambien en Dobre Grid para 3D
    Estimados, espero sus comentarios
    Alexis
  • Gaël (Pix4D)
    Hola Alexis,
    Gracias por todas las sugerencias que nos comentas.
    La mayoría de ellas han sido ya reportadas por otros usuarios en otras ocasiones y las he compartido con los desarrolladores y product owner.
    Tratamos de tenerlas en cuenta para ir poco a poco mejorando la aplicación y la experiencia del usuario.
    Sobre la tercera sugerencia, como posibilidad alternativa a lo que propones, es posible importar un .kml/.kmz que permita definir mejor los límites de tu proyecto. Por el momento, esta funcionalidad solamente está disponible en la version para Android. Quizñas te pueda ayudar ya que puedes hacerlo antes de ir al campo a volar.
    Un saludo.
  • Helmuth Wiesinger
    Hello,
    I'm using Pix4DCapture App on iOS with Parrot Anafi drone ... works perfectly well under normal conditions.
    Still, so far I encountered two situations that abort a running mission, which are hard to control:
    • Imagine you receive an incoming call while the drone is flying in a mission.
      Currently in version 4.5, even if you choose to not take the incoming call, the ongoing mission in the app is closed.
      I'm not able to monitor it any further. The drone continues to take pictures even afterwards, and it even returns successfully at the end of the uploaded mission.
      BUT: There are no images on the SD card after the incoming call was received.
    • Imagine taking the Pix4D Capture app to background on your iPhone, while the drone is flying in a mission.
      Currently in V4.5 when you return to the app, the ongoing mission is closed there. You're back to home screen.
      The rest is like above. Monitoring is not possible any longer, the drone continues and returns, but no images are saved to SD card after that action (taking the app to background)
    Are there any known workarounds to that?
    Can I, for example, turn of mobile network of my mobile or even switch the iPhone to flight mode after before I start a mission?
    Maybe these things are easy to fix.
    If more detailed explaination is needed pls contact me by e-mail.
    Best regards!
  • Gaël (Pix4D)
    Hi Helmuth,
    thank you for your interesting feedback.
    The case you are mentioning with incoming phone calls has not been considered. So if I understand it well the application is crashing, when a phone call is received, am I right?
    I will report this behavior to the developer's team.
    In the meantime, when operating a drone using Pix4Dcapture, I strongly suggest the following:
    - If possible, get a mobile device that is dedicated to your flights so that no incoming calls will disturb the missions.
    - After having planned your mission and before starting it, it should not have any impact to put the flight mode on your phone as the GPS will still be active.
    Also, I would strongly recommend interrupting a mission while you are experiencing crashes or any unexpected behavior.
    About the second case, I will also report it to the developers, as it should be possible to follow up on the mission even while putting the application in the background for a while. Is the behavior you described happening all the time? Also, note that when flying a mission, you should not put in the background Pix4Dcapture and follow up the mission all time if an unexpected behavior occurs.
    Best regards,
  • John Smith
    Hi Helmuth and Gäel,
    I'm using Android and DJI Mavic Pro. Incoming calls don't affect the mission, I just shut the call.
    But Pix4D Capture App freezes in the middle od the misson very often, approx. 1/3 of all flights. App doesn't crash, the screen is just freezed or maybe it's more like connection with remote controller was lost, but without any warning. Dron is still on a misson able to finish it, it lands succfesfully on Homepoint, it's taking pictures and they're all on SD card. I'm not able to watch the progress of the mission, because the screen is freezed and there's button "start" instead of "abort".
    I guess it's OK to finish the misson, when you have a visual contact with a drone and all important indicators are displayed on a remote controlle. I'm going to try another mobile device next time.
    Regards, John
  • Cláudio Ângelo da Silva Neto
    Hi, I have a Mavic 2 Pro and have tested Pix4dCapture on Android and iOS several times. However, on both, clicking the Camera View button shows nothing, the screen only shows everything black.
    The survey is done normally, but I can't see Camera View during the flight.
    All firmware, application versions, and operating systems are up to date. I've searched several forums and couldn't solve my problem. Thanks if you can help me.
  • Gaël (Pix4D)
    Hi Claudio,
    Using the Mavic 2 Pro, the video feed has not been implemented on the Android version of Pix4Dcapture, it is then normal that you will have a black screen when trying to access the camera view. You can find back this information on important communication here.
    On the iOS version, several users reported that the video feed was not working properly and our developers have indeed confirmed that. A fix will come in the next release of the iOS version of Pix4Dcapture.
    Best regards,
