Download and installation - PIX4Dfields
 Previous  |  Next
Download
To download the software:
  1. Go to the download page.
  2. Download PIX4Dfields for Windows or macOS.
Installation on macOS
Once the software has been downloaded, install it using the following steps:
1. Double-click the downloaded file.
2. Drag and drop the PIX4Dfields logo into Applications.
3. Navigate to Finder and click on the tab Applications.
4. Double-click PIX4Dfields to run the program.
5. (optional) If the pop-up appears, click Open.
Installation on Windows
1. Double-click the downloaded file. The PIX4Dfields Setup wizard starts.
2. (optional) If the pop-up Open file - Security Warning appears, click Run anyway.
3. In the pop-up PIX4Dfields Setup, click Next.
4. Read and agree to the End-User License Agreement to continue the installation. Click Next.
5. (optional) Click Change... to change the destination path for installation and click Next.
6. Click Install.
7. (optional) In the software window: "Do you want to allow the following program to install software on this computer?", click Yes.
8. Click Finish.
9. A shortcut is created on your desktop once the installation is completed.
Login
For step-by-step instructions: PIX4Dfields sign up and the first-time login.
0 out of 1 found this helpful
2 comments
  • Juan daniel Marin solis
    estoy intentando renovar el pix4d field y me envia un error que dice 404 que la pagina no existe o se movio, yengo varios años trabajando con field, me podran ayudar al respecto ultimamente pix4d esta bajando en cuestion de atencion a los cieltes tengo pix4d matic, el pix4d mapper, pme podrian ayudar por favor.
    daniel marin
  • Marco Paccagnella
    Hola Daniel,
    Hemos mandado tu mensaje a nuestro equipo de ventas. Te contactaran para ayudarte lo antes possible.
