Current version 1.11
Version | Release date | Release type |
1.11 | March 9th, 2022 | New features, Bug fix |
New features
- Accurate processing mode for high resolution digital surface models (DSM), improved geolocation and datasets with strong elevation changes.
- Added full blending processing option to improve colour transitions in datasets with thin structures (at the cost of slight unsharpness).
Fix/Improvements
- Improved band alignment for the DJI Phantom 4 Multispectral with Accurate processing.
- Improved usability of processing settings.
- Moved Share to Cloud to the export menu.
- Support for MicaSense RedEdge-P.
- Support for DJI Mavic 2 Enterprise Advanced (RGB only).
- Support for Sentera 6X Thermal.
- Fixed blue map on MacOS for some GPU models.
- Fixed crash when exporting PDF reports containing line annotations.
Known issues
- Windows 11 and synchronizing with OneDrive while importing images.
Versions 1.10.1
1.10.1 | October 5th, 2021 | Bug fix, Known issues |
Fix/Improvements
- Fixed a bug in the PDF report where the layer area size was incorrectly displayed in metric units when a user used imperial units.
- Improved PDF report layer order. Your layers will now display alphabetically by layer type Orthomosaic, DSM, Index, Zonation.
- Fixed an issue where some buttons and text were hidden due to the screen resolution.
- Fixed an issue where you could not cancel a PDF report generation.
- Improved the tooltips for the custom index calculator when your custom index is missing a name.
Known issues
- A line annotation on either a DSM or Index layer when exported to PDF will cause PDF export to crash.
Versions 1.10.0
1.10.0 | September 7th, 2021 | New features, Bug fix, Known issues |
Version 1.10.0 |
New
- Upload outputs (ortho, surface model, index layers) directly to PIX4Dcloud for sharing
- Customize the PDF report with your own logo and contact details
- GPU acceleration to reduce processing time (applies to RGB datasets only where available)
- Now available in French, Italian, Korean, Ukrainian and Russian
- Layer export menu with option to scale output size, including selection to export original or an RGB compressed geoTIFF and option to include overviews for faster opening of the output in a third party GIS solution
- Improved workflow for copying and deleting annotations
- Additional statistical information in the layer info tab, CSV export and PDF report
- Improved support for processing DJI P4 Multispectral
- Support for Sentera reflectance targets
Bug fixes
- Importing a project now displays progress bar
- Display more information about the dataset acquisition time when missing time zone information
- Custom basemaps now display when exporting a snapshot or PDF report
- Annotations now correctly export the “name” value
- Improved explanation that a boundary area size can be a combination of multiple boundary area measurements
- Improved UI for custom index calculator
- Improved annotation line measurement accuracy
- Updated target detection for the latest MicaSense reflectance targets
Other
- Fixed transparency issue for outputs uploaded to PIX4Dcloud
- End of support for exporting directly to MyJohnDeere due to authorization protocols changes
- Notification that PIX4Dfields 1.10 will be the last version to support the current DataSync feature (in the future sharing will be via Share to PIX4Dcloud)
- Unit conversion issue. When using imperial measurements, some statistics do not convert from ha to acres
Versions 1.9
1.9.0 | February 3, 2021 | New features, Bug fix, Known issues |
Version 1.9.0 |
New
- Improvement of user interface inside projects, especially for annotation management
- Statistics for DSM and index layers and for their area annotations (mean and standard deviation)
- Display of DSM and index layer value for point annotations
- Export of layer and annotation statistics as well as point annotation values as CSV and part of the PDF report
- Ability to import multi-polygon shapes as annotations and split into individual polygons
- Import GPS tagged images as geolocated annotations on a layer
- Option to display images attached to annotations directly on the map
- Export of annotations in KML format
- RTK support for DJI Phantom 4 RTK and other selected drone-camera combinations
- Support for 10-band MicaSense RedEdge-MX Dual Camera Imaging System, including support for custom index creation in the index calculator using any combination of bands
- Support for Delair UX11, DJI Zenmuse X7
- Rig alignment for all bands of the MicaSense Altum including thermal
Bug fixes
- Importing a single-band floating-point GeoTIFF (i.e. DSM or index) prompts the user to select the layer type to ensure correct color modes and units are displayed
- Improved PDF report layout to avoid unnecessary wasted space
- Improved detection of MicaSense reflectance targets
Known issues
- Exported layers to MyJohnDeere will not display visualization adjustments
- Importing a large project into Pix4Dfields does not show a progress bar and loads in the background without locking the UI. Please wait as your project is still loading
- Importing annotations with attachments in geoJSON format will trigger a warning that your project is missing data. We currently do not support this functionality. Instead, attach your file to the annotation once imported.
