This article contains the most used and latest supported drones and cameras in PIX4Dfields.
- The table below is structured by Brand, Drone/Camera, and Syntax.
- Syntax is composed by: Camera model + Focal Length + Resolution.
If the camera is not listed in this article, check if it is present in Remaining supported cameras. PIX4Dfields will be able to process the images for all cameras listed in the PDF, but it is recommended to test the processing as the quality of the orthomosaic may vary.
Register for a trial version to test your images.
Brand | Drone/Camera | Syntax |
Parrot | AnafiAi | ANAFIAi_5.3_4000x3000 ANAFIAi_5.3_8000x6000 |
Anafi/AnafiUSA | Anafi_4.0_4608x3456 Anafi_4.0_5344x4016 |
Sequoia/Sequoia+ | Sequoia_4.0_1280x960 | |
MicaSense | Altum | Altum_1.8_160x120 (Thermal) Altum_8.0_2064x1544 |
Altum-PT | Altum-PT_10.3_4112x3008 (Panchromatic) Altum-PT_1.8_320x256 (Thermal) Altum-PT_8.0_2064x1544 |
RedEdge-P | RedEdge-P_10.3_2464x2056 (Panchromatic) RedEdge-P_5.5_1456x1088 |
RedEdge | RedEdge_5.5_1280x960 | |
RedEdge-MX RedEdge-M | RedEdge-M_5.5_1280x960 RedEdge-M_5.5_960x1280 |
senseFly | albris | albris_8.0_4488x3368 albris_8.0_7152x5368 albris_8.0_7728x5368 |
S.O.D.A. | S.O.D.A._10.2_5472x3648 S.O.D.A._10.2_5472x3648_fw_1.1.0 S.O.D.A._10.6_5472x3648 |
S110 RGB/NIR/RE | CanonPowerShotS110_5.2_4048x3048 | |
senseFly Aeria X | senseFlyAeriaX_18.5_6000x4000 | |
DJI | Spark | FC1102_4.5_3968x2976 |
Mini | FC7203_4.5_4000x2250 | |
Mavic Air | FC2103_4.5_4056x3040 | |
Mavic Air 2 | FC3170_4.5_4000x3000 | |
Mavic Air 2S | FC3411_8.4_5472x3648 | |
Mavic Pro | FC220_4.7_2000x1500 FC220_4.7_4000x2250 FC220_4.7_4000x3000 |
Mavic 2 Enterprise Dual | FC2403_4.5_4056x3040 | |
Mavic 2 Pro | L1D-20c_10.3_5472x3648 | |
Mavic 2 Enterprise Advanced | MAVIC2-ENTERPRISE-ADVANCED_4.5_8000x6000 (RGB) | |
Mavic 3 | L2D-20c_12.3_5280x3956 | |
Mavic 3 Enterprise | M3E_12.3_5280x3956 | |
Mavic 3 Multispectral | M3M_4.3_2592x1944 M3M_12.3_5280x3956 |
M30T | M30T_4.4_4000x3000 (RGB - Wide) | |
Phantom 3 | FC300C_3.6_2000x1500 FC300C_3.6_4000x3000 |
Phantom 3 Adv | FC300S_3.6_4000x2250 FC300S_3.6_4000x3000 |
Phantom 3 Pro | FC300X_3.6_4000x2250 FC300X_3.6_4000x3000 |
Phantom 4 | FC330_3.6_2000x1500 FC330_3.6_4000x2250 FC330_3.6_4000x3000 |
Phantom 4 Pro V2 | FC6310S_8.8_5472x3648 FC6310S_8.8_4864x3648 |
Phantom 4 Pro | FC6310_8.8_4864x3648 FC6310_8.8_5472x3648 |
Phantom 4 RTK | FC6310R_8.8_4864x3648 FC6310R_8.8_5472x3648 |
Phantom 4 Multispectral | FC6360_5.7_1600x1300 | |
Zenmuse P1 | ZenmuseP1_35.0_8192x5460 | |
Zenmuse H20T | ZH20T_4.5_4056x3040 (RGB) | |
Zenmuse X3 | FC350_3.6_4000x2250 FC350_3.6_4000x3000 |
Zenmuse X5 | FC550_15.0_4608x3456 FC550_DJIMFT15mmF1.7ASPH_15.0_4608x3456 FC550_OLYMPUSM.12mmF2.0_12.0_4608x3456 |
Zenmuse X5RAW | FC550RAW_DJIMFT15mmF1.7ASPH_15.0_4608x3456 | |
Zenmuse X4S | FC6510_8.8_4864x3648 FC6510_8.8_5472x3078 FC6510_8.8_5472x3648 |
Zenmuse X5S | FC6520_DJIMFT15mmF1.7ASPH_15.0_5280x3956 | |
Zenmuse X7 | FC6540_DJIDL24mmF2.8LSASPH_24.0_6016x4008 FC6540_DJIDL35mmF2.8LSASPH_35.0_6016x3376 |
SlantRange | SlantRange-3P | SlantRange-3P_12.0_1280x1024 |
Sentera | Sentera 6X | 21216-01_3.2MP-GS-0001 (Thermal) 21214-00_3.2MP-GS-0001 (Standard) |
AeroVironment | Quantix | Quantix_2.6_2432x1824 Quantix_5.2_4864x3648 Quantix_5.4_4864x3648 Quantix_5.4_2432x1824 |
AutelEvo | Autel Evo I | XB015_3.2_4000x3000 |
Autel Evo II 8K | XT701_4.7_7680x4320 | |
Autel Evo II Pro 6K | XT705_10.6_5472x3648 | |
Autel Evo II Pro V3 | XL705_10.2_5472x3648 | |
Autel Evo II Dual | XT706_4.7_4000x3000 | |
Sony | Sony Alpha 7R IV | ILCE-7RM4_FE24mmF2.8G_24.0_9504x6336 |
Yuneec | E90 | E90_8.3_5472x3648 |
Skydio | Skydio2/2+ | 2_3.7_4056x3040 |
Skydio X2(RGB only) | X2_3.7_4056x3040 X2+_3.7_4056x3040 X2Wide_3.7_4056x304 |
XAG | M500 | Xcam20UC02_10.6_4864x3648 Xcam20UC02_10.6_5472x3648 |
La Quinta | DB2-Vision | LaQuintaM-Spectral_8.0_1344x759 |
ACSL | SOTEN | CX-GB100_10.2_5448x3632 |
