Imports and exports
 Previous  |  Next
Import images
Import either drone images or an existing GeoTIFF.
1. Click the icon Import.
2. (optional) To import drone images (.jpg or .tif format) click IMPORT IMAGES.
3. (optional) To import an existing GeoTIFF file (.tif format) click IMPORT GEOTIFF.
Import field boundaries
 Import field boundaries.
1. After importing images the option to import field boundaries is available.
2. To import a field boundary, click the FIELD BOUNDARIES menu.
3. Click Import field boundary.
4. Navigate to the folder containing the file and select it.
5. Click Open.
6. The prompt Do you want to trim the layers intersecting the border? appears, check the box(es) beside the layer(s) to be trimmed.
7. Click TRIM.
Import annotations
Import annotations.
1. Select the layer where to add annotations.
2. Click the Annotate icon on the top right of the project screen.
3. At the bottom of the left sidebar, click on the menu icon next to ANNOTATIONS.
4. Click Import. The cursor changes to a “plus” sign.
5. Navigate to the folder containing required files and select.
6. Click Open.
Exports
Export layers from a project for use outside the software.
1. Click the tab Export.
2. On the left sidebar, check layers for export.
3. (optional) If prompted, select export formats.
4. Click EXPORT.
5. Select a destination folder, click Select Folder (Windows users) / Open (macOS users).
0 out of 7 found this helpful
23 comments
  • Mike powell
    What programs can I export my 3d buildings to.
  • Sam (Pix4D)
    Hi Mike,
    Pix4Dfields does not support 3D structures, for this type of functionality please use Pix4Dmapper.  The export types can be found here: https://support.pix4d.com/hc/en-us/articles/202558499#label6
    For more general information about the export options to third party software can be found in the following articles:
    https://support.pix4d.com/hc/en-us/sections/360000210023
    If you have a more specific question and are unable to find the answer in our knowledge base please reach out to us by clicking the button at the top of this page called Contact Support
    Regards, Sam
  • Sam Chapman
    Hi Sam,
    how can i export from Pix4Dmapper?
    i dont see an export button?
  • Blaž (Pix4D)
    @Sam, there are two ways to export the 3D textured mesh:
    1. Directly in the Processing Options of Step 2. Point Cloud and Mesh.
    2. By right-clicking on the Mesh in the Layers section (rayCloud):
    Edited by Blaž (Pix4D)
  • Natália Veleda
    Boa tarde.
    Estou em período de teste com Pix4DFields, e eu gostaria de saber como exportar as imagens já processadas para o Atlas Mica Sense, é possível? Se sim, como?
    Na versão anterior eu conseguia fazer esta ligação.
  • Sam (Pix4D)
    Olá Natália,
    Infelizmente Pix4dFields não suporta exportar os resultados para o Atlas MicaSense. Nós estamos trabalhando com MicaSensa numa solução para suportar essa funcionalidade no futuro. Atualmente, você apenas pode exportar de um software Pix4D diretamente para o Atlas MicaSense se usar o Pix4DMapper.
    Saudações, Sam.
  • Felippe Kelling
    Boa tarde.
    Realizei uma prescrição no programa e converti para shp, para que o arquivo pudesse ser aberto pela controladora mas o valor que constava era o valor atribuído no "rate [units/ha]" ao invés de ser "amount [units]". Isso está correto?
  • Sam (Pix4D)
    Boa tarde,
    O shapefile contém os seguintes dados:
    Coluna 1: "amount" = quantidade [unidades] / amount [units]
    Coluna 2: "area" = área [ha] / area [ha]
    Coluna 3: "avgValue" = valor médio / average value
    Coluna 4: "rate" = taxa [unidades / ha] / rate [units/ha]
    Você precisará verificar como sua maquinaria lê shapefiles e selecionar as colunas necessárias.
    Normalmente, isso seria "rate" para alterar a quantidade de fertilizante / semente aplicada. Estamos trabalhando para melhorar a ferramenta de zoneamento e facilitar a exportação para maquinaria normalmente usada na indústria.
  • Disraeli Beber
    Na hora de realizar uma prescrição o sistema só aceita (ponto), e minhas maquinas só aceitam (virgula), teria como mudar alguma configuração para o Pix4d Aceitar a prescrição de taxa com (virgula) ???
  • Beata (Pix4D)
    Oi Disraeli,
    Pode você explica o problema mais uma vez usando palavras diferentes ou idealmente inglês?
    Você usa Pix4Dfields ou Pix4Dmapper?
    O problema ocorre enquanto você importar GCPs?
    Pode você enviar uma captura de tela?
    Se possível, responda em inglês. Por enquanto nós não fornecemos o suporte oficial em português e mais pessoas poderão ver e entender o problema ;-)
    Edited by Beata (Pix4D)
  • Tomas Martinex
    Hi,
    I'm exporting an orthomosaic and it doesn't have any projection, and when I assign one it goes to a wrong place. Thanks! Tomas
  • Marco (Pix4D)
    Hi Tomas,
    Could you be more precise on the issue you are facing?
    Could you add the images, log file, *.p4d file, screenshots of your project here:
    one drive
    Then we will be able to investigate further and hopefully be able to help you,
    Best,
  • Hugo Solari
    Hola, me podrias demostrar como se importa un shapefile?
  • Marco (Pix4D)
    Hola Hugo,
    Puede importar un shapefile usando la herramienta de importación de "Field Boundaries" ubicado en la parte inferior de la ventana.
    Saludos
  • Obed Media Aerea
    Hola,
    Como puedo exportar los analisis y ortomosaico creado en Pix4D Fields en archivos KML?
  • Marco (Pix4D)
    Hola Obed Media Aerea,
    Lamentablemente por el momento no es posible exportar ningún resultado en formato KML desde Pix4Dfields.
    Sólo se puede exportar KML (Orthofoto y mapa térmico) desde Pix4Dmapper.
    Pix4D-outputs-with-other-software-by-output
    Saludos
  • Elias Kopty
    How to select specific point and to export the coordinates of this point to csv or txt file ..
    There is a way to do it in the web platform .. but i need to do it on the desktop version
  • Fernanda Bosmediano
    Hi Elias,
    Currently, that can not be done in Pix4Dfields 1.4. However, this feature will be included in our future versions. It is definitely in our roadmap.
    Regards,
  • Elias Kopty
    Hi fernando
    I don't have pix4dfield
    I have pix4dmapper
    Hi Elias,
    You can export Manual Tie Points and/ or GCPs using Pix4Dmapper. You can find some guides here and here. I recommend you to post Pix4Dmapper questions on the corresponding pages. This is an article about Pix4Dfields.
    Best of successes in your projects
  • Matej Tabačák
    Helou Pix4D,
    I have a question about support tractor mechanism. How mark tractor are supported in software installed in tractors. We have exports shape files from Pix4Dfields. Can you help me? Thank you.
    Hi Matej,
    We find very interesting that you are using tractors with our software. Could you please raise a ticket with this? Here I leave you the link to contact support. I will be waiting for it, to better understand your problem and assist you in the best possible way.
    Best,
  • Momtanu (Pix4D)
    Matej,
    Adding to Fernanda's query, I would like to know which farm management software are you using in the tractor? I know John Deere had some issues before but you should be able to use the prescription map shp files.
