Comparison Tool
 Previous  |  Next
Comparison Tool
Comparison Tool
To compare layers:
1. Click the Compare icon on the right upper corner of the screen.
2. On the left sidebar select the layers to view.
3. Click the icon beside a layer to set as left or right view.
To change views:
2. Select which layers you would like to compare and in which view by selecting the correct split screen icon next to the layer’s name.
3. At the top right of the window, the Double Screen view is selected by default.
4. Click the other icon to switch to the Split Screen view.
5. You can move the vertical line in the middle of the map interface from side to side.
6. (optional) Once you are finished comparing layers, click the cross symbol next to COMPARE on the left sidebar to exit the comparison tool.
1 out of 3 found this helpful
