Previous | Next |
The following list contains a sample of supported cameras in Pix4Dfields.To see the complete database, download the following file: Camera database of Pix4Dfields
If the camera is not listed in the article, check the camera and its parameters in the Pix4Dfields camera database. If the camera parameters are the same as the ones in the database, Pix4Dfields will be able to read the images. If the camera is not listed in the article, but it is in the camera database, it is recommended to test processing the images in Pix4Dfields using the trial version of the software.
Manufacturer | Camera | Syntax |
Parrot | Anafi | Anafi_4.0_4608x3456 Anafi_4.0_5344x4016 |
Sequoia | Sequoia_4.0_1280x960 Sequoia_4.9_4608x3456 Sequoia_4.0_1280x970 Sequoia_4.9_4000x3000 |
MicaSense | Altum | Altum_1.8_160x120 Altum_8.0_2064x1544 |
RedEdge | RedEdge_5.5_1280x960 | |
RedEdge-MX RedEdge-M |
RedEdge-M_5.5_1280x960 RedEdge-M_5.5_960x1280 |
senseFly | S.O.D.A. | S.O.D.A._10.6_5472x3648 S.O.D.A._10.2_5472x3648 |
DJI | Spark | FC1102_4.5_3968x2976 |
Mavic Air | FC2103_4.5_4056x3040 | |
Mavic Pro | FC220_4.7_4000x3000 FC220_4.7_4000x2250 |
Mavic 2 Zoom | FC2204_4.4_4000x3000 | |
Mavic Enterprise Dual | FC2403_4.5_4056x3040 | |
Phantom 3 | FC300C_3.6_4000x3000 | |
Phantom 3 Advanced | FC300S_3.6_4000x3000 FC300S_3.6_4000x2250 |
Phantom 3 Professional | FC300X_3.6_4000x3000 FC300X_3.6_4000x2250 |
Mavic Air 2 | FC3170_4.5_8000x6000 | |
Phantom 4 | FC330_3.6_4000x3000 FC330_3.6_4000x2250 |
Zenmuse X3 | FC350_3.6_4000x3000 | |
Zenmuse X5 | FC550_DJIMFT15mmF1.7ASPH_15.0_4608x3456 | |
Zenmuse X5RAW | FC550RAW_DJIMFT15mmF1.7ASPH_15.0_4608x3456 | |
Phantom 4 Pro | FC6310_8.8_5472x3648 FC6310_8.8_4864x3648 FC6310_8.8_5472x3078 |
Phantom 4 RTK | FC6310R_8.8_5472x3648 FFC6310R_8.8_4864x3648 |
Phantom 4 Pro V2 | FC6310S_8.8_4864x3648 FC6310S_8.8_5472x3648 |
P4 Multispectral | FC6360_5.7_1600x1300 | |
Zenmuse X4S | FC6510_8.8_5472x3648 FC6510_8.8_4864x3648 FC6510_8.8_5472x3078 |
Zenmuse X5S | FC6520_DJIMFT15mmF1.7ASPH_15.0_5280x3956 | |
Zenmuse X7 | FC6540_DJIDL24mmF2.8LSASPH_24.0_6016x4008 FC6540_0.0_5248x3936 |
AeroVironment | Quantix | Quantix_2.6_2432x1824 Quantix_5.2_4864x3648 Quantix_5.4_4864x3648 Quantix_5.4_2432x1824 |
Hello, I can see the Mavic Mini (FC7203_4.5_4000x2250) in the supported camera list, but when trying to import jpegs to Pix4dfields it keeps saying that is isn't compatible. I downloaded the database file and couldn't find the lines for FC7203.
Do you know the solution? Thanks!
Hey, thanks for letting us know. Indeed this camera is not yet supported, but we are working to add it soon. Meanwhile, you can use an XML file to test it some users have shared this file with us. You can contact us with a ticket to support and we can gladly give it to you.
Hello,
Is this camera no longer supported? I have downloaded sequoia_update.plf from https://support.parrot.com/us/support/products/parrot-sequoia and uploaded through USB cable to http://192.168.42.2/ .
Hi John,
We think you are using images from the front camera. Could you please let me know if you are doing that intentionally? Usually, our users process the images from the ParrotSequia camera which is also integrated into that drone, and the images are stored in the SD card.
Best,
Hello,
I have imported Images from a DJI 4P Multispectral to Pix4D Fields. After processing the orthomosaic looks that it was not aligned properly.
Any thoughts? Please help
Thank you
Hey George,
Did you process with the rig relative calibration option? If this does not work, could you please create a ticket to support? Please send us the log file, information about the overlap, speed, weather conditions during the acquisition, and if possible the dataset. We can replicate the issue, and explain the reason for the issues. Then, we can share the outputs here.
What is the best way to view or read the contents of the camera database file. Do you have a dedicated reader that displays the data in table form or some other form?
Dear Gary,
You can download the file and see it with a text editor such as Notepad++. I think this is the best way to see it. We do not have another reader that can display this information as a table. If you have some issues understanding the format, you can contact support or post in our community, we will gladly help you.
Kind regards,
Need help to import and process the images. I am getting following error.
Thanks,
Anand
Anand, this XML file should work: https://drive.google.com/drive/folders/1XYnoUyOciM7Xt1Z1EUHJXdL-8rexluDx?usp=sharing
You will need to import this file in Pix4DFields. Let us know if you need any help.