Versions 1.8
1.8.1 | August 26, 2020 | Bug fix |
1.8.0 | August 6, 2020 | New features, Bug fix |
Version 1.8.1 |
Fix/Improvement
- Radiometric correction for some datasets was rejected due to a negative relative angle of the sunshine sensor.
Known issues
Version 1.8.0 |
New
- Advanced layer visualization for index and surface model layers:
- Set the range of values displayed.
- visualize out of range values as either transparent or solid colors.
- toggle on/off histogram equalization [index layers only].
- view in app or export your defined visualization.
- Improved radiometry, including full support for MicaSense DLS2.
- Additional languages: Chinese and Portuguese.
- Color selection for annotations (point, line, area).
Improvements
- Improved processing of DJI Phantom 4 Multispectral data.
- Improved processing of Quantix RGN data.
- Data Sync stability when changing root folder.
- PDF report export stability.
Known issues
- Exported layers to MyJohnDeere will not display visualization adjustments.
Versions 1.7
1.7.1 | May 28, 2020 | Bug fix |
1.7.0 | March 10, 2020 | New features, bug fix |
Version 1.7.1 |
Fix
- Essential update to allow continued functionality of the default basemap.
Known issues
- Importing a GeoTIFF into Pix4Dfields desktop created with Pix4Dmapper or Pix4D Cloud will show the alpha channel as black instead of transparent when displayed.
- Surface model layers created prior to 1.6 will not display the DSM colormode. The scale bar will not include units of measurement.
Version 1.7.0 |
New
- Share outputs from Pix4Dfields directly to your John Deere Operations Center.
- Ability to switch language between English, German, Japanese, and Spanish.
- Import images by selecting a folder.
- Custom index formulas can now be saved, reused and synchronized to other devices with Data Sync
- Select and display custom basemaps via URL.
- Support for Sentera Single sensor (Make sure that the version of the firmware is updated to version 2.3.2)
Known issues
- Surface model layers created prior to 1.6 will not display the DSM color mode. The scale bar will not include units of measurement.
Versions 1.6
1.6.1 | January 23, 2020 | Improvements, known issues |
1.6.0 | November 26, 2019 | New features,improvements, known issues |
Version 1.6.1 |
Improvements
- Regular updates include stability and minor bug fixes.
- Fix to allow Mac users to import a project and open correctly.
- Resolves an issue where RGB orthomosaics generated an unexpectedly large file size.
- Improved comparison mode responsivenes.
- Support for Sony ILCE-6000, iPhone XR/XS.
- Additional support for DJI Phantom 4 Multispectral.
Known issues
Version 1.6.0 |
New
- High detail orthomosaic generation and control over file size and resolution as part of Advanced Processing settings.
- New measurement tools to create area and line measurements as part of Annotations feature.
- Base layer switcher between satellite, roadmap and no map.
- Snapshot tool on Exports to take a screenshot of the existing field of view.
- Support for DJI Phantom 4 Multispectral (Make sure that the version of the firmware is updated to v01.16.0007) and DJI Mavic 2 Dual Enterprise (RGB sensor).
Improvements
- Regular updates include stability and minor bug fixes. .
Known issues
Versions 1.5
1.5.1 | October 1, 2019 | New, bug fix |
1.5.0 | August 15, 2019 | New, bug fix |
Version 1.5.1 |
Improvements
- Support radiometric correction for multi-channel images, produced by modified RGB cameras.
Bug fixes
- After syncing, a layer modified in two devices loads correctly.
- Canceling and restarting a group synchronization does not cause errors.
- When projects are synchronized, the order of the layers is preserved.
- After syncing, a border modified in two devices is duplicated.
- An annotation that was deleted on one device and modified in another device synchronizes correctly.
- Second import of images after the display of an index layer does not retain the histogram on the screen.
- When the message "Some reflectance targets were not found" is displayed on the application, a radiometric correction performs without the reflectance target information.
- Notification of a new Pix4Dfields version shows up on the application.
Version 1.5.0 |
What is new
- Radiometry.
- Data sync.
- Location indicator when clicking on the map.
Improvements
- Processing can be canceled during bundle adjustment and stitching phases.
- Better geometric calibration for low altitude flights.
- The PDF report now includes annotations.
- Capture locations are displayed after images have been imported.
