Zonation and prescription
 Previous  |  Next
Zonation
To create a zoned map from an index map.
1. Click the Zonation & Prescription icon on the top right of the window. The ZONATION tool opens in the left sidebar.
2. Select the Input map layer from the dropdown menu. The input map can be either an index layer or the surface model.
3. Set the Map Detail to either Normal or High, and then choose the Number of  Classes in which the values of the index will be distributed. The number of classes chosen corresponds to the number of zones in the output layer.
4. Click GENERATE, and then, if you are satisfied with the result.
5. Click APPLY to create the layer.
6. The Zonation layer now appears in the list of layers. You can rename the layer.
Export Zonation
To export a zonation map.
1. Click the Export icon on the top right of the window.
2. In the EXPORT sidebar, select  Data files below Select export type.
3. Below Select layers, check the box next to Zonation.
4. Under Select export format, check the boxes to export the layer in the needed format (GeoJSON, KML, Shapefile (.zip)).
5. Click EXPORT.
Prescription
To input prescription values on a zonation map.
1. Generate a zonation map as outlined in section Zonation.
2. On the right sidebar under rate [units/ha] input the desired values for each zone.
3. The column amount [units] will update based on the inputs.
4. Click SAVE.
Note: The rate and amount of units depend on the farm machinery the software in which these prescriptions are going to be used. It could be kilograms, liters, or seeds per hectare for example
2 out of 3 found this helpful