Hello, I can see the Mavic Mini (FC7203_4.5_4000x2250) in the supported camera list, but when trying to import jpegs to Pix4dfields it keeps saying that is isn't compatible. I downloaded the database file and couldn't find the lines for FC7203.
Do you know the solution? Thanks!
Hey, thanks for letting us know. Indeed this camera is not yet supported, but we are working to add it soon. Meanwhile, you can use an XML file to test it some users have shared this file with us. You can contact us with a ticket to support and we can gladly give it to you.
Hello,
Is this camera no longer supported? I have downloaded sequoia_update.plf from https://support.parrot.com/us/support/products/parrot-sequoia and uploaded through USB cable to http://192.168.42.2/ .
Hi John,
We think you are using images from the front camera. Could you please let me know if you are doing that intentionally? Usually, our users process the images from the ParrotSequia camera which is also integrated into that drone, and the images are stored in the SD card.
Best,
Hello,
I have imported Images from a DJI 4P Multispectral to Pix4D Fields. After processing the orthomosaic looks that it was not aligned properly.
Any thoughts? Please help
Thank you
Hey George,
Did you process with the rig relative calibration option? If this does not work, could you please create a ticket to support? Please send us the log file, information about the overlap, speed, weather conditions during the acquisition, and if possible the dataset. We can replicate the issue, and explain the reason for the issues. Then, we can share the outputs here.
What is the best way to view or read the contents of the camera database file. Do you have a dedicated reader that displays the data in table form or some other form?
Dear Gary,
You can download the file and see it with a text editor such as Notepad++. I think this is the best way to see it. We do not have another reader that can display this information as a table. If you have some issues understanding the format, you can contact support or post in our community, we will gladly help you.
Kind regards,
Need help to import and process the images. I am getting following error.
Thanks,
Anand
Anand, this XML file should work: https://drive.google.com/drive/folders/1XYnoUyOciM7Xt1Z1EUHJXdL-8rexluDx?usp=sharing
You will need to import this file in Pix4DFields. Let us know if you need any help.
Hello,
I need help to import and process the images. The camera is not supported. Can somebody help me?
Thanks in advance.
Christian
The 30 mm focal length of this camera is supported (ILCE-6000_30.0_6000x4000). However, if you send us 3 images (you can upload in google drive), we can send you an XML file which you can import to Pix4DFields: https://support.pix4d.com/hc/en-us/articles/360035481811-How-to-generate-an-XML-file-to-process-a-not-supported-camera-in-Pix4Dfields#label6
Hey Momtanu,
here is the link to google drive with three images. Thank you for your help :)
https://drive.google.com/drive/folders/1Dg8iNvtsSgPmghm5Eojs7lslrJTCY1Qa?usp=sharing
Hello Christian,
I uploaded the XML file here. At the end of this article https://support.pix4d.com/hc/en-us/articles/360035481811 you will find the instructions of how to import it to Pix4Dfields.
Sincerely,
Buenas tardes, espero estén bien.
Dispongo de un dji Ph4 multiespectral con cámara FC6360_5.7_1600x1300, según el listado compatible con Pix4d Fields.
Cuando realizo el proyecto con las imágenes RGB me genera el ortomosaico de forma correcta, pero al generar con las imágenes tif de las bandas multiespectrales, parece que no las solapa correctamente. Lo proceso con la calibración RIG activada. Para el ejemplo se trata de un gsd de unos 5 cm aproximadamente.
Muchas gracias.
Hola,
¿Puede crear un ticket para el soporte técnico? Por favor, envíenos su log file, conjunto de datos y capturas de pantalla que muestren los errores.
Sinceramente,