- Shapefile format can be imported to John Deere Operations Center.
- Field boundaries can be imported as .kml files.
- Non-float single band GeoTIFF can be imported.
- Significant speed-up of the zonation computation including a progress bar during the zonation computation and cancellation option.
- Project log files can be exported from the dashboard without opening the project.
Bug fixes
- Editing a border does not duplicate the border.
- Initial project location opens according to the last project location.
- Improve initial map center for empty projects.
- Custom indices are now correctly displayed in the PDF report.
- Fixed scrolling issue with mac touch-pads on the dashboard.
- Show an error message attempting to take an annotation photo without any camera support.
- Fixed misalignment of image thumbnails.
Versions 1.4
1.4.0 | March 20, 2019 | New, bug fix |
Version 1.4.0 |
What is new
- Dashboard: new look and feel, this includes a sidebar to access: Help, Settings, Project Options.
- Dashboard: you can group your project by: company, farm, client; in addition assign crop types and varieties.
- Dashboard: a project can be assigned a description which is visible on the dashboard project tile.
- Dashboard: a project tile will show the field size (based on the field boundary).
- PDF reports can now be created from a project which includes layers of the map.
Improvements
- Algorithmic correction for rig relatives.
- Dataset feedback prior to processing, notification if the camera is not supported.
- Support for new camera models included improved support for DJI cameras.
- Image attachments for annotations.
- Improved editing of field boundaries: drag/remove points when editing.
- Processing the images now uses less memory by using tiling.
- Increased performance: shape and display of zonation maps.
- Switch between imperial and metric units of measurement.
- Project file storage has been regrouped, as part of this, a logfile export is now possible in project.
- Universal Transverse Mercator (UTM) is the coordinate system used for the orthomosaics (instead of Transverse Mercator) for better interoperability with other software.
Bug fixes
- Incorrect calculation of the zonation area.
Known issues
- PDF report does not include annotations currently
Versions 1.3
1.3.0 | August 22, 2018 | New, bug fix |
Version 1.3.0 |
What is new
- Dashboard view showing recent projects.
- Custom index calculator.
- Dark theme, still includes original light theme.
- Built in index: MCARI.
Improvements
- 2x speed up on high resolution JPEG datasets.
- Robustness to inaccurate GPS tags.
- Removed moire patterns on datasets with many thin lines (e.g. crop lines).
- Add support for new cameras.
- Better false-RGB from datasets missing the blue band.
Bug fixes
- Fixed crash on certain datasets with orphaned images.
Known issues
- On initial run of software after upgrade icons may appear incorrectly.
Versions 1.2
1.2.0 | July 23, 2018 | New, bug fix |
Version 1.2.0 |
What is new
- Histogram of data distribution for indices / Digital Surface Model (DSM).
- Export histogram and legend when exported indices / DSM.
- DSM-specific color mode with isoluminant colors and hill-shading.
- Scale shown on map in the main view.
Improvements
- Reduced noise in orthomosaic with high resolution and/or large projects.
- Better adapt DSM structure for mixed-complexity projects.
- Hill-shading on DSM improved for slower GPUs.
- Show progress bars for more operations:
- Project load
- Export
- Index generation
- Make prescriptions unit-agnostic
Bug fixes
- Fix ranges of legend for indexes / DSM.
- Do not try to import non-annotation GeoJSON file as an annotation.
Known issues
- On windows, on the very first run after upgrade some icons may be wrong.
Versions 1.1
1.1.0 | July 04, 2018 | New, bug fix |
Version 1.1.0 |
What is new
- Digital Surface Model (DSM) generation and color scheme.
- Scale shown for indices and DSM.
- Automatic filtering of layers for trimming.
- Adapt processing and UI performance to available RAM.
Improvements
- Improved orthomosaic in non-flat scenes.
- Improved color blending.
- Faster project loading.
- Updated icons and logos.
Bug fixes
- Fix bug for Sequoia RGB image processing.
- Fix bug for MicaSense RedEdge camera processing following firmware update.
- Various bug fixes.
Known issues
- Export images not compatible with MicaSense Atlas.
Versions 1.0
1.0.0 | June 07, 2018 | Initial release |
Version 1.0.0 |
Pix4Dfields is a new standalone software built for agriculture with the input from farmers, agronomists and breeders.
- Fast and accurate maps while in field.
- Orthomosaic generation from drone images.
- Pre-determined list of index maps.
- Zonation and prescription maps.
- Comparison and annotation tools.
- Import and Export functionality.
